root/radiance/ray/SConstruct
Revision: 1.6
Committed: Thu Feb 10 16:42:04 2005 UTC (19 years, 7 months ago) by schorsch
CVS Tags: rad3R7P2, rad3R7P1, rad3R8, rad3R9
Set default to ray/, so all executables end up in ray/bin/.
1
2 import os
3 import sys
4 import string
5
6 OPTFILE = 'rayopts.py'
7 SourceSignatures('timestamp')
8 def set_opts(env):
9 # XXX add some caching
10 opts = Options(OPTFILE, ARGUMENTS)
11 opts.Add('SKIP', 'Skip Display of License terms', 0)
12 opts.Add('RAD_BINDIR', 'Install executables here', env['RAD_BINDIR'])
13 opts.Add('RAD_RLIBDIR', 'Install support files here', env['RAD_RLIBDIR'])
14 opts.Add('RAD_MANDIR', 'Install man pages here', env['RAD_MANDIR'])
15 opts.Add('RAD_DEBUG', 'Build a debug version', 0)
16 opts.Update(env)
17 opts.Save(OPTFILE, env)
18 Help(opts.GenerateHelpText(env, sort=cmp))
19 # where stuff is located in the source tree
20 env['RAD_BUILDLIB'] = '#src/lib'
21 env['RAD_BUILDBIN'] = '#bin'
22 env['RAD_BUILDRLIB'] = '#lib'
23 env['RAD_BUILDMAN'] = '#doc/man'
24
25 def allplats_setup(env):
26 from build_utils import find_libs
27 find_libs.find_x11(env)
28 find_libs.find_gl(env) # OpenGL
29
30 def post_common_setup(env):
31 env.Append(CPPPATH = [os.path.join('#src', 'common')])
32 env.Append(LIBPATH=['../lib']) # our own libs
33 if not env.has_key('RAD_MLIB'):
34 env['RAD_MLIB'] = [] #['m'] # no seperate mlib on Win
35
36 def shareinstall_setup(env):
37 from build_utils import install
38 # only scan for those files when we actually need them
39 if 'install' in sys.argv or 'rlibinstall' in sys.argv:
40 install.install_rlibfiles(env)
41 if 'install' in sys.argv or 'maninstall' in sys.argv:
42 install.install_manfiles(env)
43
44 # Set up build environment
45 env = Environment()
46
47 if os.name == 'posix':
48 from build_utils import install
49 csh_b = Builder(action = install.install_cshscript,
50 suffix = '', src_suffix = '.csh')
51 env.Append(BUILDERS={'InstallCsh': csh_b})
52
53 # configure platform-specific stuff
54 from build_utils import load_plat
55 load_plat.load_plat(env, ARGUMENTS, platform=None)
56
57 # override options
58 set_opts(env)
59
60 # accept license
61 if not env['SKIP'] and not '-c' in sys.argv:
62 from build_utils import copyright
63 copyright.show_license()
64
65 # fill in generic config
66 allplats_setup(env)
67
68
69
70 # Bring in all the actual things to build
71 Export('env')
72 SConscript(os.path.join('src', 'common', 'SConscript'))
73 post_common_setup(env)
74 for d in Split('meta cv gen ot rt px hd util cal'):
75 print d
76 SConscript(os.path.join('src', d, 'SConscript'))
77
78 if string.find(string.join(sys.argv[1:]), 'install') > -1:
79 shareinstall_setup(env)
80
81 Default('.')
82
83 # virtual targets
84 env.Alias('bininstall', '$RAD_BINDIR')
85 env.Alias('rlibinstall', '$RAD_RLIBDIR')
86 env.Alias('maninstall', '$RAD_MANDIR')
87
88 env.Alias('build', ['#bin'])
89 env.Alias('test', ['#src/test'])
90 env.Alias('install', ['bininstall', 'rlibinstall', 'maninstall'])
91
