--- ray/SConstruct 2004/07/04 12:08:47 1.3 +++ ray/SConstruct 2016/03/05 00:25:21 1.12 @@ -4,35 +4,35 @@ import sys import string OPTFILE = 'rayopts.py' - def set_opts(env): - # XXX add some caching - opts = Options(OPTFILE, ARGUMENTS) - opts.Add('SKIP', 'Skip Display of License terms', 0) - opts.Add('RAD_BINDIR', 'Install executables here', env['RAD_BINDIR']) - opts.Add('RAD_RLIBDIR', 'Install support files here', env['RAD_RLIBDIR']) - opts.Add('RAD_MANDIR', 'Install man pages here', env['RAD_MANDIR']) - opts.Add('RAD_DEBUG', 'Build a debug version', 0) - opts.Update(env) - opts.Save(OPTFILE, env) - Help(opts.GenerateHelpText(env, sort=cmp)) + # XXX add some caching + opts = Options(OPTFILE, ARGUMENTS) + opts.Add('SKIP', 'Skip Display of License terms', 0) + opts.Add('RAD_BINDIR', 'Install executables here', env['RAD_BINDIR']) + opts.Add('RAD_RLIBDIR', 'Install support files here', env['RAD_RLIBDIR']) + opts.Add('RAD_MANDIR', 'Install man pages here', env['RAD_MANDIR']) + opts.Add('RAD_DEBUG', 'Build a debug version', 0) + opts.Update(env) + opts.Save(OPTFILE, env) + Help(opts.GenerateHelpText(env, sort=cmp)) # where stuff is located in the source tree - env['RAD_BUILDLIB'] = '#src/lib' - env['RAD_BUILDBIN'] = '#bin' - env['RAD_BUILDRLIB'] = '#lib' - env['RAD_BUILDMAN'] = '#doc/man' + env['RAD_BUILDLIB'] = '#src/lib' + env['RAD_BUILDBIN'] = '#bin' + env['RAD_BUILDRLIB'] = '#lib' + env['RAD_BUILDMAN'] = '#doc/man' def allplats_setup(env): - from build_utils import find_libs - find_libs.find_x11(env) - find_libs.find_gl(env) # OpenGL - #find_libs.find_pixar(env) # PIXAR_LIB for src/px/ra_pixar.c + from build_utils import find_libs + find_libs.find_radlib(env) + find_libs.find_x11(env) + find_libs.find_gl(env) # OpenGL + find_libs.find_libtiff(env) def post_common_setup(env): - env.Append(CPPPATH = [os.path.join('#src', 'common')]) - env.Append(LIBPATH=['../lib']) # our own libs - if not env.has_key('RAD_MLIB'): - env['RAD_MLIB'] = [] #['m'] # no seperate mlib on Win + env.Append(CPPPATH = [os.path.join('#src', 'common')]) + env.Append(LIBPATH=['../lib']) # our own libs + if not env.has_key('RAD_MLIB'): + env['RAD_MLIB'] = [] #['m'] # no seperate mlib on Win def shareinstall_setup(env): from build_utils import install @@ -44,7 +44,14 @@ def shareinstall_setup(env): # Set up build environment env = Environment() +env.Decider('timestamp-match') +if os.name == 'posix': + from build_utils import install + csh_b = Builder(action = install.install_script, + suffix = '', src_suffix = '.csh') + env.Append(BUILDERS={'InstallScript': csh_b}) + # configure platform-specific stuff from build_utils import load_plat load_plat.load_plat(env, ARGUMENTS, platform=None) @@ -53,40 +60,38 @@ load_plat.load_plat(env, ARGUMENTS, platform=None) set_opts(env) # accept license -if not env['SKIP'] and not '-c' in sys.argv: - from build_utils import copyright - copyright.show_license() +if ((not env['SKIP'] + or env['SKIP'].strip().lower() in (0,'0','no','false')) + and not '-c' in sys.argv and not 'test' in sys.argv): + from build_utils import copyright + copyright.show_license() # fill in generic config allplats_setup(env) # Bring in all the actual things to build Export('env') -SConscript(os.path.join('src', 'common', 'SConscript')) -post_common_setup(env) -for d in Split('meta cv gen ot rt px hd util cal'): - print d - SConscript(os.path.join('src', d, 'SConscript')) +if 'test' in sys.argv: + SConscript(os.path.join('test', 'SConscript')) + +else: + SConscript(os.path.join('src', 'common', 'SConscript')) + post_common_setup(env) + for d in Split('meta cv gen ot rt px hd util cal'): + print d + SConscript(os.path.join('src', d, 'SConscript')) -if string.find(string.join(sys.argv[1:]), 'install') > -1: - shareinstall_setup(env) + if string.find(string.join(sys.argv[1:]), 'install') > -1: + shareinstall_setup(env) +Default('.') + # virtual targets -# RAD_XXXINSTALL are filled in by the local scripts -env.Alias('bininstall', env.get('RAD_BININSTALL', [])) -env.Alias('rlibinstall', env.get('RAD_RLIBINSTALL',[])) -env.Alias('maninstall', env.get('RAD_MANINSTALL', [])) +env.Alias('bininstall', '$RAD_BINDIR') +env.Alias('rlibinstall', '$RAD_RLIBDIR') +env.Alias('maninstall', '$RAD_MANDIR') env.Alias('build', ['#bin']) -env.Alias('test', ['#src/test']) +env.Alias('test', ['#test']) env.Alias('install', ['bininstall', 'rlibinstall', 'maninstall']) - -# Further virtual targets are defined locally: -# meta_special: mt1601 okimate imagew mt160 mx80 impress aed5 -# tcurve tscat tbar mtext libt4014.a plotout t4014 -# px_special: ra_im, t4027, paintjet, mt160t, greyscale, colorscale, d48c -# util_special: scanner, makedist (not for Windows yet) -env.Alias('special', ['meta_special', 'px_special', 'util_special']) -env.Alias('special_install', ['meta_special_install', - 'px_special_install', 'util_special_install'])
