root/radiance/ray/InstallRules/GetPrerequisites.cmake
Revision: 1.1
Committed: Sat Oct 22 22:38:10 2011 UTC (13 years, 6 months ago) by greg
CVS Tags: rad4R2P2, rad4R2P1, rad5R1, rad4R2, rad4R1, rad5R0
Added qt interface for rvu and cmake files from Bill Hoffman
1 # - Functions to analyze and list executable file prerequisites.
2 # This module provides functions to list the .dll, .dylib or .so
3 # files that an executable or shared library file depends on. (Its
4 # prerequisites.)
5 #
6 # It uses various tools to obtain the list of required shared library files:
7 # dumpbin (Windows)
8 # ldd (Linux/Unix)
9 # otool (Mac OSX)
10 # The following functions are provided by this module:
11 # get_prerequisites
12 # list_prerequisites
13 # list_prerequisites_by_glob
14 # gp_append_unique
15 # is_file_executable
16 # gp_item_default_embedded_path
17 # (projects can override with gp_item_default_embedded_path_override)
18 # gp_resolve_item
19 # (projects can override with gp_resolve_item_override)
20 # gp_resolved_file_type
21 # (projects can override with gp_resolved_file_type_override)
22 # gp_file_type
23 # Requires CMake 2.6 or greater because it uses function, break, return and
24 # PARENT_SCOPE.
25 #
26 # GET_PREREQUISITES(<target> <prerequisites_var> <exclude_system> <recurse>
27 # <dirs>)
28 # Get the list of shared library files required by <target>. The list in
29 # the variable named <prerequisites_var> should be empty on first entry to
30 # this function. On exit, <prerequisites_var> will contain the list of
31 # required shared library files.
32 #
33 # <target> is the full path to an executable file. <prerequisites_var> is the
34 # name of a CMake variable to contain the results. <exclude_system> must be 0
35 # or 1 indicating whether to include or exclude "system" prerequisites. If
36 # <recurse> is set to 1 all prerequisites will be found recursively, if set to
37 # 0 only direct prerequisites are listed. <exepath> is the path to the top
38 # level executable used for @executable_path replacment on the Mac. <dirs> is
39 # a list of paths where libraries might be found: these paths are searched
40 # first when a target without any path info is given. Then standard system
41 # locations are also searched: PATH, Framework locations, /usr/lib...
42 #
43 # LIST_PREREQUISITES(<target> [<recurse> [<exclude_system> [<verbose>]]])
44 # Print a message listing the prerequisites of <target>.
45 #
46 # <target> is the name of a shared library or executable target or the full
47 # path to a shared library or executable file. If <recurse> is set to 1 all
48 # prerequisites will be found recursively, if set to 0 only direct
49 # prerequisites are listed. <exclude_system> must be 0 or 1 indicating whether
50 # to include or exclude "system" prerequisites. With <verbose> set to 0 only
51 # the full path names of the prerequisites are printed, set to 1 extra
52 # informatin will be displayed.
53 #
54 # LIST_PREREQUISITES_BY_GLOB(<glob_arg> <glob_exp>)
55 # Print the prerequisites of shared library and executable files matching a
56 # globbing pattern. <glob_arg> is GLOB or GLOB_RECURSE and <glob_exp> is a
57 # globbing expression used with "file(GLOB" or "file(GLOB_RECURSE" to retrieve
58 # a list of matching files. If a matching file is executable, its prerequisites
59 # are listed.
60 #
61 # Any additional (optional) arguments provided are passed along as the
62 # optional arguments to the list_prerequisites calls.
63 #
64 # GP_APPEND_UNIQUE(<list_var> <value>)
65 # Append <value> to the list variable <list_var> only if the value is not
66 # already in the list.
67 #
68 # IS_FILE_EXECUTABLE(<file> <result_var>)
69 # Return 1 in <result_var> if <file> is a binary executable, 0 otherwise.
70 #
71 # GP_ITEM_DEFAULT_EMBEDDED_PATH(<item> <default_embedded_path_var>)
72 # Return the path that others should refer to the item by when the item
73 # is embedded inside a bundle.
74 #
75 # Override on a per-project basis by providing a project-specific
76 # gp_item_default_embedded_path_override function.
77 #
78 # GP_RESOLVE_ITEM(<context> <item> <exepath> <dirs> <resolved_item_var>)
79 # Resolve an item into an existing full path file.
80 #
81 # Override on a per-project basis by providing a project-specific
82 # gp_resolve_item_override function.
