root/Development/ray/SConstruct
Thu Feb 10 16:42:04 2005 UTC (20 years, 8 months ago) by schorsch
Diff to previous 1.5
Set default to ray/, so all executables end up in ray/bin/.
Fri Nov 5 22:15:42 2004 UTC (21 years ago) by schorsch
Changes since 1.4: +0 -10 lines
Diff to previous 1.4
Thu Oct 21 15:47:11 2004 UTC (21 years ago) by schorsch
Changes since 1.3: +12 -5 lines
Diff to previous 1.3
SCons build simplifications.
Sun Jul 4 12:08:47 2004 UTC (21 years, 4 months ago) by schorsch
Changes since 1.2: +8 -11 lines
Diff to previous 1.2
Mon Oct 27 10:35:41 2003 UTC (22 years ago) by schorsch
Changes since 1.1: +4 -7 lines
Diff to previous 1.1
Tue Oct 21 19:27:28 2003 UTC (22 years ago) by schorsch
