root/radiance/ray/InstallRules/dependencies.cmake.in
Mon Jan 8 16:51:31 2018 UTC (7 years, 2 months ago) by greg
Changes since 1.6: +1 -7 lines
Diff to previous 1.6
Update to CMake build system from Rob G. and Alex S., adding test cases
Thu Aug 17 21:32:29 2017 UTC (7 years, 7 months ago) by greg
Diff to previous 1.5
Final check-ins to get evalglare working and addition of bsdfview -t option
Fri May 8 18:07:38 2015 UTC (9 years, 10 months ago) by greg
Changes since 1.4: +6 -6 lines
Diff to previous 1.4
Fixes for rvu under Windows
Wed Apr 16 20:48:07 2014 UTC (10 years, 11 months ago) by greg
Diff to previous 1.3
Removed objview Ruby script, which is no longer needed for Windows
Wed May 30 18:31:11 2012 UTC (12 years, 9 months ago) by greg
Changes since 1.2: +9 -1 lines
Diff to previous 1.2
Patches to cmake build system and QT driver for rvu
Wed Apr 25 22:21:06 2012 UTC (12 years, 11 months ago) by greg
Diff to previous 1.1
Sat Oct 22 22:38:10 2011 UTC (13 years, 5 months ago) by greg
Added qt interface for rvu and cmake files from Bill Hoffman
