1 |
RCSid "$Id" |
2 |
3 |
Hello and welcome to the Radiance synthetic imaging system. This is |
4 |
the thirteenth release, Version 3.5, and it includes all source files |
5 |
for local compilation with a standard C compiler. To find out what's |
6 |
new in this release, check the text file "doc/notes/ReleaseNotes". |
7 |
8 |
Radiance is OpenSource software copyrighted and distributed by |
9 |
Lawrence Berkeley National Laboratory in California. By downloading |
10 |
and installing this software, you are implicitly agreeing to the |
11 |
OpenSource license appended to this README file. Please read it |
12 |
carefully before proceeding -- this is very different from previous |
13 |
licenses, and contains fewer restrictions on commercialization. |
14 |
15 |
Please read this entire file before sending e-mail asking |
16 |
how to install this software or what to do with it. Some |
17 |
frequently asked questions are answered here and also on our |
18 |
web site at: |
19 |
20 |
http://radsite.lbl.gov/radiance/ |
21 |
22 |
The website above should also have some precompiled Radiance binaries |
23 |
and add-ons for common Unix platforms. |
24 |
25 |
We have attempted to make it easy for you (and for us) to install |
26 |
the software on differently configured systems using a global make |
27 |
script. To install the software, just type: |
28 |
29 |
makeall install |
30 |
31 |
You can clean up the .o files and so forth with: |
32 |
33 |
makeall clean |
34 |
35 |
Or, if you are confident you can do both at the same time with: |
36 |
37 |
makeall install clean |
38 |
39 |
You can give other make options at the end of the command as well. For |
40 |
example, the -n option will tell you what makeall is going to do without |
41 |
actually doing it. |
42 |
43 |
If you downloaded the binaries, so compilation is not necessary, |
44 |
run the following command to install the library files only: |
45 |
46 |
makeall library |
47 |
48 |
The makeall may script ask you questions about your system and where you |
49 |
want to install the executables and library files. The pathnames you |
50 |
give should be relative to root for the programs to work properly. You |
51 |
may also use the tilde ('~') character to give paths starting with |
52 |
someone's home directory. |
53 |
54 |
If you do NOT have X11 support, please read the note "noX11.help" in |
55 |
this directory. It explains what to change to make things work. |
56 |
57 |
Although it is set automatically by makeall, individuals may want to |
58 |
set the RAYPATH environment variable manually. This variable tells |
59 |
Radiance where to look for auxiliary files, and usually includes the |
60 |
current directory as well as the system library (ray/lib in this |
61 |
distribution). As you develop auxiliary files yourself, it is often |
62 |
useful to add in your own library directory before the system directory. |
63 |
An example setting such as this would go in a user's .login file: |
64 |
65 |
setenv RAYPATH .:${HOME}/mylib:/usr/local/lib/ray |
66 |
67 |
After installing the software, you may want to start by scanning the |
68 |
troff input documentation contained in "doc/ray.1", which is also formatted |
69 |
for web browsers in "doc/ray.html". |
70 |
A PDF version of this manual may be found in |
71 |
"doc/pdf/ray.pdf", along with an older tutorial by Cindy Larson, |
72 |
"doc/pdf/raduser1_6.pdf". |
73 |
74 |
For complete documentation on the system as of release 3.1, refer to |
75 |
"Rendering with Radiance" by Larson and Shakespeare, which used to be |
76 |
available from Morgan Kauffman Publishing. Unfortunately, the book has |
77 |
gone out of print, and the authors are currently looking at alternative |
78 |
means of distribution. The first chapter of this book, which includes |
79 |
a basic tutorial and serves as a good introduction for new users, may be |
80 |
found in "doc/pdf/RwR01.pdf". Keep tuned to the radiance website |
81 |
for updates on the full book's availability. |
82 |
83 |
Important additions since version 3.1 include the holodeck programs (rholo, |
84 |
etc., built in src/hd), glrad, ranimove, and the new "mesh" primitive, |
85 |
suported by obj2mesh. |
86 |
87 |
Individual manual pages may be found in the subdirectory "doc/man". |
88 |
You may want to copy these to the system manual directory, or add this |
89 |
