root/radiance/ray/README
Revision: 1.1
Committed: Sat Mar 15 17:58:16 2003 UTC (22 years ago) by greg
1 RCSid "$Id"
2
3 Hello and welcome to the Radiance synthetic imaging system. This is
4 the thirteenth release, Version 3.5, and it includes all source files
5 for local compilation with a standard C compiler. To find out what's
6 new in this release, check the text file "doc/notes/ReleaseNotes".
7
8 Radiance is OpenSource software copyrighted and distributed by
9 Lawrence Berkeley National Laboratory in California. By downloading
10 and installing this software, you are implicitly agreeing to the
11 OpenSource license appended to this README file. Please read it
12 carefully before proceeding -- this is very different from previous
13 licenses, and contains fewer restrictions on commercialization.
14
15 Please read this entire file before sending e-mail asking
16 how to install this software or what to do with it. Some
17 frequently asked questions are answered here and also on our
18 web site at:
19
20 http://radsite.lbl.gov/radiance/
21
22 The website above should also have some precompiled Radiance binaries
23 and add-ons for common Unix platforms.
24
25 We have attempted to make it easy for you (and for us) to install
26 the software on differently configured systems using a global make
27 script. To install the software, just type:
28
29 makeall install
30
31 You can clean up the .o files and so forth with:
32
33 makeall clean
34
35 Or, if you are confident you can do both at the same time with:
36
37 makeall install clean
38
39 You can give other make options at the end of the command as well. For
40 example, the -n option will tell you what makeall is going to do without
41 actually doing it.
42
43 If you downloaded the binaries, so compilation is not necessary,
44 run the following command to install the library files only:
45
46 makeall library
47
48 The makeall may script ask you questions about your system and where you
49 want to install the executables and library files. The pathnames you
50 give should be relative to root for the programs to work properly. You
51 may also use the tilde ('~') character to give paths starting with
52 someone's home directory.
53
54 If you do NOT have X11 support, please read the note "noX11.help" in
55 this directory. It explains what to change to make things work.
56
57 Although it is set automatically by makeall, individuals may want to
58 set the RAYPATH environment variable manually. This variable tells
59 Radiance where to look for auxiliary files, and usually includes the
60 current directory as well as the system library (ray/lib in this
61 distribution). As you develop auxiliary files yourself, it is often
62 useful to add in your own library directory before the system directory.
63 An example setting such as this would go in a user's .login file:
64
65 setenv RAYPATH .:${HOME}/mylib:/usr/local/lib/ray
66
67 After installing the software, you may want to start by scanning the
68 troff input documentation contained in "doc/ray.1", which is also formatted
69 for web browsers in "doc/ray.html".
70 A PDF version of this manual may be found in
71 "doc/pdf/ray.pdf", along with an older tutorial by Cindy Larson,
72 "doc/pdf/raduser1_6.pdf".
73
74 For complete documentation on the system as of release 3.1, refer to
75 "Rendering with Radiance" by Larson and Shakespeare, which used to be
76 available from Morgan Kauffman Publishing. Unfortunately, the book has
77 gone out of print, and the authors are currently looking at alternative
78 means of distribution. The first chapter of this book, which includes
79 a basic tutorial and serves as a good introduction for new users, may be
80 found in "doc/pdf/RwR01.pdf". Keep tuned to the radiance website
81 for updates on the full book's availability.
82
83 Important additions since version 3.1 include the holodeck programs (rholo,
84 etc., built in src/hd), glrad, ranimove, and the new "mesh" primitive,
85 suported by obj2mesh.
86
87 Individual manual pages may be found in the subdirectory "doc/man".
88 You may want to copy these to the system manual directory, or add this
89 directory to your MANPATH environment variable in your shell
90 initialization file. A good starting place is to print the text file
91 ray/doc/man/whatis, which gives a one line description of each program in
92 the Radiance package. To print out the manual pages, use the "-man"
93 macro package.
94
95 The most important program to learn about if you are a new user of Radiance
96 (or have not used this program before) is "rad". It controls Radiance
97 lighting parameters, and automates much of the rendering process.
98 To get started, change directory to obj/misc and try running:
99
100 % rad -o x11 daf.rif
101
102 This works if you are running X11. If you are not, you can still generate
103 an image with:
104
105 % rad daf.rif &
106
107 When the picture is done, you can convert it to another format for display
108 with any of the ra_* programs listed in the doc/whatis database.
109
110 There is a user interface built on top of this using Tcl/Tk, called trad.
111 If you do not have Tcl/Tk installed on your system, you must do so prior
112 to building this distribution if you ant trad to install. (Try a google
113 search on "Tcl/Tk" or go to "http://www.scriptics.com/software/tcltk/".)
114
115 If you have a question, you might start by looking in the Radiance Digest
116 archives, accessible from the Radiance web site. For current issues and
117 problems with this release, go to the radiance-online list at:
118
119 http://www.radiance-online.org
120
121 ----------------------------------------------------------------------
122 The Radiance Software License, Version 1.0
123
124 Copyright (c) 1990 - 2002 The Regents of the University of California,
125 through Lawrence Berkeley National Laboratory. All rights reserved.
126
127 Redistribution and use in source and binary forms, with or without
128 modification, are permitted provided that the following conditions
129 are met:
130
131 1. Redistributions of source code must retain the above copyright
132 notice, this list of conditions and the following disclaimer.
133
134 2. Redistributions in binary form must reproduce the above copyright
135 notice, this list of conditions and the following disclaimer in
136 the documentation and/or other materials provided with the
137 distribution.
138
139 3. The end-user documentation included with the redistribution,
140 if any, must include the following acknowledgment:
141 "This product includes Radiance software
142 (http://radsite.lbl.gov/)
143 developed by the Lawrence Berkeley National Laboratory
144 (http://www.lbl.gov/)."
145 Alternately, this acknowledgment may appear in the software itself,
146 if and wherever such third-party acknowledgments normally appear.
147
148 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
149 and "The Regents of the University of California" must
150 not be used to endorse or promote products derived from this
151 software without prior written permission. For written
152 permission, please contact [email protected].
153
154 5. Products derived from this software may not be called "Radiance",
155 nor may "Radiance" appear in their name, without prior written
156 permission of Lawrence Berkeley National Laboratory.
157
158 THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
159 WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
160 OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
161 DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
162 ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
163 SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
164 LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
165 USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
166 ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
167 OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
168 OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
169 SUCH DAMAGE.
170 ====================================================================
171
172 This software consists of voluntary contributions made by many
173 individuals on behalf of Lawrence Berkeley National Laboratory. For more
174 information on Lawrence Berkeley National Laboratory, please see
175 <http://www.lbl.gov/>.
176
