1 |
Building and Installing Radiance with SCons |
2 |
3 |
4 |
This file describes how to build and install Radiance using the SCons |
5 |
based build system (an alternative to the traditional makeall script |
6 |
explained in the README file). |
7 |
8 |
9 |
Requirements |
10 |
11 |
12 |
Please make sure that you have dowloaded and unpacked BOTH the Radiance |
13 |
source package AND the archive with the auxiliary files. Crucial parts |
14 |
of the system will be missing if you only have one of them. |
15 |
16 |
SCons is a platform-independent software configuration and build system |
17 |
written in Python. If SCons and Python are not already installed on your |
18 |
system, then you need to download and install them first. |
19 |
20 |
Python: http://www.python.org/ |
21 |
SCons: http://www.scons.org/ |
22 |
23 |
For many systems, precompiled packages are available, such as Installer |
24 |
files for Windows. Most Linux distributions already come with Python |
25 |
installed and ready to use. |
26 |
27 |
SCons *may* use a libtiff already installed on your system. However, if |
28 |
it doesn't find one, it will build its own from sources included with |
29 |
Radiance. |
30 |
31 |
32 |
Building |
33 |
34 |
35 |
For building Radiance, go to the "ray" directory (where this file |
36 |
resides) in a console window and type: |
37 |
38 |
$> scons build |
39 |
40 |
or just |
41 |
42 |
$> scons |
43 |
44 |
The Scons program will find the necessary information, display a |
45 |
copyright message for you to acknowledge, and proceed to build the |
46 |
software. |
47 |
48 |
49 |
Configuring |
50 |
51 |
52 |
In the subdirectory "ray/platform/" there are a number of configuration |
53 |
files for various build environments. In this context, a "platform" is a |
54 |
specific combination of operating system and build tools (eg. compiler). |
55 |
On unix based systems, the compiler usually doesn't make much of a |
56 |
difference, but on Windows, there are seperate build environments for |
57 |
toolkits like Cygwin or MingW. |
58 |
59 |
The file "ray/platform/README" explains the settings that can be |
60 |
configured in those files, and how to create a new one, if you use a |
61 |
platform that isn't supported yet. |
62 |
63 |
64 |
Options |
65 |
66 |
67 |
You can add the following command line options when invoking Scons. |
68 |
The directories given here will override those specified in the |
69 |
configuration file. |
70 |
71 |
RAD_BINDIR=<directory> |
72 |
Install executables here |
73 |
(Default read from config file) |
74 |
75 |
RAD_MANDIR=<directory> |
76 |
Install man pages here |
77 |
78 |
79 |
RAD_RLIBDIR=<directory> |
80 |
Install support files here |
81 |
82 |
83 |
RAD_DEBUG=1|0 |
84 |
1: Build a debug version |
85 |
0: Build a production version (default) |
86 |
87 |
SKIP=1|0 |
88 |
1: Skip display of License terms |
89 |
0: Don't skip (default) |
90 |
91 |
SCons will remember the values given with those options. You don't need |
92 |
to supply them again each time when you run repeated builds and |
93 |
installs, but only when something changes. |
94 |
95 |
Invoking SCons with the -H flag will display informtion about many other |
96 |
options, but you won't normally need any of those. |
97 |
98 |
99 |
Testing |
100 |
101 |
102 |
Radiance comes with a (still very incomplete) test suite, which can be |
103 |
run by invoking |
104 |
105 |
$> scons test |
106 |
107 |
This executes a series of tests, each indicating success or failure. |
108 |
Testing will use the Radiance binaries in the "ray/bin/" directory, and the |
109 |
support files in "ray/lib/", where they are located after building but |
110 |
before installing. However, it will not trigger a (re-)build if any of |
111 |
those files are out of date or missing (instead, it will complain about |
112 |
failed tests because of missing executables etc.). You need to manually |
113 |
invoke building and testing after each other to ensure that everything |
114 |
is where it should be. |
115 |
116 |
Users (that means you!) are invited to contribute more test cases. |
117 |
The goal is that eventually (almost) all Radiance functionality can be |
118 |
tested for compliance with the specification and/or expected results. |
119 |
120 |
See the file "ray/test/README.txt" for details about the testing framework |
121 |
and instructions on how to contribute test cases. |
122 |
123 |
124 |
Installation |
125 |
126 |
127 |
The software will be installed into the directories given either in the |
128 |
configuration file or through command options, by invoking |
129 |
130 |
$> scons install |
131 |
132 |
To do this you need write permission in the target directories. |
133 |
Any files that are not present or not up to date will be (re-)built |
134 |
before being installed. |
135 |
136 |
You can install parts of the software by specifying one of three special |
137 |
targets: |
138 |
139 |
$> scons bininstall # only executable files |
140 |
$> scons rlibinstall # only support files |
141 |
$> scons maninstall # only manual pages |
142 |
143 |
144 |
Cleanup |
145 |
146 |
147 |
To save disk space on your system, or in preparation of a fresh build |
148 |
with different settings, you can clean up the source tree by invoking |
149 |
150 |
$> scons -c |
151 |
152 |
This will delete all the generated object files, libraries, and |
153 |
executables in and below the "ray/src/" subdirectory. |
154 |
155 |