83 #
84 # GP_RESOLVED_FILE_TYPE(<original_file> <file> <exepath> <dirs> <type_var>)
85 # Return the type of <file> with respect to <original_file>. String
86 # describing type of prerequisite is returned in variable named <type_var>.
87 #
88 # Use <exepath> and <dirs> if necessary to resolve non-absolute <file>
89 # values -- but only for non-embedded items.
90 #
91 # Possible types are:
92 # system
93 # local
94 # embedded
95 # other
96 # Override on a per-project basis by providing a project-specific
97 # gp_resolved_file_type_override function.
98 #
99 # GP_FILE_TYPE(<original_file> <file> <type_var>)
100 # Return the type of <file> with respect to <original_file>. String
101 # describing type of prerequisite is returned in variable named <type_var>.
102 #
103 # Possible types are:
104 # system
105 # local
106 # embedded
107 # other
108
109 #=============================================================================
110 # Copyright 2008-2009 Kitware, Inc.
111 #
112 # Distributed under the OSI-approved BSD License (the "License");
113 # see accompanying file Copyright.txt for details.
114 #
115 # This software is distributed WITHOUT ANY WARRANTY; without even the
116 # implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
117 # See the License for more information.
118 #=============================================================================
119 # (To distribute this file outside of CMake, substitute the full
120 # License text for the above reference.)
121
122 function(gp_append_unique list_var value)
123 set(contains 0)
124
125 foreach(item ${${list_var}})
126 if("${item}" STREQUAL "${value}")
127 set(contains 1)
128 break()
129 endif("${item}" STREQUAL "${value}")
130 endforeach(item)
131
132 if(NOT contains)
133 set(${list_var} ${${list_var}} "${value}" PARENT_SCOPE)
134 endif(NOT contains)
135 endfunction(gp_append_unique)
136
137
138 function(is_file_executable file result_var)
139 #
140 # A file is not executable until proven otherwise:
141 #
142 set(${result_var} 0 PARENT_SCOPE)
143
144 get_filename_component(file_full "${file}" ABSOLUTE)
145 string(TOLOWER "${file_full}" file_full_lower)
146
147 # If file name ends in .exe on Windows, *assume* executable:
148 #
149 if(WIN32 AND NOT UNIX)
150 if("${file_full_lower}" MATCHES "\\.exe$")
151 set(${result_var} 1 PARENT_SCOPE)
152 return()
153 endif("${file_full_lower}" MATCHES "\\.exe$")
154
155 # A clause could be added here that uses output or return value of dumpbin
156 # to determine ${result_var}. In 99%+? practical cases, the exe name
157 # match will be sufficient...
158 #
159 endif(WIN32 AND NOT UNIX)
160
161 # Use the information returned from the Unix shell command "file" to
162 # determine if ${file_full} should be considered an executable file...
163 #
164 # If the file command's output contains "executable" and does *not* contain
165 # "text" then it is likely an executable suitable for prerequisite analysis
166 # via the get_prerequisites macro.
167 #
168 if(UNIX)
169 if(NOT file_cmd)
170 find_program(file_cmd "file")
171 endif(NOT file_cmd)
172
173 if(file_cmd)
174 execute_process(COMMAND "${file_cmd}" "${file_full}"
175 OUTPUT_VARIABLE file_ov
176 OUTPUT_STRIP_TRAILING_WHITESPACE
177 )
178
179 # Replace the name of the file in the output with a placeholder token
180 # (the string " _file_full_ ") so that just in case the path name of
181 # the file contains the word "text" or "executable" we are not fooled
182 # into thinking "the wrong thing" because the file name matches the
183 # other 'file' command output we are looking for...
184 #
185 string(REPLACE "${file_full}" " _file_full_ " file_ov "${file_ov}")
186 string(TOLOWER "${file_ov}" file_ov)
187
188 #message(STATUS "file_ov='${file_ov}'")
189 if("${file_ov}" MATCHES "executable")
190 #message(STATUS "executable!")
191 if("${file_ov}" MATCHES "text")
192 #message(STATUS "but text, so *not* a binary executable!")
193 else("${file_ov}" MATCHES "text")
194 set(${result_var} 1 PARENT_SCOPE)
195 return()
196 endif("${file_ov}" MATCHES "text")
197 endif("${file_ov}" MATCHES "executable")
198 else(file_cmd)
199 message(STATUS "warning: No 'file' command, skipping execute_process...")
