1 |
schorsch |
1.1 |
Building and Installing Radiance with SCons |
2 |
3 |
4 |
This file describes how to build and install Radiance using the SCons |
5 |
schorsch |
1.6 |
based build system, an alternative to the traditional makeall script |
6 |
explained in the README file. |
7 |
schorsch |
1.1 |
8 |
9 |
Requirements |
10 |
11 |
12 |
Please make sure that you have dowloaded and unpacked BOTH the Radiance |
13 |
schorsch |
1.3 |
source package AND the archive with the auxiliary support files. |
14 |
Crucial parts of the system will be missing if you only have one of |
15 |
them, and SCons will be unable to build the software. |
16 |
schorsch |
1.1 |
17 |
SCons is a platform-independent software configuration and build system |
18 |
written in Python. If SCons and Python are not already installed on your |
19 |
system, then you need to download and install them first. |
20 |
schorsch |
1.6 |
At the time of this writing, all versions of SCons work with Python 2.7. |
21 |
SCons versions from 3.0 up also work with Python 3.x, even if the |
22 |
documentation may still say otherwise. |
23 |
schorsch |
1.1 |
24 |
Python: http://www.python.org/ |
25 |
SCons: http://www.scons.org/ |
26 |
27 |
schorsch |
1.2 |
For many systems, precompiled packages are available, such as Installer |
28 |
schorsch |
1.1 |
files for Windows. Most Linux distributions already come with Python |
29 |
installed and ready to use. |
30 |
31 |
schorsch |
1.4 |
SCons *may* use a libtiff already installed on your system. On posix |
32 |
systems it usually does. Otherwise the executables requiring it are |
33 |
not built. |
34 |
schorsch |
1.1 |
35 |
schorsch |
1.5 |
On Windows, Radiance gets built with MS Visual Studio if present, the |
36 |
schorsch |
1.6 |
free (of cost) community editions are sufficient. |
37 |
Warning: when VS 2015 came out, the new "universal CRT" from Windows 10, |
38 |
which was used at the time, had a bug that corrupts data in text pipes. |
39 |
(Technically, the UCRT is now part of the OS instead of the compiler, |
40 |
so you need to make sure you have a fixed version of the CRT SDK.) |
41 |
Since VS 2017, the "universal CRT" bug is fixed and everyting works fine. |
42 |
schorsch |
1.5 |
43 |
schorsch |
1.1 |
44 |
Building |
45 |
46 |
47 |
For building Radiance, go to the "ray" directory (where this file |
48 |
resides) in a console window and type: |
49 |
50 |
$> scons build |
51 |
52 |
or just |
53 |
54 |
$> scons |
55 |
56 |
The Scons program will find the necessary information, display a |
57 |
schorsch |
1.6 |
copyright message for you to acknowledge (once), and proceed to build |
58 |
the software. |
59 |
schorsch |
1.1 |
60 |
schorsch |
1.6 |
On Windows, the distribution includes a file named "scons.bat", in |
61 |
case the SCons script is not on the system execution path. You may |
62 |
need to change this file to point to your actual Python installation. |
63 |
schorsch |
1.1 |
64 |
schorsch |
1.6 |
All build products are stored under "ray/scbuild/<platform>/", where |
65 |
they are then available for testing and installation. |
66 |
67 |
68 |
Configuration |
69 |
70 |
schorsch |
1.1 |
71 |
In the subdirectory "ray/platform/" there are a number of configuration |
72 |
files for various build environments. In this context, a "platform" is a |
73 |
schorsch |
1.6 |
specific combination of operating system, Memory model (32 or 64 bit), |
74 |
and build tools (eg. compiler). |
75 |
schorsch |
1.1 |
On unix based systems, the compiler usually doesn't make much of a |
76 |
difference, but on Windows, there are seperate build environments for |
77 |
schorsch |
1.4 |
toolkits like MingW. |
78 |
schorsch |
1.1 |
79 |
The file "ray/platform/README" explains the settings that can be |
80 |
configured in those files, and how to create a new one, if you use a |
81 |
platform that isn't supported yet. |
82 |
83 |
84 |
Options |
85 |
86 |
87 |
You can add the following command line options when invoking Scons. |
88 |
The directories given here will override those specified in the |
89 |
configuration file. |
90 |
91 |
schorsch |
1.6 |
RAD_BASEDIR=<directory> |
92 |
The base directory for the installation |
93 |
(Default read from config file, depending on platform) |
94 |
95 |
schorsch |
1.1 |
RAD_BINDIR=<directory> |
96 |
schorsch |
1.6 |
Install executables here |
97 |
(Default read from config file, usually relative to RAD_BASEDIR) |
98 |
schorsch |
1.1 |
99 |
RAD_MANDIR=<directory> |
100 |
schorsch |
1.6 |
Install man pages here |
101 |
102 |
schorsch |
1.1 |
103 |
RAD_RLIBDIR=<directory> |
104 |
schorsch |
1.6 |
Install support files here |
105 |
106 |
schorsch |
1.1 |
107 |
RAD_DEBUG=1|0 |
108 |
schorsch |
1.6 |
1: Build a debug version |
109 |
0: Build a production version (default) |
110 |
schorsch |
1.1 |
