root/radiance/ray/InstallRules/CMakeLists.txt
Revision: 1.5
Committed: Fri Jun 28 01:10:16 2013 UTC (11 years, 10 months ago) by greg
CVS Tags: rad4R2P2, rad4R2, rad4R2P1
Changes since 1.4: +6 -6 lines
Fixed quotes needed for Windows cmake build
1 if(X11_FOUND)
2 get_filename_component(X11_LIBRARY_DIR ${X11_X11_LIB} PATH)
3 endif()
4 if(TIFF_LIBRARY)
5 get_filename_component(TIFF_LIBRARY_DIR ${TIFF_LIBRARY} PATH)
6 if(WIN32)
7 #also need the location of libtiff3.dll on Windows.
8 #By default this is ../bin relative to TIFF_LIBRARY_DIR.
9 set(TIFF_BINARY_DIR "${TIFF_LIBRARY_DIR}/../bin")
10 get_filename_component(TIFF_BINARY_DIR "${TIFF_BINARY_DIR}" ABSOLUTE)
11 set(TIFF_LIBRARY_DIRS "${TIFF_LIBRARY_DIR};${TIFF_BINARY_DIR}")
12 else()
13 set(TIFF_LIBRARY_DIRS "${TIFF_LIBRARY_DIR}")
14 endif()
15 endif()
16
17 #plugins loaded by rvu at runtime
18 get_filename_component(qgif_plugin "${QT_QGIF_${qt_plugin_term}_RELEASE}" NAME)
19 get_filename_component(qico_plugin "${QT_QICO_${qt_plugin_term}_RELEASE}" NAME)
20 get_filename_component(qjpeg_plugin "${QT_QJPEG_${qt_plugin_term}_RELEASE}" NAME)
21 get_filename_component(qmng_plugin "${QT_QMNG_${qt_plugin_term}_RELEASE}" NAME)
22 get_filename_component(qsvg_plugin "${QT_QSVG_${qt_plugin_term}_RELEASE}" NAME)
23 get_filename_component(qtiff_plugin "${QT_QTIFF_${qt_plugin_term}_RELEASE}" NAME)
24
25 configure_file(
26 "${CMAKE_CURRENT_SOURCE_DIR}/dependencies.cmake.in"
27 "${CMAKE_CURRENT_BINARY_DIR}/dependencies.cmake"
28 @ONLY
29 )
30 install(SCRIPT "${CMAKE_CURRENT_BINARY_DIR}/dependencies.cmake")
31
