root/radiance/ray/InstallRules/dependencies.cmake.in
Revision: 1.4
Committed: Wed Apr 16 20:48:07 2014 UTC (11 years ago) by greg
CVS Tags: rad4R2P2, rad4R2, rad4R2P1
Removed objview Ruby script, which is no longer needed for Windows
1 if("${CMAKE_VERSION}" VERSION_LESS "2.8.5")
2 # older CMake, add to CMAKE_MODULE_PATH, use local BundleUtilities and GetPrerequisites
3 set(CMAKE_MODULE_PATH "@CMAKE_CURRENT_SOURCE_DIR@" ${CMAKE_MODULE_PATH})
4 endif()
5
6 function(gp_item_default_embedded_path_override path)
7 set(path "@executable_path" PARENT_SCOPE)
8 endfunction()
9
10 include(BundleUtilities)
11
12 set(plugins "")
13 list(APPEND plugins "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/plugins/imageformats/@qgif_plugin@")
14 list(APPEND plugins "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/plugins/imageformats/@qico_plugin@")
15 list(APPEND plugins "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/plugins/imageformats/@qjpeg_plugin@")
16 list(APPEND plugins "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/plugins/imageformats/@qmng_plugin@")
17 list(APPEND plugins "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/plugins/imageformats/@qsvg_plugin@")
18 list(APPEND plugins "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/plugins/imageformats/@qtiff_plugin@")
19
20 fixup_bundle("${CMAKE_INSTALL_PREFIX}/bin/rtrace@CMAKE_EXECUTABLE_SUFFIX@" "${plugins}" "@QT_LIBRARY_DIR@;@X11_LIBRARY_DIR@;@TIFF_LIBRARY_DIRS@")
