| 1 |
greg |
1.10 |
RCSid "$Id: README,v 1.9 2011/10/27 00:51:29 greg Exp $"
| 2 |
greg |
1.1 |
| 3 |
Hello and welcome to the Radiance synthetic imaging system. This is
| 4 |
greg |
1.9 |
the eighteenth release, Version 4.1, and it includes all source files
| 5 |
greg |
1.1 |
for local compilation with a standard C compiler. To find out what's
| 6 |
new in this release, check the text file "doc/notes/ReleaseNotes".
| 7 |
| 8 |
Radiance is OpenSource software copyrighted and distributed by
| 9 |
Lawrence Berkeley National Laboratory in California. By downloading
| 10 |
and installing this software, you are implicitly agreeing to the
| 11 |
OpenSource license appended to this README file. Please read it
| 12 |
carefully before proceeding -- this is very different from previous
| 13 |
licenses, and contains fewer restrictions on commercialization.
| 14 |
| 15 |
Please read this entire file before sending e-mail asking
| 16 |
how to install this software or what to do with it. Some
| 17 |
frequently asked questions are answered here and also on our
| 18 |
greg |
1.6 |
website at:
| 19 |
greg |
1.1 |
| 20 |
http://radsite.lbl.gov/radiance/
| 21 |
| 22 |
greg |
1.4 |
The CVS source tree is available, including post-release bug-fixes and
| 23 |
mailing lists access at:
| 24 |
| 25 |
http://www.radiance-online.org/
| 26 |
| 27 |
The websites above should also have some precompiled Radiance binaries
| 28 |
greg |
1.1 |
and add-ons for common Unix platforms.
| 29 |
| 30 |
We have attempted to make it easy for you (and for us) to install
| 31 |
the software on differently configured systems using a global make
| 32 |
script. To install the software, just type:
| 33 |
| 34 |
greg |
1.2 |
./makeall install
| 35 |
greg |
1.1 |
| 36 |
You can clean up the .o files and so forth with:
| 37 |
| 38 |
greg |
1.2 |
./makeall clean
| 39 |
greg |
1.1 |
| 40 |
Or, if you are confident you can do both at the same time with:
| 41 |
| 42 |
greg |
1.2 |
./makeall install clean
| 43 |
greg |
1.1 |
| 44 |
You can give other make options at the end of the command as well. For
| 45 |
example, the -n option will tell you what makeall is going to do without
| 46 |
actually doing it.
| 47 |
| 48 |
If you downloaded the binaries, so compilation is not necessary,
| 49 |
run the following command to install the library files only:
| 50 |
| 51 |
greg |
1.2 |
./makeall library
| 52 |
greg |
1.1 |
| 53 |
The makeall may script ask you questions about your system and where you
| 54 |
want to install the executables and library files. The pathnames you
| 55 |
give should be relative to root for the programs to work properly. You
| 56 |
may also use the tilde ('~') character to give paths starting with
| 57 |
someone's home directory.
| 58 |
| 59 |
If you do NOT have X11 support, please read the note "noX11.help" in
| 60 |
this directory. It explains what to change to make things work.
| 61 |
| 62 |
Although it is set automatically by makeall, individuals may want to
| 63 |
set the RAYPATH environment variable manually. This variable tells
| 64 |
Radiance where to look for auxiliary files, and usually includes the
| 65 |
current directory as well as the system library (ray/lib in this
| 66 |
distribution). As you develop auxiliary files yourself, it is often
| 67 |
useful to add in your own library directory before the system directory.
| 68 |
An example setting such as this would go in a user's .login file:
| 69 |
| 70 |
setenv RAYPATH .:${HOME}/mylib:/usr/local/lib/ray
| 71 |
| 72 |
After installing the software, you may want to start by scanning the
| 73 |
troff input documentation contained in "doc/ray.1", which is also formatted
| 74 |
for web browsers in "doc/ray.html".
| 75 |
A PDF version of this manual may be found in
| 76 |
"doc/pdf/ray.pdf", along with an older tutorial by Cindy Larson,
| 77 |
"doc/pdf/raduser1_6.pdf".
| 78 |
| 79 |
For complete documentation on the system as of release 3.1, refer to
| 80 |
"Rendering with Radiance" by Larson and Shakespeare, which used to be
| 81 |
greg |
1.3 |
available from Morgan Kauffman Publishing. Recently, the authors have
| 82 |
taken over printing of the book, which is now available from booksurge.com.
| 83 |
You may find it linked to the Radiance website page:
| 84 |
| 85 |
http://radsite.lbl.gov/radiance/book/
| 86 |
| 87 |
The first chapter of this book, which includes a basic tutorial and
| 88 |
serves as a good introduction for new users, may be found in
| 89 |
"doc/pdf/RwR01.pdf".
| 90 |
greg |
1.1 |
| 91 |
Important additions since version 3.1 include the holodeck programs (rholo,
| 92 |
greg |
1.5 |
etc., built in src/hd), glrad, ranimove, the new "mesh" primitive,
| 93 |
and rtcontrib. Again, check doc/notes/ReleaseNotes for details.
| 94 |
greg |
1.1 |
| 95 |
Individual manual pages may be found in the subdirectory "doc/man".
| 96 |
You may want to copy these to the system manual directory, or add this
| 97 |
directory to your MANPATH environment variable in your shell
| 98 |
initialization file. A good starting place is to print the text file
| 99 |
ray/doc/man/whatis, which gives a one line description of each program in
| 100 |
the Radiance package. To print out the manual pages, use the "-man"
| 101 |
macro package.
| 102 |
| 103 |
The most important program to learn about if you are a new user of Radiance
| 104 |
(or have not used this program before) is "rad". It controls Radiance
| 105 |
lighting parameters, and automates much of the rendering process.
| 106 |
To get started, change directory to obj/misc and try running:
| 107 |
| 108 |
% rad -o x11 daf.rif
| 109 |
| 110 |
This works if you are running X11. If you are not, you can still generate
| 111 |
an image with:
| 112 |
| 113 |
% rad daf.rif &
| 114 |
| 115 |
When the picture is done, you can convert it to another format for display
| 116 |
with any of the ra_* programs listed in the doc/whatis database.
| 117 |
| 118 |
There is a user interface built on top of this using Tcl/Tk, called trad.
| 119 |
If you do not have Tcl/Tk installed on your system, you must do so prior
| 120 |
greg |
1.7 |
to building this distribution if you want trad to install. (Try a google
| 121 |
greg |
1.1 |
search on "Tcl/Tk" or go to "http://www.scriptics.com/software/tcltk/".)