200 endif(file_cmd)
201 endif(UNIX)
202 endfunction(is_file_executable)
203
204
205 function(gp_item_default_embedded_path item default_embedded_path_var)
206
207 # On Windows and Linux, "embed" prerequisites in the same directory
208 # as the executable by default:
209 #
210 set(path "@executable_path")
211 set(overridden 0)
212
213 # On the Mac, relative to the executable depending on the type
214 # of the thing we are embedding:
215 #
216 if(APPLE)
217 #
218 # The assumption here is that all executables in the bundle will be
219 # in same-level-directories inside the bundle. The parent directory
220 # of an executable inside the bundle should be MacOS or a sibling of
221 # MacOS and all embedded paths returned from here will begin with
222 # "@executable_path/../" and will work from all executables in all
223 # such same-level-directories inside the bundle.
224 #
225
226 # By default, embed things right next to the main bundle executable:
227 #
228 set(path "@executable_path/../../Contents/MacOS")
229
230 # Embed .dylibs right next to the main bundle executable:
231 #
232 if(item MATCHES "\\.dylib$")
233 set(path "@executable_path/../MacOS")
234 set(overridden 1)
235 endif(item MATCHES "\\.dylib$")
236
237 # Embed frameworks in the embedded "Frameworks" directory (sibling of MacOS):
238 #
239 if(NOT overridden)
240 if(item MATCHES "[^/]+\\.framework/")
241 set(path "@executable_path/../Frameworks")
242 set(overridden 1)
243 endif(item MATCHES "[^/]+\\.framework/")
244 endif(NOT overridden)
245 endif()
246
247 # Provide a hook so that projects can override the default embedded location
248 # of any given library by whatever logic they choose:
249 #
250 if(COMMAND gp_item_default_embedded_path_override)
251 gp_item_default_embedded_path_override("${item}" path)
252 endif(COMMAND gp_item_default_embedded_path_override)
253
254 set(${default_embedded_path_var} "${path}" PARENT_SCOPE)
255 endfunction(gp_item_default_embedded_path)
256
257
258 function(gp_resolve_item context item exepath dirs resolved_item_var)
259 set(resolved 0)
260 set(resolved_item "${item}")
261
262 # Is it already resolved?
263 #
264 if(IS_ABSOLUTE "${resolved_item}" AND EXISTS "${resolved_item}")
265 set(resolved 1)
266 endif(IS_ABSOLUTE "${resolved_item}" AND EXISTS "${resolved_item}")
267
268 if(NOT resolved)
269 if(item MATCHES "@executable_path")
270 #
271 # @executable_path references are assumed relative to exepath
272 #
273 string(REPLACE "@executable_path" "${exepath}" ri "${item}")
274 get_filename_component(ri "${ri}" ABSOLUTE)
275
276 if(EXISTS "${ri}")
277 #message(STATUS "info: embedded item exists (${ri})")
278 set(resolved 1)
279 set(resolved_item "${ri}")
280 else(EXISTS "${ri}")
281 message(STATUS "warning: embedded item does not exist '${ri}'")
282 endif(EXISTS "${ri}")
283 endif(item MATCHES "@executable_path")
284 endif(NOT resolved)
285
286 if(NOT resolved)
287 if(item MATCHES "@loader_path")
288 #
289 # @loader_path references are assumed relative to the
290 # PATH of the given "context" (presumably another library)
291 #
292 get_filename_component(contextpath "${context}" PATH)
293 string(REPLACE "@loader_path" "${contextpath}" ri "${item}")
294 get_filename_component(ri "${ri}" ABSOLUTE)
295
296 if(EXISTS "${ri}")
297 #message(STATUS "info: embedded item exists (${ri})")
298 set(resolved 1)
299 set(resolved_item "${ri}")
300 else(EXISTS "${ri}")
301 message(STATUS "warning: embedded item does not exist '${ri}'")
302 endif(EXISTS "${ri}")
303 endif(item MATCHES "@loader_path")
304 endif(NOT resolved)
305
306 if(NOT resolved)
307 set(ri "ri-NOTFOUND")
308 find_file(ri "${item}" ${exepath} ${dirs} NO_DEFAULT_PATH)
309 find_file(ri "${item}" ${exepath} ${dirs} /usr/lib)
310 if(ri)
311 #message(STATUS "info: 'find_file' in exepath/dirs (${ri})")
312 set(resolved 1)
313 set(resolved_item "${ri}")
314 set(ri "ri-NOTFOUND")
315 endif(ri)
316 endif(NOT resolved)
317
318 if(NOT resolved)
319 if(item MATCHES "[^/]+\\.framework/")
320 set(fw "fw-NOTFOUND")
321 find_file(fw "${item}"
322 "~/Library/Frameworks"
323 "/Library/Frameworks"
324 "/System/Library/Frameworks"
325 )
326 if(fw)
327 #message(STATUS "info: 'find_file' found framework (${fw})")
328 set(resolved 1)
329 set(resolved_item "${fw}")
330 set(fw "fw-NOTFOUND")
331 endif(fw)
332 endif(item MATCHES "[^/]+\\.framework/")
333 endif(NOT resolved)
334
335 # Using find_program on Windows will find dll files that are in the PATH.