directory to your MANPATH environment variable in your shell |
90 |
initialization file. A good starting place is to print the text file |
91 |
ray/doc/man/whatis, which gives a one line description of each program in |
92 |
the Radiance package. To print out the manual pages, use the "-man" |
93 |
macro package. |
94 |
95 |
The most important program to learn about if you are a new user of Radiance |
96 |
(or have not used this program before) is "rad". It controls Radiance |
97 |
lighting parameters, and automates much of the rendering process. |
98 |
To get started, change directory to obj/misc and try running: |
99 |
100 |
% rad -o x11 daf.rif |
101 |
102 |
This works if you are running X11. If you are not, you can still generate |
103 |
an image with: |
104 |
105 |
% rad daf.rif & |
106 |
107 |
When the picture is done, you can convert it to another format for display |
108 |
with any of the ra_* programs listed in the doc/whatis database. |
109 |
110 |
There is a user interface built on top of this using Tcl/Tk, called trad. |
111 |
If you do not have Tcl/Tk installed on your system, you must do so prior |
112 |
to building this distribution if you ant trad to install. (Try a google |
113 |
search on "Tcl/Tk" or go to "http://www.scriptics.com/software/tcltk/".) |
114 |
115 |
If you have a question, you might start by looking in the Radiance Digest |
116 |
archives, accessible from the Radiance web site. For current issues and |
117 |
problems with this release, go to the radiance-online list at: |
118 |
119 |
http://www.radiance-online.org |
120 |
121 |
122 |
The Radiance Software License, Version 1.0 |
123 |
124 |
Copyright (c) 1990 - 2002 The Regents of the University of California, |
125 |
through Lawrence Berkeley National Laboratory. All rights reserved. |
126 |
127 |
Redistribution and use in source and binary forms, with or without |
128 |
modification, are permitted provided that the following conditions |
129 |
are met: |
130 |
131 |
1. Redistributions of source code must retain the above copyright |
132 |
notice, this list of conditions and the following disclaimer. |
133 |
134 |
2. Redistributions in binary form must reproduce the above copyright |
135 |
notice, this list of conditions and the following disclaimer in |
136 |
the documentation and/or other materials provided with the |
137 |
distribution. |
138 |
139 |
3. The end-user documentation included with the redistribution, |
140 |
if any, must include the following acknowledgment: |
141 |
"This product includes Radiance software |
142 |
(http://radsite.lbl.gov/) |
143 |
developed by the Lawrence Berkeley National Laboratory |
144 |
(http://www.lbl.gov/)." |
145 |
Alternately, this acknowledgment may appear in the software itself, |
146 |
if and wherever such third-party acknowledgments normally appear. |
147 |
148 |
4. The names "Radiance," "Lawrence Berkeley National Laboratory" |
149 |
and "The Regents of the University of California" must |
150 |
not be used to endorse or promote products derived from this |
151 |
software without prior written permission. For written |
152 |
permission, please contact [email protected]. |
153 |
154 |
5. Products derived from this software may not be called "Radiance", |
155 |
nor may "Radiance" appear in their name, without prior written |
156 |
permission of Lawrence Berkeley National Laboratory. |
157 |
158 |
THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED |
159 |
WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES |
160 |
OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE |
161 |
DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR |
162 |
ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, |
163 |
SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT |
164 |
LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF |
165 |
USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND |
166 |
ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, |
167 |
OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT |
168 |
OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF |
169 |
SUCH DAMAGE. |
170 |
171 |
172 |
This software consists of voluntary contributions made by many |
173 |
individuals on behalf of Lawrence Berkeley National Laboratory. For more |
174 |
information on Lawrence Berkeley National Laboratory, please see |
175 |
<http://www.lbl.gov/>. |
176 |
