root/radiance/ray/InstallRules/CMakeLists.txt
Revision: 1.5
Committed: Fri Jun 28 01:10:16 2013 UTC (10 years, 11 months ago) by greg
CVS Tags: rad4R2P2, rad4R2, rad4R2P1
Changes since 1.4: +6 -6 lines
Fixed quotes needed for Windows cmake build
# User Rev Content
1 greg 1.2 if(X11_FOUND)
2     get_filename_component(X11_LIBRARY_DIR ${X11_X11_LIB} PATH)
3     endif()
4     if(TIFF_LIBRARY)
5     get_filename_component(TIFF_LIBRARY_DIR ${TIFF_LIBRARY} PATH)
6     if(WIN32)
7     #also need the location of libtiff3.dll on Windows.
8     #By default this is ../bin relative to TIFF_LIBRARY_DIR.
9     set(TIFF_BINARY_DIR "${TIFF_LIBRARY_DIR}/../bin")
10     get_filename_component(TIFF_BINARY_DIR "${TIFF_BINARY_DIR}" ABSOLUTE)
11     set(TIFF_LIBRARY_DIRS "${TIFF_LIBRARY_DIR};${TIFF_BINARY_DIR}")
12     else()
13     set(TIFF_LIBRARY_DIRS "${TIFF_LIBRARY_DIR}")
14     endif()
15     endif()
16 greg 1.3
17     #plugins loaded by rvu at runtime
18 greg 1.5 get_filename_component(qgif_plugin "${QT_QGIF_${qt_plugin_term}_RELEASE}" NAME)
19     get_filename_component(qico_plugin "${QT_QICO_${qt_plugin_term}_RELEASE}" NAME)
20     get_filename_component(qjpeg_plugin "${QT_QJPEG_${qt_plugin_term}_RELEASE}" NAME)
21     get_filename_component(qmng_plugin "${QT_QMNG_${qt_plugin_term}_RELEASE}" NAME)
22     get_filename_component(qsvg_plugin "${QT_QSVG_${qt_plugin_term}_RELEASE}" NAME)
23     get_filename_component(qtiff_plugin "${QT_QTIFF_${qt_plugin_term}_RELEASE}" NAME)
24 greg 1.3
25 greg 1.1 configure_file(
26     "${CMAKE_CURRENT_SOURCE_DIR}/dependencies.cmake.in"
27     "${CMAKE_CURRENT_BINARY_DIR}/dependencies.cmake"
28     @ONLY
29     )
30     install(SCRIPT "${CMAKE_CURRENT_BINARY_DIR}/dependencies.cmake")
31