336 # (Converting simple file names into full path names if found.)
337 #
338 if(WIN32 AND NOT UNIX)
339 if(NOT resolved)
340 set(ri "ri-NOTFOUND")
341 find_program(ri "${item}" PATHS "${exepath};${dirs}" NO_DEFAULT_PATH)
342 find_program(ri "${item}" PATHS "${exepath};${dirs}")
343 if(ri)
344 #message(STATUS "info: 'find_program' in exepath/dirs (${ri})")
345 set(resolved 1)
346 set(resolved_item "${ri}")
347 set(ri "ri-NOTFOUND")
348 endif(ri)
349 endif(NOT resolved)
350 endif(WIN32 AND NOT UNIX)
351
352 # Provide a hook so that projects can override item resolution
353 # by whatever logic they choose:
354 #
355 if(COMMAND gp_resolve_item_override)
356 gp_resolve_item_override("${context}" "${item}" "${exepath}" "${dirs}" resolved_item resolved)
357 endif(COMMAND gp_resolve_item_override)
358
359 if(NOT resolved)
360 message(STATUS "
361 warning: cannot resolve item '${item}'
362
363 possible problems:
364 need more directories?
365 need to use InstallRequiredSystemLibraries?
366 run in install tree instead of build tree?
367 ")
368 # message(STATUS "
369 #******************************************************************************
370 #warning: cannot resolve item '${item}'
371 #
372 # possible problems:
373 # need more directories?
374 # need to use InstallRequiredSystemLibraries?
375 # run in install tree instead of build tree?
376 #
377 # context='${context}'
378 # item='${item}'
379 # exepath='${exepath}'
380 # dirs='${dirs}'
381 # resolved_item_var='${resolved_item_var}'
382 #******************************************************************************
383 #")
384 endif(NOT resolved)
385
386 set(${resolved_item_var} "${resolved_item}" PARENT_SCOPE)
387 endfunction(gp_resolve_item)
388
389
390 function(gp_resolved_file_type original_file file exepath dirs type_var)
391 #message(STATUS "**")
392
393 if(NOT IS_ABSOLUTE "${original_file}")
394 message(STATUS "warning: gp_resolved_file_type expects absolute full path for first arg original_file")
395 endif()
396
397 set(is_embedded 0)
398 set(is_local 0)
399 set(is_system 0)
400
401 set(resolved_file "${file}")
402
403 if("${file}" MATCHES "^@(executable|loader)_path")
404 set(is_embedded 1)
405 endif()
406
407 if(NOT is_embedded)
408 if(NOT IS_ABSOLUTE "${file}")
409 gp_resolve_item("${original_file}" "${file}" "${exepath}" "${dirs}" resolved_file)
410 endif()
411
412 string(TOLOWER "${original_file}" original_lower)
413 string(TOLOWER "${resolved_file}" lower)
414
415 if(UNIX)
416 if(resolved_file MATCHES "^(/lib/|/lib32/|/lib64/|/usr/lib/|/usr/lib32/|/usr/lib64/|/usr/X11R6/|/usr/bin/)")
417 set(is_system 1)
418 endif()
419 endif()
420
421 if(APPLE)
422 if(resolved_file MATCHES "^(/System/Library/|/usr/lib/)")
423 set(is_system 1)
424 endif()
425 endif()
426
427 if(WIN32)
428 string(TOLOWER "$ENV{SystemRoot}" sysroot)
429 string(REGEX REPLACE "\\\\" "/" sysroot "${sysroot}")
430
431 string(TOLOWER "$ENV{windir}" windir)
432 string(REGEX REPLACE "\\\\" "/" windir "${windir}")
433
434 if(lower MATCHES "^(${sysroot}/sys(tem|wow)|${windir}/sys(tem|wow)|(.*/)*msvc[^/]+dll)")
435 set(is_system 1)
436 endif()
437
438 if(UNIX)
439 # if cygwin, we can get the properly formed windows paths from cygpath