111 |
SKIP=1|0 |
112 |
schorsch |
1.6 |
1: Skip display of License terms |
113 |
0: Don't skip (default) |
114 |
schorsch |
1.1 |
115 |
schorsch |
1.7 |
PMAP_OOC=1|0 |
116 |
This is not yet available on Windows |
117 |
1: Build Photon-Maps with Out-of-core Octree (default on unix) |
118 |
0: Build Photon-Maps with In-core KD-Tree (hard set on Windows) |
119 |
120 |
schorsch |
1.6 |
MSVC_VERSION=12.0|13.0|14.1 |
121 |
This is only relevant for building with VC on Windows. |
122 |
"12.0" for Visual C/C++ 2013. |
123 |
"13.0" for Visual C/C++ 2015 (watch out for CRT bug). |
124 |
"14.1" for Visual C/C++ 2017 with up-to-date service packs as of |
125 |
this writing. |
126 |
By default, SCons will select the C/C++ toolset from the most recent |
127 |
installed VC version. If it doesn't select the one you want, you can |
128 |
supply an invalid value (eg. 'xxx') and it will print out a list |
129 |
of the versions that it found to be available. |
130 |
131 |
SCons will remember the values given with those options, for each |
132 |
platform seperately. You don't need to supply them again each time when |
133 |
you run repeated builds and installs, but only when something changes. |
134 |
schorsch |
1.1 |
135 |
Invoking SCons with the -H flag will display informtion about many other |
136 |
options, but you won't normally need any of those. |
137 |
138 |
139 |
Testing |
140 |
141 |
142 |
Radiance comes with a (still very incomplete) test suite, which can be |
143 |
run by invoking |
144 |
145 |
$> scons test |
146 |
147 |
This executes a series of tests, each indicating success or failure. |
148 |
schorsch |
1.6 |
149 |
Testing via SCons will use the Radiance binaries in the |
150 |
"ray/scbuild/<platform>/bin" directory, where they are located after |
151 |
building but before installing, and the support files in "ray/lib/" |
152 |
or elsewhere in the source tree. |
153 |
However, it will not trigger a (re-)build if any of those files are out |
154 |
of date or missing. Instead, it will complain about failed tests because |
155 |
of missing executables and other files. You need to manually invoke |
156 |
building and testing runs one after the other to ensure that everything |
157 |
schorsch |
1.1 |
is where it should be. |
158 |
159 |
Users (that means you!) are invited to contribute more test cases. |
160 |
The goal is that eventually (almost) all Radiance functionality can be |
161 |
tested for compliance with the specification and/or expected results. |
162 |
163 |
See the file "ray/test/README.txt" for details about the testing framework |
164 |
and instructions on how to contribute test cases. |
165 |
166 |
167 |
Installation |
168 |
169 |
170 |
schorsch |
1.6 |
At the begin of each run, SCons will print the currently configured |
171 |
installations directories to the console, even when it won't actually |
172 |
install anything. You can use this to verify that you're about to |
173 |
install in the right location. If uncertain, just start another build |
174 |
run (possibly resulting just in a "`build' is up to date." message) while |
175 |
supplying eg. a new "RAD_BASEDIR=..." parameter to verify the output. |
176 |
If the path configuration seems botched up, just remove the file |
177 |
"ray/scbuild/<platform>/install_paths.py" and start from scratch. |
178 |
179 |
The default installation directory structure is as follows: |
180 |
Base: <> # default depending on platform |
181 |
Binaries: <>/bin |
182 |
Library: <>/share/lib |
183 |
Manpages: <>/share/man |
184 |
If you keep this structure, make sure to set the PATH, RAYPATH, and |
185 |
MANPATH environment variables accordingly. |
186 |
187 |
schorsch |
1.1 |
The software will be installed into the directories given either in the |
188 |
schorsch |
1.2 |
configuration file or through command options, by invoking |
189 |
schorsch |
1.1 |
190 |
$> scons install |
191 |
192 |
To do this you need write permission in the target directories. |
193 |
Any files that are not present or not up to date will be (re-)built |
194 |
before being installed. |
195 |
196 |
You can install parts of the software by specifying one of three special |
197 |
targets: |
198 |
199 |
$> scons bininstall # only executable files |
200 |
$> scons rlibinstall # only support files |
201 |
$> scons maninstall # only manual pages |
202 |
203 |
204 |
Cleanup |
205 |
206 |
207 |
To save disk space on your system, or in preparation of a fresh build |
208 |
with different settings, you can clean up the source tree by invoking |
209 |
210 |
schorsch |
1.2 |
$> scons -c |
211 |
schorsch |
1.1 |
212 |
This will delete all the generated object files, libraries, and |
213 |
schorsch |
1.6 |
executables below the respective "ray/scbuild/<platform>/" subdirectory. |
214 |
schorsch |
1.1 |
215 |
