root/radiance/ray/InstallRules/CMakeLists.txt
Revision: 1.6
Committed: Fri May 8 18:07:38 2015 UTC (9 years, 11 months ago) by greg
Changes since 1.5: +19 -6 lines
Fixes for rvu under Windows
1 if(X11_FOUND)
2 get_filename_component(X11_LIBRARY_DIR ${X11_X11_LIB} PATH)
3 endif()
4 if(TIFF_LIBRARY)
5 get_filename_component(TIFF_LIBRARY_DIR ${TIFF_LIBRARY} PATH)
6 if(WIN32)
7 #also need the location of libtiff3.dll on Windows.
8 #By default this is ../bin relative to TIFF_LIBRARY_DIR.
9 set(TIFF_BINARY_DIR "${TIFF_LIBRARY_DIR}/../bin")
10 get_filename_component(TIFF_BINARY_DIR "${TIFF_BINARY_DIR}" ABSOLUTE)
11 set(TIFF_LIBRARY_DIRS "${TIFF_LIBRARY_DIR};${TIFF_BINARY_DIR}")
12 else()
13 set(TIFF_LIBRARY_DIRS "${TIFF_LIBRARY_DIR}")
14 endif()
15 endif()
16
17 #plugins loaded by rvu at runtime
18 get_target_property(GIF_PLUGIN Qt5::QGifPlugin LOCATION)
19 get_target_property(ICO_PLUGIN Qt5::QICOPlugin LOCATION)
20 get_target_property(JPEG_PLUGIN Qt5::QJpegPlugin LOCATION)
21 get_target_property(MNG_PLUGIN Qt5::QMngPlugin LOCATION)
22 get_target_property(TIFF_PLUGIN Qt5::QTiffPlugin LOCATION)
23 get_filename_component(GIF_PLUGIN_NAME "${GIF_PLUGIN}" NAME)
24 get_filename_component(ICO_PLUGIN_NAME "${ICO_PLUGIN}" NAME)
25 get_filename_component(JPEG_PLUGIN_NAME "${JPEG_PLUGIN}" NAME)
26 get_filename_component(MNG_PLUGIN_NAME "${MNG_PLUGIN}" NAME)
27 get_filename_component(TIFF_PLUGIN_NAME "${TIFF_PLUGIN}" NAME)
28
29 if(APPLE OR WIN32)
30 if(WIN32)
31 get_target_property(QPA_PLUGIN Qt5::QWindowsIntegrationPlugin LOCATION)
32 elseif(APPLE)
33 get_target_property(QPA_PLUGIN Qt5::QCocoaIntegrationPlugin LOCATION)
34 endif()
35 get_filename_component(QPA_PLUGIN_NAME "${QPA_PLUGIN}" NAME)
36 endif()
37
38 configure_file(
39 "${CMAKE_CURRENT_SOURCE_DIR}/dependencies.cmake.in"
40 "${CMAKE_CURRENT_BINARY_DIR}/dependencies.cmake"
41 @ONLY
42 )
43 install(SCRIPT "${CMAKE_CURRENT_BINARY_DIR}/dependencies.cmake")
44
