root/radiance/ray/InstallRules/CMakeLists.txt
Revision: 1.10
Committed: Tue May 16 22:58:18 2023 UTC (12 months, 2 weeks ago) by greg
CVS Tags: rad5R4, HEAD
chore: Removed qt from macOS X and Linux builds as it was having issues
1 if(X11_FOUND)
2 get_filename_component(X11_LIBRARY_DIR ${X11_X11_LIB} PATH)
3 endif()
4 if(TIFF_LIBRARY)
5 get_filename_component(TIFF_LIBRARY_DIR ${TIFF_LIBRARY} PATH)
6 if(WIN32)
7 #also need the location of libtiff3.dll on Windows.
8 #By default this is ../bin relative to TIFF_LIBRARY_DIR.
9 set(TIFF_BINARY_DIR "${TIFF_LIBRARY_DIR}/../bin")
10 get_filename_component(TIFF_BINARY_DIR "${TIFF_BINARY_DIR}" ABSOLUTE)
11 set(TIFF_LIBRARY_DIRS "${TIFF_LIBRARY_DIR};${TIFF_BINARY_DIR}")
12 else()
13 set(TIFF_LIBRARY_DIRS "${TIFF_LIBRARY_DIR}")
14 endif()
15 endif()
16
17 if(NOT BUILD_HEADLESS AND BUILD_QT)
18 #plugins loaded by rvu at runtime
19 get_target_property(GIF_PLUGIN Qt5::QGifPlugin LOCATION)
20 get_target_property(ICO_PLUGIN Qt5::QICOPlugin LOCATION)
21 get_target_property(JPEG_PLUGIN Qt5::QJpegPlugin LOCATION)
22 get_target_property(TIFF_PLUGIN Qt5::QTiffPlugin LOCATION)
23 get_filename_component(GIF_PLUGIN_NAME "${GIF_PLUGIN}" NAME)
24 get_filename_component(ICO_PLUGIN_NAME "${ICO_PLUGIN}" NAME)
25 get_filename_component(JPEG_PLUGIN_NAME "${JPEG_PLUGIN}" NAME)
26 get_filename_component(TIFF_PLUGIN_NAME "${TIFF_PLUGIN}" NAME)
27
28 if(WIN32)
29 get_target_property(QPA_PLUGIN Qt5::QWindowsIntegrationPlugin LOCATION)
30 elseif(APPLE)
31 get_target_property(QPA_PLUGIN Qt5::QCocoaIntegrationPlugin LOCATION)
32 elseif(UNIX)
33 get_target_property(QPA_PLUGIN Qt5::QXcbIntegrationPlugin LOCATION)
34 endif()
35 get_filename_component(QPA_PLUGIN_NAME "${QPA_PLUGIN}" NAME)
36
37 configure_file("${CMAKE_CURRENT_SOURCE_DIR}/dependencies.cmake.in" "${CMAKE_CURRENT_BINARY_DIR}/dependencies.cmake" @ONLY)
38 install(SCRIPT "${CMAKE_CURRENT_BINARY_DIR}/dependencies.cmake")
39 endif()
