root/radiance/ray/INSTALL.scons
Revision: 1.2
Committed: Thu Oct 22 20:50:27 2009 UTC (15 years, 7 months ago) by schorsch
Changes since 1.1: +4 -4 lines
Fixing typos.
1 Building and Installing Radiance with SCons
2 -------------------------------------------
3
4 This file describes how to build and install Radiance using the SCons
5 based build system (an alternative to the traditional makeall script
6 explained in the README file).
7
8
9 Requirements
10 ------------
11
12 Please make sure that you have dowloaded and unpacked BOTH the Radiance
13 source package AND the archive with the auxiliary files. Crucial parts
14 of the system will be missing if you only have one of them.
15
16 SCons is a platform-independent software configuration and build system
17 written in Python. If SCons and Python are not already installed on your
18 system, then you need to download and install them first.
19
20 Python: http://www.python.org/
21 SCons: http://www.scons.org/
22
23 For many systems, precompiled packages are available, such as Installer
24 files for Windows. Most Linux distributions already come with Python
25 installed and ready to use.
26
27 SCons *may* use a libtiff already installed on your system. However, if
28 it doesn't find one, it will build its own from sources included with
29 Radiance.
30
31
32 Building
33 --------
34
35 For building Radiance, go to the "ray" directory (where this file
36 resides) in a console window and type:
37
38 $> scons build
39
40 or just
41
42 $> scons
43
44 The Scons program will find the necessary information, display a
45 copyright message for you to acknowledge, and proceed to build the
46 software.
47
48
49 Configuring
50 -----------
51
52 In the subdirectory "ray/platform/" there are a number of configuration
53 files for various build environments. In this context, a "platform" is a
54 specific combination of operating system and build tools (eg. compiler).
55 On unix based systems, the compiler usually doesn't make much of a
56 difference, but on Windows, there are seperate build environments for
57 toolkits like Cygwin or MingW.
58
59 The file "ray/platform/README" explains the settings that can be
60 configured in those files, and how to create a new one, if you use a
61 platform that isn't supported yet.
62
63
64 Options
65 -------
66
67 You can add the following command line options when invoking Scons.
68 The directories given here will override those specified in the
69 configuration file.
70
71 RAD_BINDIR=<directory>
72 Install executables here
73 (Default read from config file)
74
75 RAD_MANDIR=<directory>
76 Install man pages here
77 (Default read from config file)
78
79 RAD_RLIBDIR=<directory>
80 Install support files here
81 (Default read from config file)
82
83 RAD_DEBUG=1|0
84 1: Build a debug version
85 0: Build a production version (default)
86
87 SKIP=1|0
88 1: Skip display of License terms
89 0: Don't skip (default)
90
91 SCons will remember the values given with those options. You don't need
92 to supply them again each time when you run repeated builds and
93 installs, but only when something changes.
94
95 Invoking SCons with the -H flag will display informtion about many other
96 options, but you won't normally need any of those.
97
98
99 Testing
100 -------
101
102 Radiance comes with a (still very incomplete) test suite, which can be
103 run by invoking
104
105 $> scons test
106
107 This executes a series of tests, each indicating success or failure.
108 Testing will use the Radiance binaries in the "ray/bin/" directory, and the
109 support files in "ray/lib/", where they are located after building but
110 before installing. However, it will not trigger a (re-)build if any of
111 those files are out of date or missing (instead, it will complain about
112 failed tests because of missing executables etc.). You need to manually
113 invoke building and testing after each other to ensure that everything
114 is where it should be.
115
116 Users (that means you!) are invited to contribute more test cases.
117 The goal is that eventually (almost) all Radiance functionality can be
118 tested for compliance with the specification and/or expected results.
119
120 See the file "ray/test/README.txt" for details about the testing framework
121 and instructions on how to contribute test cases.
122
123
124 Installation
125 ------------
126
127 The software will be installed into the directories given either in the
128 configuration file or through command options, by invoking
129
130 $> scons install
131
132 To do this you need write permission in the target directories.
133 Any files that are not present or not up to date will be (re-)built
134 before being installed.
135
136 You can install parts of the software by specifying one of three special
137 targets:
138
139 $> scons bininstall # only executable files
140 $> scons rlibinstall # only support files
141 $> scons maninstall # only manual pages
142
143
144 Cleanup
145 -------
146
147 To save disk space on your system, or in preparation of a fresh build
148 with different settings, you can clean up the source tree by invoking
149
150 $> scons -c
151
152 This will delete all the generated object files, libraries, and
153 executables in and below the "ray/src/" subdirectory.
154
155