440 find_program(CYGPATH_EXECUTABLE cygpath)
441
442 if(CYGPATH_EXECUTABLE)
443 execute_process(COMMAND ${CYGPATH_EXECUTABLE} -W
444 OUTPUT_VARIABLE env_windir
445 OUTPUT_STRIP_TRAILING_WHITESPACE)
446 execute_process(COMMAND ${CYGPATH_EXECUTABLE} -S
447 OUTPUT_VARIABLE env_sysdir
448 OUTPUT_STRIP_TRAILING_WHITESPACE)
449 string(TOLOWER "${env_windir}" windir)
450 string(TOLOWER "${env_sysdir}" sysroot)
451
452 if(lower MATCHES "^(${sysroot}/sys(tem|wow)|${windir}/sys(tem|wow)|(.*/)*msvc[^/]+dll)")
453 set(is_system 1)
454 endif()
455 endif(CYGPATH_EXECUTABLE)
456 endif(UNIX)
457 endif(WIN32)
458
459 if(NOT is_system)
460 get_filename_component(original_path "${original_lower}" PATH)
461 get_filename_component(path "${lower}" PATH)
462 if("${original_path}" STREQUAL "${path}")
463 set(is_local 1)
464 endif()
465 endif()
466 endif()
467
468 # Return type string based on computed booleans:
469 #
470 set(type "other")
471
472 if(is_system)
473 set(type "system")
474 elseif(is_embedded)
475 set(type "embedded")
476 elseif(is_local)
477 set(type "local")
478 endif()
479
480 #message(STATUS "gp_resolved_file_type: '${file}' '${resolved_file}'")
481 #message(STATUS " type: '${type}'")
482
483 if(NOT is_embedded)
484 if(NOT IS_ABSOLUTE "${resolved_file}")
485 if(lower MATCHES "^msvc[^/]+dll" AND is_system)
486 message(STATUS "info: non-absolute msvc file '${file}' returning type '${type}'")
487 else()
488 message(STATUS "warning: gp_resolved_file_type non-absolute file '${file}' returning type '${type}' -- possibly incorrect")
489 endif()
490 endif()
491 endif()
492
493 # Provide a hook so that projects can override the decision on whether a
494 # library belongs to the system or not by whatever logic they choose:
495 #
496 if(COMMAND gp_resolved_file_type_override)
497 gp_resolved_file_type_override("${resolved_file}" type)
498 endif()
499
500 set(${type_var} "${type}" PARENT_SCOPE)
501
502 #message(STATUS "**")
503 endfunction()
504
505
506 function(gp_file_type original_file file type_var)
507 if(NOT IS_ABSOLUTE "${original_file}")
508 message(STATUS "warning: gp_file_type expects absolute full path for first arg original_file")
509 endif()
510
511 get_filename_component(exepath "${original_file}" PATH)
512
513 set(type "")
514 gp_resolved_file_type("${original_file}" "${file}" "${exepath}" "" type)
515
516 set(${type_var} "${type}" PARENT_SCOPE)
517 endfunction(gp_file_type)
518
519
520 function(get_prerequisites target prerequisites_var exclude_system recurse exepath dirs)
521 set(verbose 0)
522 set(eol_char "E")
523
524 if(NOT IS_ABSOLUTE "${target}")
525 message("warning: target '${target}' is not absolute...")
526 endif(NOT IS_ABSOLUTE "${target}")
527
528 if(NOT EXISTS "${target}")
529 message("warning: target '${target}' does not exist...")
530 endif(NOT EXISTS "${target}")
531
532 # <setup-gp_tool-vars>
533 #
534 # Try to choose the right tool by default. Caller can set gp_tool prior to
535 # calling this function to force using a different tool.
536 #
537 if("${gp_tool}" STREQUAL "")
538 set(gp_tool "ldd")
539 if(APPLE)
540 set(gp_tool "otool")
541 endif(APPLE)
542 if(WIN32 AND NOT UNIX) # This is how to check for cygwin, har!
