| 1 |
greg |
1.4 |
RCSid "$Id$"
| 2 |
greg |
1.1 |
| 3 |
Hello and welcome to the Radiance synthetic imaging system. This is
| 4 |
greg |
1.3 |
the thirteenth release, Version 3.6, and it includes all source files
| 5 |
greg |
1.1 |
for local compilation with a standard C compiler. To find out what's
| 6 |
new in this release, check the text file "doc/notes/ReleaseNotes".
| 7 |
| 8 |
Radiance is OpenSource software copyrighted and distributed by
| 9 |
Lawrence Berkeley National Laboratory in California. By downloading
| 10 |
and installing this software, you are implicitly agreeing to the
| 11 |
OpenSource license appended to this README file. Please read it
| 12 |
carefully before proceeding -- this is very different from previous
| 13 |
licenses, and contains fewer restrictions on commercialization.
| 14 |
| 15 |
Please read this entire file before sending e-mail asking
| 16 |
how to install this software or what to do with it. Some
| 17 |
frequently asked questions are answered here and also on our
| 18 |
web site at:
| 19 |
| 20 |
http://radsite.lbl.gov/radiance/
| 21 |
| 22 |
greg |
1.4 |
The CVS source tree is available, including post-release bug-fixes and
| 23 |
mailing lists access at:
| 24 |
| 25 |
http://www.radiance-online.org/
| 26 |
| 27 |
The websites above should also have some precompiled Radiance binaries
| 28 |
greg |
1.1 |
and add-ons for common Unix platforms.
| 29 |
| 30 |
We have attempted to make it easy for you (and for us) to install
| 31 |
the software on differently configured systems using a global make
| 32 |
script. To install the software, just type:
| 33 |
| 34 |
greg |
1.2 |
./makeall install
| 35 |
greg |
1.1 |
| 36 |
You can clean up the .o files and so forth with:
| 37 |
| 38 |
greg |
1.2 |
./makeall clean
| 39 |
greg |
1.1 |
| 40 |
Or, if you are confident you can do both at the same time with:
| 41 |
| 42 |
greg |
1.2 |
./makeall install clean
| 43 |
greg |
1.1 |
| 44 |
You can give other make options at the end of the command as well. For
| 45 |
example, the -n option will tell you what makeall is going to do without
| 46 |
actually doing it.
| 47 |
| 48 |
If you downloaded the binaries, so compilation is not necessary,
| 49 |
run the following command to install the library files only:
| 50 |
| 51 |
greg |
1.2 |
./makeall library
| 52 |
greg |
1.1 |
| 53 |
The makeall may script ask you questions about your system and where you
| 54 |
want to install the executables and library files. The pathnames you
| 55 |
give should be relative to root for the programs to work properly. You
| 56 |
may also use the tilde ('~') character to give paths starting with
| 57 |
someone's home directory.
| 58 |
| 59 |
If you do NOT have X11 support, please read the note "noX11.help" in
| 60 |
this directory. It explains what to change to make things work.
| 61 |
| 62 |
Although it is set automatically by makeall, individuals may want to
| 63 |
set the RAYPATH environment variable manually. This variable tells
| 64 |
Radiance where to look for auxiliary files, and usually includes the
| 65 |
current directory as well as the system library (ray/lib in this
| 66 |
distribution). As you develop auxiliary files yourself, it is often
| 67 |
useful to add in your own library directory before the system directory.
| 68 |
An example setting such as this would go in a user's .login file:
| 69 |
| 70 |
setenv RAYPATH .:${HOME}/mylib:/usr/local/lib/ray
| 71 |
| 72 |
After installing the software, you may want to start by scanning the
| 73 |
troff input documentation contained in "doc/ray.1", which is also formatted
| 74 |
for web browsers in "doc/ray.html".
| 75 |
A PDF version of this manual may be found in
| 76 |
"doc/pdf/ray.pdf", along with an older tutorial by Cindy Larson,
| 77 |
"doc/pdf/raduser1_6.pdf".
| 78 |
| 79 |
For complete documentation on the system as of release 3.1, refer to
| 80 |
"Rendering with Radiance" by Larson and Shakespeare, which used to be
| 81 |
greg |
1.3 |
available from Morgan Kauffman Publishing. Recently, the authors have
| 82 |
taken over printing of the book, which is now available from booksurge.com.
