| 1 |
schorsch |
1.1 |
Building and Installing Radiance with SCons
| 2 |
| 3 |
| 4 |
This file describes how to build and install Radiance using the SCons
| 5 |
schorsch |
1.6 |
based build system, an alternative to the traditional makeall script
| 6 |
explained in the README file.
| 7 |
schorsch |
1.1 |
| 8 |
| 9 |
Requirements
| 10 |
| 11 |
| 12 |
Please make sure that you have dowloaded and unpacked BOTH the Radiance
| 13 |
schorsch |
1.3 |
source package AND the archive with the auxiliary support files.
| 14 |
Crucial parts of the system will be missing if you only have one of
| 15 |
them, and SCons will be unable to build the software.
| 16 |
schorsch |
1.1 |
| 17 |
SCons is a platform-independent software configuration and build system
| 18 |
written in Python. If SCons and Python are not already installed on your
| 19 |
system, then you need to download and install them first.
| 20 |
schorsch |
1.6 |
At the time of this writing, all versions of SCons work with Python 2.7.
| 21 |
SCons versions from 3.0 up also work with Python 3.x, even if the
| 22 |
documentation may still say otherwise.
| 23 |
schorsch |
1.1 |
| 24 |
Python: http://www.python.org/
| 25 |
SCons: http://www.scons.org/
| 26 |
| 27 |
schorsch |
1.2 |
For many systems, precompiled packages are available, such as Installer
| 28 |
schorsch |
1.1 |
files for Windows. Most Linux distributions already come with Python
| 29 |
installed and ready to use.
| 30 |
| 31 |
schorsch |
1.4 |
SCons *may* use a libtiff already installed on your system. On posix
| 32 |
systems it usually does. Otherwise the executables requiring it are
| 33 |
not built.
| 34 |
schorsch |
1.1 |
| 35 |
schorsch |
1.5 |
On Windows, Radiance gets built with MS Visual Studio if present, the
| 36 |
schorsch |
1.6 |
free (of cost) community editions are sufficient.
| 37 |
Warning: when VS 2015 came out, the new "universal CRT" from Windows 10,
| 38 |
which was used at the time, had a bug that corrupts data in text pipes.
| 39 |
(Technically, the UCRT is now part of the OS instead of the compiler,
| 40 |
so you need to make sure you have a fixed version of the CRT SDK.)
| 41 |
Since VS 2017, the "universal CRT" bug is fixed and everyting works fine.
| 42 |
schorsch |
1.5 |
| 43 |
schorsch |
1.1 |
| 44 |
Building
| 45 |
| 46 |
| 47 |
For building Radiance, go to the "ray" directory (where this file
| 48 |
resides) in a console window and type:
| 49 |
| 50 |
$> scons build
| 51 |
| 52 |
or just
| 53 |
| 54 |
$> scons
| 55 |
| 56 |
The Scons program will find the necessary information, display a
| 57 |
schorsch |
1.6 |
copyright message for you to acknowledge (once), and proceed to build
| 58 |
the software.
| 59 |
schorsch |
1.1 |
| 60 |
schorsch |
1.6 |
On Windows, the distribution includes a file named "scons.bat", in
| 61 |
case the SCons script is not on the system execution path. You may
| 62 |
need to change this file to point to your actual Python installation.
| 63 |
schorsch |
1.1 |
| 64 |
schorsch |
1.6 |
All build products are stored under "ray/scbuild/<platform>/", where
| 65 |
they are then available for testing and installation.
| 66 |
| 67 |
| 68 |
Configuration
| 69 |
| 70 |
schorsch |
1.1 |
| 71 |
In the subdirectory "ray/platform/" there are a number of configuration
| 72 |
files for various build environments. In this context, a "platform" is a
| 73 |
schorsch |
1.6 |
specific combination of operating system, Memory model (32 or 64 bit),
| 74 |
and build tools (eg. compiler).
| 75 |
schorsch |
1.1 |
On unix based systems, the compiler usually doesn't make much of a
| 76 |
difference, but on Windows, there are seperate build environments for
| 77 |
schorsch |
1.4 |
toolkits like MingW.
| 78 |
schorsch |
1.1 |
| 79 |
The file "ray/platform/README" explains the settings that can be
| 80 |
configured in those files, and how to create a new one, if you use a
| 81 |
platform that isn't supported yet.
| 82 |
| 83 |
| 84 |
Options
| 85 |
| 86 |
| 87 |
You can add the following command line options when invoking Scons.
| 88 |
The directories given here will override those specified in the
| 89 |
configuration file.