543 set(gp_tool "dumpbin")
544 endif(WIN32 AND NOT UNIX)
545 endif("${gp_tool}" STREQUAL "")
546
547 set(gp_tool_known 0)
548
549 if("${gp_tool}" STREQUAL "ldd")
550 set(gp_cmd_args "")
551 set(gp_regex "^[\t ]*[^\t ]+ => ([^\t\(]+) .*${eol_char}$")
552 set(gp_regex_error "not found${eol_char}$")
553 set(gp_regex_fallback "^[\t ]*([^\t ]+) => ([^\t ]+).*${eol_char}$")
554 set(gp_regex_cmp_count 1)
555 set(gp_tool_known 1)
556 endif("${gp_tool}" STREQUAL "ldd")
557
558 if("${gp_tool}" STREQUAL "otool")
559 set(gp_cmd_args "-L")
560 set(gp_regex "^\t([^\t]+) \\(compatibility version ([0-9]+.[0-9]+.[0-9]+), current version ([0-9]+.[0-9]+.[0-9]+)\\)${eol_char}$")
561 set(gp_regex_error "")
562 set(gp_regex_fallback "")
563 set(gp_regex_cmp_count 3)
564 set(gp_tool_known 1)
565 endif("${gp_tool}" STREQUAL "otool")
566
567 if("${gp_tool}" STREQUAL "dumpbin")
568 set(gp_cmd_args "/dependents")
569 set(gp_regex "^ ([^ ].*[Dd][Ll][Ll])${eol_char}$")
570 set(gp_regex_error "")
571 set(gp_regex_fallback "")
572 set(gp_regex_cmp_count 1)
573 set(gp_tool_known 1)
574 set(ENV{VS_UNICODE_OUTPUT} "") # Block extra output from inside VS IDE.
575 endif("${gp_tool}" STREQUAL "dumpbin")
576
577 if(NOT gp_tool_known)
578 message(STATUS "warning: gp_tool='${gp_tool}' is an unknown tool...")
579 message(STATUS "CMake function get_prerequisites needs more code to handle '${gp_tool}'")
580 message(STATUS "Valid gp_tool values are dumpbin, ldd and otool.")
581 return()
582 endif(NOT gp_tool_known)
583
584 set(gp_cmd_paths ${gp_cmd_paths}
585 "C:/Program Files/Microsoft Visual Studio 9.0/VC/bin"
586 "C:/Program Files (x86)/Microsoft Visual Studio 9.0/VC/bin"
587 "C:/Program Files/Microsoft Visual Studio 8/VC/BIN"
588 "C:/Program Files (x86)/Microsoft Visual Studio 8/VC/BIN"
589 "C:/Program Files/Microsoft Visual Studio .NET 2003/VC7/BIN"
590 "C:/Program Files (x86)/Microsoft Visual Studio .NET 2003/VC7/BIN"
591 "/usr/local/bin"
592 "/usr/bin"
593 )
594
595 find_program(gp_cmd ${gp_tool} PATHS ${gp_cmd_paths})
596
597 if(NOT gp_cmd)
598 message(STATUS "warning: could not find '${gp_tool}' - cannot analyze prerequisites...")
599 return()
600 endif(NOT gp_cmd)
601
602 if("${gp_tool}" STREQUAL "dumpbin")
603 # When running dumpbin, it also needs the "Common7/IDE" directory in the
604 # PATH. It will already be in the PATH if being run from a Visual Studio
605 # command prompt. Add it to the PATH here in case we are running from a
606 # different command prompt.
607 #
608 get_filename_component(gp_cmd_dir "${gp_cmd}" PATH)
609 get_filename_component(gp_cmd_dlls_dir "${gp_cmd_dir}/../../Common7/IDE" ABSOLUTE)
610 # Use cmake paths as a user may have a PATH element ending with a backslash.
611 # This will escape the list delimiter and create havoc!
612 if(EXISTS "${gp_cmd_dlls_dir}")
613 # only add to the path if it is not already in the path
614 set(gp_found_cmd_dlls_dir 0)
615 file(TO_CMAKE_PATH "$ENV{PATH}" env_path)
616 foreach(gp_env_path_element ${env_path})
617 if("${gp_env_path_element}" STREQUAL "${gp_cmd_dlls_dir}")
618 set(gp_found_cmd_dlls_dir 1)
619 endif()
620 endforeach(gp_env_path_element)
621
622 if(NOT gp_found_cmd_dlls_dir)
623 file(TO_NATIVE_PATH "${gp_cmd_dlls_dir}" gp_cmd_dlls_dir)
624 set(ENV{PATH} "$ENV{PATH};${gp_cmd_dlls_dir}")
625 endif()
626 endif(EXISTS "${gp_cmd_dlls_dir}")
627 endif("${gp_tool}" STREQUAL "dumpbin")
628 #
629 # </setup-gp_tool-vars>
630
