1 |
RCSid "$Id: README.txt,v 1.4 2017/08/19 14:16:15 greg Exp $" |
2 |
3 |
Hello and welcome to the Radiance synthetic imaging system. This is |
4 |
the twenty-third release, Version 5.2, and it includes all source files |
5 |
for local compilation with a standard C compiler. To find out what's |
6 |
new in this release, check the text file "doc/notes/ReleaseNotes". |
7 |
8 |
Radiance is OpenSource software copyrighted and distributed by |
9 |
Lawrence Berkeley National Laboratory in California. By downloading |
10 |
and installing this software, you are implicitly agreeing to the |
11 |
OpenSource license appended to this README file. Please read it |
12 |
carefully before proceeding -- this is very different from previous |
13 |
licenses, and contains fewer restrictions on commercialization. |
14 |
15 |
Please read this entire file before sending e-mail asking |
16 |
how to install this software or what to do with it. Some |
17 |
frequently asked questions are answered here and also on our |
18 |
website at: |
19 |
20 |
http://radsite.lbl.gov/radiance/ |
21 |
22 |
The CVS source tree is available, including post-release bug-fixes and |
23 |
mailing lists access at: |
24 |
25 |
http://www.radiance-online.org/ |
26 |
27 |
The websites above should also have some precompiled Radiance binaries |
28 |
and add-ons for common Unix platforms. |
29 |
30 |
We have attempted to make it easy for you (and for us) to install |
31 |
the software on differently configured systems using a global make |
32 |
script. To install the software, just type: |
33 |
34 |
./makeall install |
35 |
36 |
You can clean up the .o files and so forth with: |
37 |
38 |
./makeall clean |
39 |
40 |
Or, if you are confident you can do both at the same time with: |
41 |
42 |
./makeall install clean |
43 |
44 |
You can give other make options at the end of the command as well. For |
45 |
example, the -n option will tell you what makeall is going to do without |
46 |
actually doing it. |
47 |
48 |
If you downloaded the binaries, so compilation is not necessary, |
49 |
run the following command to install the library files only: |
50 |
51 |
./makeall library |
52 |
53 |
The makeall may script ask you questions about your system and where you |
54 |
want to install the executables and library files. The pathnames you |
55 |
give should be relative to root for the programs to work properly. You |
56 |
may also use the tilde ('~') character to give paths starting with |
57 |
someone's home directory. |
58 |
59 |
If you do NOT have X11 support, please read the note "noX11.help" in |
60 |
this directory. It explains what to change to make things work. |
61 |
62 |
Although it is set automatically by makeall, individuals may want to |
63 |
set the RAYPATH environment variable manually. This variable tells |
64 |
Radiance where to look for auxiliary files, and usually includes the |
65 |
current directory as well as the system library (ray/lib in this |
66 |
distribution). As you develop auxiliary files yourself, it is often |
67 |
useful to add in your own library directory before the system directory. |
68 |
An example setting such as this would go in a user's .login file: |
69 |
70 |
setenv RAYPATH .:${HOME}/mylib:/usr/local/lib/ray |
71 |
72 |
After installing the software, you may want to start by scanning the |
73 |
troff input documentation contained in "doc/ray.1", which is also formatted |
74 |
for web browsers in "doc/ray.html". |
75 |
A PDF version of this manual may be found in |
76 |
"doc/pdf/ray.pdf", along with an older tutorial by Cindy Larson, |
77 |
"doc/pdf/raduser1_6.pdf". |
78 |
79 |
For complete documentation on the system as of release 3.1, refer to |
80 |
"Rendering with Radiance" by Larson and Shakespeare, which used to be |
81 |
available from Morgan Kauffman Publishing. Recently, the authors have |
82 |
taken over printing of the book, which is now available from booksurge.com. |
83 |
You may find it linked to the Radiance website page: |
84 |
85 |
http://radsite.lbl.gov/radiance/book/ |
86 |
87 |
The first chapter of this book, which includes a basic tutorial and |
88 |
serves as a good introduction for new users, may be found in |
89 |
"doc/pdf/RwR01.pdf". |
90 |
91 |
Important additions since version 3.1 include the holodeck programs (rholo, |
92 |
etc., built in src/hd), glrad, ranimove, the new "mesh" primitive, |
93 |
and rtcontrib. Again, check doc/notes/ReleaseNotes for details. |
94 |
95 |
Individual manual pages may be found in the subdirectory "doc/man". |
96 |
You may want to copy these to the system manual directory, or add this |
97 |
directory to your MANPATH environment variable in your shell |
98 |
initialization file. A good starting place is to print the text file |
99 |
ray/doc/man/whatis, which gives a one line description of each program in |
100 |
the Radiance package. To print out the manual pages, use the "-man" |
101 |
macro package. |
102 |
103 |
The most important program to learn about if you are a new user of Radiance |
104 |
(or have not used this program before) is "rad". It controls Radiance |
105 |
lighting parameters, and automates much of the rendering process. |
106 |
To get started, change directory to obj/misc and try running: |
107 |
108 |
% rad -o x11 daf.rif |
109 |
110 |
This works if you are running X11. If you are not, you can still generate |
111 |
an image with: |
112 |
113 |
% rad daf.rif & |
114 |
115 |
When the picture is done, you can convert it to another format for display |
116 |
with any of the ra_* programs listed in the doc/whatis database. |
117 |
118 |
There is a user interface built on top of this using Tcl/Tk, called trad. |
119 |
If you do not have Tcl/Tk installed on your system, you must do so prior |
120 |
to building this distribution if you want trad to install. (Try a google |
121 |
search on "Tcl/Tk" or go to "http://www.scriptics.com/software/tcltk/".) |