| 90 |
| 91 |
schorsch |
1.6 |
RAD_BASEDIR=<directory>
| 92 |
The base directory for the installation
| 93 |
(Default read from config file, depending on platform)
| 94 |
| 95 |
schorsch |
1.1 |
RAD_BINDIR=<directory>
| 96 |
schorsch |
1.6 |
Install executables here
| 97 |
(Default read from config file, usually relative to RAD_BASEDIR)
| 98 |
schorsch |
1.1 |
| 99 |
RAD_MANDIR=<directory>
| 100 |
schorsch |
1.6 |
Install man pages here
| 101 |
| 102 |
schorsch |
1.1 |
| 103 |
RAD_RLIBDIR=<directory>
| 104 |
schorsch |
1.6 |
Install support files here
| 105 |
| 106 |
schorsch |
1.1 |
| 107 |
RAD_DEBUG=1|0
| 108 |
schorsch |
1.6 |
1: Build a debug version
| 109 |
0: Build a production version (default)
| 110 |
schorsch |
1.1 |
| 111 |
SKIP=1|0
| 112 |
schorsch |
1.6 |
1: Skip display of License terms
| 113 |
0: Don't skip (default)
| 114 |
schorsch |
1.1 |
| 115 |
schorsch |
1.7 |
PMAP_OOC=1|0
| 116 |
This is not yet available on Windows
| 117 |
1: Build Photon-Maps with Out-of-core Octree (default on unix)
| 118 |
0: Build Photon-Maps with In-core KD-Tree (hard set on Windows)
| 119 |
| 120 |
schorsch |
1.6 |
MSVC_VERSION=12.0|13.0|14.1
| 121 |
This is only relevant for building with VC on Windows.
| 122 |
"12.0" for Visual C/C++ 2013.
| 123 |
"13.0" for Visual C/C++ 2015 (watch out for CRT bug).
| 124 |
"14.1" for Visual C/C++ 2017 with up-to-date service packs as of
| 125 |
this writing.
| 126 |
By default, SCons will select the C/C++ toolset from the most recent
| 127 |
installed VC version. If it doesn't select the one you want, you can
| 128 |
supply an invalid value (eg. 'xxx') and it will print out a list
| 129 |
of the versions that it found to be available.
| 130 |
| 131 |
SCons will remember the values given with those options, for each
| 132 |
platform seperately. You don't need to supply them again each time when
| 133 |
you run repeated builds and installs, but only when something changes.
| 134 |
schorsch |
1.1 |
| 135 |
Invoking SCons with the -H flag will display informtion about many other
| 136 |
options, but you won't normally need any of those.
| 137 |
| 138 |
| 139 |
Testing
| 140 |
| 141 |
| 142 |
Radiance comes with a (still very incomplete) test suite, which can be
| 143 |
run by invoking
| 144 |
| 145 |
$> scons test
| 146 |
| 147 |
This executes a series of tests, each indicating success or failure.
| 148 |
schorsch |
1.6 |
| 149 |
Testing via SCons will use the Radiance binaries in the
| 150 |
"ray/scbuild/<platform>/bin" directory, where they are located after
| 151 |
building but before installing, and the support files in "ray/lib/"
| 152 |
or elsewhere in the source tree.
| 153 |
However, it will not trigger a (re-)build if any of those files are out
| 154 |
of date or missing. Instead, it will complain about failed tests because
| 155 |
of missing executables and other files. You need to manually invoke
| 156 |
building and testing runs one after the other to ensure that everything
| 157 |
schorsch |
1.1 |
is where it should be.
| 158 |
| 159 |
Users (that means you!) are invited to contribute more test cases.
| 160 |
The goal is that eventually (almost) all Radiance functionality can be
| 161 |
tested for compliance with the specification and/or expected results.
| 162 |
| 163 |
See the file "ray/test/README.txt" for details about the testing framework
| 164 |
and instructions on how to contribute test cases.
| 165 |
| 166 |
| 167 |
Installation
| 168 |
| 169 |
| 170 |
schorsch |
1.6 |
At the begin of each run, SCons will print the currently configured
| 171 |
installations directories to the console, even when it won't actually
| 172 |
install anything. You can use this to verify that you're about to
| 173 |
install in the right location. If uncertain, just start another build
| 174 |
run (possibly resulting just in a "`build' is up to date." message) while
| 175 |
supplying eg. a new "RAD_BASEDIR=..." parameter to verify the output.
| 176 |
If the path configuration seems botched up, just remove the file
| 177 |
"ray/scbuild/<platform>/install_paths.py" and start from scratch.
| 178 |
| 179 |
The default installation directory structure is as follows:
| 180 |
Base: <> # default depending on platform
| 181 |
Binaries: <>/bin
| 182 |
Library: <>/share/lib
| 183 |
Manpages: <>/share/man
| 184 |
If you keep this structure, make sure to set the PATH, RAYPATH, and
| 185 |
MANPATH environment variables accordingly.
| 186 |
| 187 |
schorsch |
1.1 |
The software will be installed into the directories given either in the
| 188 |
schorsch |
1.2 |
configuration file or through command options, by invoking
| 189 |
schorsch |
1.1 |
| 190 |
$> scons install
| 191 |
| 192 |
To do this you need write permission in the target directories.
| 193 |
Any files that are not present or not up to date will be (re-)built
| 194 |
before being installed.
| 195 |
| 196 |
You can install parts of the software by specifying one of three special
| 197 |
targets:
| 198 |
| 199 |
$> scons bininstall # only executable files
| 200 |
$> scons rlibinstall # only support files
| 201 |
$> scons maninstall # only manual pages
| 202 |
| 203 |
| 204 |
Cleanup
| 205 |
| 206 |
| 207 |
To save disk space on your system, or in preparation of a fresh build
| 208 |
with different settings, you can clean up the source tree by invoking
| 209 |
| 210 |
schorsch |
1.2 |
$> scons -c
| 211 |
schorsch |
1.1 |
| 212 |
This will delete all the generated object files, libraries, and
| 213 |
schorsch |
1.6 |
executables below the respective "ray/scbuild/<platform>/" subdirectory.
| 214 |
schorsch |
1.1 |
| 215 |