631 if("${gp_tool}" STREQUAL "ldd")
632 set(old_ld_env "$ENV{LD_LIBRARY_PATH}")
633 foreach(dir ${exepath} ${dirs})
634 set(ENV{LD_LIBRARY_PATH} "${dir}:$ENV{LD_LIBRARY_PATH}")
635 endforeach(dir)
636 endif("${gp_tool}" STREQUAL "ldd")
637
638
639 # Track new prerequisites at each new level of recursion. Start with an
640 # empty list at each level:
641 #
642 set(unseen_prereqs)
643
644 # Run gp_cmd on the target:
645 #
646 execute_process(
647 COMMAND ${gp_cmd} ${gp_cmd_args} ${target}
648 OUTPUT_VARIABLE gp_cmd_ov
649 )
650
651 if("${gp_tool}" STREQUAL "ldd")
652 set(ENV{LD_LIBRARY_PATH} "${old_ld_env}")
653 endif("${gp_tool}" STREQUAL "ldd")
654
655 if(verbose)
656 message(STATUS "<RawOutput cmd='${gp_cmd} ${gp_cmd_args} ${target}'>")
657 message(STATUS "gp_cmd_ov='${gp_cmd_ov}'")
658 message(STATUS "</RawOutput>")
659 endif(verbose)
660
661 get_filename_component(target_dir "${target}" PATH)
662
663 # Convert to a list of lines:
664 #
665 string(REGEX REPLACE ";" "\\\\;" candidates "${gp_cmd_ov}")
666 string(REGEX REPLACE "\n" "${eol_char};" candidates "${candidates}")
667
668 # check for install id and remove it from list, since otool -L can include a
669 # reference to itself
670 set(gp_install_id)
671 if("${gp_tool}" STREQUAL "otool")
672 execute_process(
673 COMMAND otool -D ${target}
674 OUTPUT_VARIABLE gp_install_id_ov
675 )
676 # second line is install name
677 string(REGEX REPLACE ".*:\n" "" gp_install_id "${gp_install_id_ov}")
678 if(gp_install_id)
679 # trim
680 string(REGEX MATCH "[^\n ].*[^\n ]" gp_install_id "${gp_install_id}")
681 #message("INSTALL ID is \"${gp_install_id}\"")
682 endif(gp_install_id)
683 endif("${gp_tool}" STREQUAL "otool")
684
685 # Analyze each line for file names that match the regular expression:
686 #
687 foreach(candidate ${candidates})
688 if("${candidate}" MATCHES "${gp_regex}")
689
690 # Extract information from each candidate:
691 if(gp_regex_error AND "${candidate}" MATCHES "${gp_regex_error}")
692 string(REGEX REPLACE "${gp_regex_fallback}" "\\1" raw_item "${candidate}")
693 else(gp_regex_error AND "${candidate}" MATCHES "${gp_regex_error}")
694 string(REGEX REPLACE "${gp_regex}" "\\1" raw_item "${candidate}")
695 endif(gp_regex_error AND "${candidate}" MATCHES "${gp_regex_error}")
696
697 if(gp_regex_cmp_count GREATER 1)
698 string(REGEX REPLACE "${gp_regex}" "\\2" raw_compat_version "${candidate}")
699 string(REGEX REPLACE "^([0-9]+)\\.([0-9]+)\\.([0-9]+)$" "\\1" compat_major_version "${raw_compat_version}")
700 string(REGEX REPLACE "^([0-9]+)\\.([0-9]+)\\.([0-9]+)$" "\\2" compat_minor_version "${raw_compat_version}")
701 string(REGEX REPLACE "^([0-9]+)\\.([0-9]+)\\.([0-9]+)$" "\\3" compat_patch_version "${raw_compat_version}")
702 endif(gp_regex_cmp_count GREATER 1)
703
704 if(gp_regex_cmp_count GREATER 2)
705 string(REGEX REPLACE "${gp_regex}" "\\3" raw_current_version "${candidate}")
706 string(REGEX REPLACE "^([0-9]+)\\.([0-9]+)\\.([0-9]+)$" "\\1" current_major_version "${raw_current_version}")
707 string(REGEX REPLACE "^([0-9]+)\\.([0-9]+)\\.([0-9]+)$" "\\2" current_minor_version "${raw_current_version}")
708 string(REGEX REPLACE "^([0-9]+)\\.([0-9]+)\\.([0-9]+)$" "\\3" current_patch_version "${raw_current_version}")
709 endif(gp_regex_cmp_count GREATER 2)
710
711 # Use the raw_item as the list entries returned by this function. Use the
712 # gp_resolve_item function to resolve it to an actual full path file if
713 # necessary.
