root/radiance/ray/InstallRules/CMakeLists.txt
Tue May 16 22:58:18 2023 UTC (23 months, 2 weeks ago) by greg
CVS Tags: HEAD, rad5R4
Diff to previous 1.9
chore: Removed qt from macOS X and Linux builds as it was having issues
Mon Jan 8 16:51:31 2018 UTC (7 years, 3 months ago) by greg
CVS Tags: rad5R2, rad5R3
Changes since 1.8: +8 -14 lines
Diff to previous 1.8
Update to CMake build system from Rob G. and Alex S., adding test cases
Thu Aug 17 21:32:29 2017 UTC (7 years, 8 months ago) by greg
Diff to previous 1.7
Final check-ins to get evalglare working and addition of bsdfview -t option
Tue Mar 22 21:36:24 2016 UTC (9 years, 1 month ago) by greg
Changes since 1.6: +26 -25 lines
Diff to previous 1.6
Rob G. fixes for "headless" target
Fri May 8 18:07:38 2015 UTC (9 years, 11 months ago) by greg
Changes since 1.5: +19 -6 lines
Diff to previous 1.5
Fixes for rvu under Windows
Fri Jun 28 01:10:16 2013 UTC (11 years, 10 months ago) by greg
Changes since 1.4: +6 -6 lines
Diff to previous 1.4
Fixed quotes needed for Windows cmake build
Tue Jun 19 16:41:47 2012 UTC (12 years, 10 months ago) by greg
Changes since 1.3: +6 -6 lines
Diff to previous 1.3
Added missing cmake files
Wed May 30 18:31:11 2012 UTC (12 years, 11 months ago) by greg
Changes since 1.2: +9 -0 lines
Diff to previous 1.2
Patches to cmake build system and QT driver for rvu
Wed Apr 25 22:21:06 2012 UTC (13 years ago) by greg
Changes since 1.1: +15 -0 lines
Diff to previous 1.1
Sat Oct 22 22:38:10 2011 UTC (13 years, 6 months ago) by greg
Added qt interface for rvu and cmake files from Bill Hoffman
