--- ray/INSTALL.scons 2008/12/26 17:00:32 1.1 +++ ray/INSTALL.scons 2009/10/22 20:50:27 1.2 @@ -3,7 +3,7 @@ Building and Installing Radiance with SCons This file describes how to build and install Radiance using the SCons based build system (an alternative to the traditional makeall script -expleined in the README file). +explained in the README file). Requirements @@ -20,7 +20,7 @@ system, then you need to download and install them fir Python: http://www.python.org/ SCons: http://www.scons.org/ -For many systems, precompiled packages are availabls, such as Installer +For many systems, precompiled packages are available, such as Installer files for Windows. Most Linux distributions already come with Python installed and ready to use. @@ -125,7 +125,7 @@ Installation ------------ The software will be installed into the directories given either in the -configuration file through command options, by invoking +configuration file or through command options, by invoking $> scons install @@ -147,7 +147,7 @@ Cleanup To save disk space on your system, or in preparation of a fresh build with different settings, you can clean up the source tree by invoking - %> scons -c + $> scons -c This will delete all the generated object files, libraries, and executables in and below the "ray/src/" subdirectory.