714 #
715 set(item "${raw_item}")
716
717 # Add each item unless it is excluded:
718 #
719 set(add_item 1)
720
721 if("${item}" STREQUAL "${gp_install_id}")
722 set(add_item 0)
723 endif("${item}" STREQUAL "${gp_install_id}")
724
725 if(add_item AND ${exclude_system})
726 set(type "")
727 gp_resolved_file_type("${target}" "${item}" "${exepath}" "${dirs}" type)
728
729 if("${type}" STREQUAL "system")
730 set(add_item 0)
731 endif("${type}" STREQUAL "system")
732 endif(add_item AND ${exclude_system})
733
734 if(add_item)
735 list(LENGTH ${prerequisites_var} list_length_before_append)
736 gp_append_unique(${prerequisites_var} "${item}")
737 list(LENGTH ${prerequisites_var} list_length_after_append)
738
739 if(${recurse})
740 # If item was really added, this is the first time we have seen it.
741 # Add it to unseen_prereqs so that we can recursively add *its*
742 # prerequisites...
743 #
744 # But first: resolve its name to an absolute full path name such
745 # that the analysis tools can simply accept it as input.
746 #
747 if(NOT list_length_before_append EQUAL list_length_after_append)
748 gp_resolve_item("${target}" "${item}" "${exepath}" "${dirs}" resolved_item)
749 set(unseen_prereqs ${unseen_prereqs} "${resolved_item}")
750 endif(NOT list_length_before_append EQUAL list_length_after_append)
751 endif(${recurse})
752 endif(add_item)
753 else("${candidate}" MATCHES "${gp_regex}")
754 if(verbose)
755 message(STATUS "ignoring non-matching line: '${candidate}'")
756 endif(verbose)
757 endif("${candidate}" MATCHES "${gp_regex}")
758 endforeach(candidate)
759
760 list(LENGTH ${prerequisites_var} prerequisites_var_length)
761 if(prerequisites_var_length GREATER 0)
762 list(SORT ${prerequisites_var})
763 endif(prerequisites_var_length GREATER 0)
764 if(${recurse})
765 set(more_inputs ${unseen_prereqs})
766 foreach(input ${more_inputs})
767 get_prerequisites("${input}" ${prerequisites_var} ${exclude_system} ${recurse} "${exepath}" "${dirs}")
768 endforeach(input)
769 endif(${recurse})
770
771 set(${prerequisites_var} ${${prerequisites_var}} PARENT_SCOPE)
772 endfunction(get_prerequisites)
773
774
775 function(list_prerequisites target)
776 if("${ARGV1}" STREQUAL "")
777 set(all 1)
778 else("${ARGV1}" STREQUAL "")
779 set(all "${ARGV1}")
780 endif("${ARGV1}" STREQUAL "")
781
782 if("${ARGV2}" STREQUAL "")
783 set(exclude_system 0)
784 else("${ARGV2}" STREQUAL "")
785 set(exclude_system "${ARGV2}")
786 endif("${ARGV2}" STREQUAL "")
787
788 if("${ARGV3}" STREQUAL "")
789 set(verbose 0)
790 else("${ARGV3}" STREQUAL "")
791 set(verbose "${ARGV3}")
792 endif("${ARGV3}" STREQUAL "")
793
794 set(count 0)
795 set(count_str "")
796 set(print_count "${verbose}")
797 set(print_prerequisite_type "${verbose}")
798 set(print_target "${verbose}")
799 set(type_str "")
800
801 get_filename_component(exepath "${target}" PATH)
802
803 set(prereqs "")
804 get_prerequisites("${target}" prereqs ${exclude_system} ${all} "${exepath}" "")
805
806 if(print_target)
807 message(STATUS "File '${target}' depends on:")
808 endif(print_target)
809
810 foreach(d ${prereqs})
811 math(EXPR count "${count} + 1")
812
813 if(print_count)
814 set(count_str "${count}. ")
815 endif(print_count)
816
817 if(print_prerequisite_type)
818 gp_file_type("${target}" "${d}" type)
819 set(type_str " (${type})")
820 endif(print_prerequisite_type)
821
822 message(STATUS "${count_str}${d}${type_str}")
823 endforeach(d)
824 endfunction(list_prerequisites)
825
826
827 function(list_prerequisites_by_glob glob_arg glob_exp)
828 message(STATUS "=============================================================================")
829 message(STATUS "List prerequisites of executables matching ${glob_arg} '${glob_exp}'")
830 message(STATUS "")
831 file(${glob_arg} file_list ${glob_exp})
832 foreach(f ${file_list})
833 is_file_executable("${f}" is_f_executable)
834 if(is_f_executable)
835 message(STATUS "=============================================================================")
836 list_prerequisites("${f}" ${ARGN})
837 message(STATUS "")
838 endif(is_f_executable)
839 endforeach(f)
840 endfunction(list_prerequisites_by_glob)