| 83 |
You may find it linked to the Radiance website page:
| 84 |
| 85 |
http://radsite.lbl.gov/radiance/book/
| 86 |
| 87 |
The first chapter of this book, which includes a basic tutorial and
| 88 |
serves as a good introduction for new users, may be found in
| 89 |
"doc/pdf/RwR01.pdf".
| 90 |
greg |
1.1 |
| 91 |
Important additions since version 3.1 include the holodeck programs (rholo,
| 92 |
etc., built in src/hd), glrad, ranimove, and the new "mesh" primitive,
| 93 |
suported by obj2mesh.
| 94 |
| 95 |
Individual manual pages may be found in the subdirectory "doc/man".
| 96 |
You may want to copy these to the system manual directory, or add this
| 97 |
directory to your MANPATH environment variable in your shell
| 98 |
initialization file. A good starting place is to print the text file
| 99 |
ray/doc/man/whatis, which gives a one line description of each program in
| 100 |
the Radiance package. To print out the manual pages, use the "-man"
| 101 |
macro package.
| 102 |
| 103 |
The most important program to learn about if you are a new user of Radiance
| 104 |
(or have not used this program before) is "rad". It controls Radiance
| 105 |
lighting parameters, and automates much of the rendering process.
| 106 |
To get started, change directory to obj/misc and try running:
| 107 |
| 108 |
% rad -o x11 daf.rif
| 109 |
| 110 |
This works if you are running X11. If you are not, you can still generate
| 111 |
an image with:
| 112 |
| 113 |
% rad daf.rif &
| 114 |
| 115 |
When the picture is done, you can convert it to another format for display
| 116 |
with any of the ra_* programs listed in the doc/whatis database.
| 117 |
| 118 |
There is a user interface built on top of this using Tcl/Tk, called trad.
| 119 |
If you do not have Tcl/Tk installed on your system, you must do so prior
| 120 |
to building this distribution if you ant trad to install. (Try a google
| 121 |
search on "Tcl/Tk" or go to "http://www.scriptics.com/software/tcltk/".)
| 122 |
| 123 |
| 124 |
The Radiance Software License, Version 1.0
| 125 |
| 126 |
Copyright (c) 1990 - 2002 The Regents of the University of California,
| 127 |
through Lawrence Berkeley National Laboratory. All rights reserved.
| 128 |
| 129 |
Redistribution and use in source and binary forms, with or without
| 130 |
modification, are permitted provided that the following conditions
| 131 |
are met:
| 132 |
| 133 |
1. Redistributions of source code must retain the above copyright
| 134 |
notice, this list of conditions and the following disclaimer.
| 135 |
| 136 |
2. Redistributions in binary form must reproduce the above copyright
| 137 |
notice, this list of conditions and the following disclaimer in
| 138 |
the documentation and/or other materials provided with the
| 139 |
distribution.
| 140 |
| 141 |
3. The end-user documentation included with the redistribution,
| 142 |
if any, must include the following acknowledgment:
| 143 |
"This product includes Radiance software
| 144 |
(http://radsite.lbl.gov/)
| 145 |
developed by the Lawrence Berkeley National Laboratory
| 146 |
(http://www.lbl.gov/)."
| 147 |
Alternately, this acknowledgment may appear in the software itself,
| 148 |
if and wherever such third-party acknowledgments normally appear.
| 149 |
| 150 |
4. The names "Radiance," "Lawrence Berkeley National Laboratory"
| 151 |
and "The Regents of the University of California" must
| 152 |
not be used to endorse or promote products derived from this
| 153 |
software without prior written permission. For written
| 154 |
permission, please contact [email protected].
| 155 |
| 156 |
5. Products derived from this software may not be called "Radiance",
| 157 |
nor may "Radiance" appear in their name, without prior written
| 158 |
permission of Lawrence Berkeley National Laboratory.
| 159 |
| 160 |
THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
| 161 |
WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
| 162 |
OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
| 163 |
DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
| 164 |
ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
| 165 |
SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
| 166 |
LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
| 167 |
USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
| 168 |
ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
| 169 |
OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
| 170 |
OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
| 171 |
SUCH DAMAGE.
| 172 |
| 173 |
| 174 |
This software consists of voluntary contributions made by many
| 175 |
individuals on behalf of Lawrence Berkeley National Laboratory. For more
| 176 |
information on Lawrence Berkeley National Laboratory, please see
| 177 |
<http://www.lbl.gov/>.
| 178 |
