--- ray/SConstruct 2016/03/28 17:48:43 1.18 +++ ray/SConstruct 2018/01/09 00:08:57 1.21 @@ -1,25 +1,30 @@ +from __future__ import division, print_function, unicode_literals import os import sys -import string -PATHFILE = 'raypaths.py' -OPTFILE = 'rayopts.py' -def set_pre_opts(env): - vars = Variables(OPTFILE, ARGUMENTS) +def set_pre_opts(testenv): + optfile = File(testenv['CFG_OPTFILE']).abspath + vars = Variables(optfile, ARGUMENTS) vars.Add('SKIP', 'Skip Display of License terms', 0) - vars.Add('RAD_DEBUG', 'Build a debug version', 0) - vars.Update(env) - vars.Save(OPTFILE, env) + vars.Add('RAD_DEBUG', 'Build a debug version', 0) + if testenv['CFG_PLATSYS'] == 'Windows': + # no default, will select the most recent one when empty + vars.Add('MSVC_VERSION', 'Microsoft VC Version', ) + else: # not yet supported on Windows + vars.Add('PMAP_OOC', 'Build Pmap with Out-of-core Data', 1) + vars.Update(testenv) + return vars -def set_opts(env): - vars = Variables(PATHFILE, ARGUMENTS) +def set_opts(env, pathfile): + vars = Variables(pathfile, ARGUMENTS) + vars.Add('RAD_BASEDIR', 'Installation base directory', env['RAD_BASEDIR']) vars.Add('RAD_BINDIR', 'Install executables here', env['RAD_BINDIR']) vars.Add('RAD_RLIBDIR', 'Install support files here', env['RAD_RLIBDIR']) vars.Add('RAD_MANDIR', 'Install man pages here', env['RAD_MANDIR']) vars.Update(env) - vars.Save(PATHFILE, env) - Help(vars.GenerateHelpText(env, sort=cmp)) + vars.Save(pathfile, env) + Help(vars.GenerateHelpText(env)) # where stuff is located in the source tree # the binary target libs are configured by platform env['RAD_BUILDRLIB'] = '#lib' @@ -31,6 +36,7 @@ def allplats_setup(env): find_libs.find_x11(env) find_libs.find_gl(env) # OpenGL find_libs.find_libtiff(env) + find_libs.find_pyinstaller(env) def post_common_setup(env): env.Append(CPPPATH = [os.path.join('#src', 'common')]) @@ -46,17 +52,23 @@ def shareinstall_setup(env): if 'install' in sys.argv or 'maninstall' in sys.argv: install.install_manfiles(env) -_arch = None -for item in sys.argv[1:]: - if item.startswith('TARGET_ARCH'): - res = item.split('=') - if len(res) == 2: - _arch = res[1].strip() +# first figure out the platform +from build_utils import load_plat +testenv = Environment() +load_plat.identify_plat(testenv) +# set stuff before loading platforms +prevars = set_pre_opts(testenv) + # Set up build environment -env = Environment(TARGET_ARCH=_arch) +env = Environment(variables=prevars) env.Decider('timestamp-match') +if env.get('PMAP_OOC', 0) in (0,'0','','n','no','false',False,None): + print('Building Photon-Maps with In-core KD-Tree') +else: + print('Building Photon-Maps with Out-of-core Octree') + from build_utils import install script_b = Builder(action = install.install_script, suffix = '') env.Append(BUILDERS={'InstallScript': script_b}) @@ -64,26 +76,36 @@ if os.name == 'posix': tclscript_b = Builder(action = install.install_tclscript, suffix = '') env.Append(BUILDERS={'InstallTCLScript': tclscript_b}) -# set debug before loading platforms -set_pre_opts(env) - # configure platform-specific stuff -from build_utils import load_plat -load_plat.load_plat(env, vars, arch=_arch) +load_plat.load_plat(env, testenv) # override options -set_opts(env) +cfg_pathfile = File(testenv['CFG_PATHFILE']).abspath +set_opts(env, cfg_pathfile) +load_plat.combine_instpaths(env) + # accept license if ((not env['SKIP'] or env['SKIP'].strip().lower() in (0,'0','n','no','false',None)) and not '-c' in sys.argv and not 'test' in sys.argv): from build_utils import copyright copyright.show_license() + testenv['SKIP'] = '1' +# We waited to save this, so that we can add the SKIP +prevars.Save(File(testenv['CFG_OPTFILE']).abspath, testenv) + # fill in generic config allplats_setup(env) +print('Installation directories:') +print('Base: ', env.subst('$RAD_BASEDIR')) +print('Binaries: ', env.subst('$RAD_BINDIR')) +print('Library: ', env.subst('$RAD_RLIBDIR')) +print('Manpages: ', env.subst('$RAD_MANDIR')) +print() + # Bring in all the actual things to build Export('env') if 'test' in sys.argv: @@ -103,7 +125,7 @@ else: SConscript(os.path.join('src', d, 'SConscript'), variant_dir=os.path.join(env['RAD_BUILDOBJ'], d), duplicate=0) - if string.find(string.join(sys.argv[1:]), 'install') > -1: + if ' '.join(sys.argv[1:]).find('install') > -1: shareinstall_setup(env) Default('.') @@ -113,8 +135,9 @@ env.Alias('bininstall', '$RAD_BINDIR') env.Alias('rlibinstall', '$RAD_RLIBDIR') env.Alias('maninstall', '$RAD_MANDIR') -env.Alias('build', ['$RAD_BUILDBIN', '$RAD_BUILDRLIB']) +env.Alias('build', ['$RAD_BUILDBIN']) #, '$RAD_BUILDRLIB']) env.Alias('test', ['#test']) env.Alias('install', ['bininstall', 'rlibinstall', 'maninstall']) -# vim: set syntax=python: +# vi: set ts=4 sw=4 : +# vim: set syntax=python :
