root/radiance/ray/INSTALL.scons
Revision: 1.5
Committed: Tue Apr 19 21:21:23 2016 UTC (8 years, 6 months ago) by schorsch
Changes since 1.4: +15 -0 lines
Build with VC2013 until text pipe bug is fixed; prepare for pyinstaller on scripts
1 Building and Installing Radiance with SCons
2 -------------------------------------------
3
4 This file describes how to build and install Radiance using the SCons
5 based build system (an alternative to the traditional makeall script
6 explained in the README file).
7
8
9 Requirements
10 ------------
11
12 Please make sure that you have dowloaded and unpacked BOTH the Radiance
13 source package AND the archive with the auxiliary support files.
14 Crucial parts of the system will be missing if you only have one of
15 them, and SCons will be unable to build the software.
16
17 SCons is a platform-independent software configuration and build system
18 written in Python. If SCons and Python are not already installed on your
19 system, then you need to download and install them first.
20
21 Python: http://www.python.org/
22 SCons: http://www.scons.org/
23
24 For many systems, precompiled packages are available, such as Installer
25 files for Windows. Most Linux distributions already come with Python
26 installed and ready to use.
27
28 SCons *may* use a libtiff already installed on your system. On posix
29 systems it usually does. Otherwise the executables requiring it are
30 not built.
31
32 On Windows, Radiance gets built with MS Visual Studio if present, the
33 community editions are sufficient.
34 VS 2013 is currently the most recent version that does it correctly.
35 VS 2015 also performs the build, but it uses the new "universal CRT"
36 from Windows 10, which has a bug that corrupts data in text pipes.
37 A fix is apparently ready and should be released via autoupdate,
38 probably around the time of the "anniversary update" in summer 2016.
39 Older versions of VS may work as well, but haven't been tested with
40 the current sources.
41
42
43 Building
44 --------
45
46 For building Radiance, go to the "ray" directory (where this file
47 resides) in a console window and type:
48
49 $> scons build
50
51 or just
52
53 $> scons
54
55 The Scons program will find the necessary information, display a
56 copyright message for you to acknowledge, and proceed to build the
57 software.
58
59
60 Configuring
61 -----------
62
63 In the subdirectory "ray/platform/" there are a number of configuration
64 files for various build environments. In this context, a "platform" is a
65 specific combination of operating system and build tools (eg. compiler).
66 On unix based systems, the compiler usually doesn't make much of a
67 difference, but on Windows, there are seperate build environments for
68 toolkits like MingW.
69
70 The file "ray/platform/README" explains the settings that can be
71 configured in those files, and how to create a new one, if you use a
72 platform that isn't supported yet.
73
74
75 Options
76 -------
77
78 You can add the following command line options when invoking Scons.
79 The directories given here will override those specified in the
80 configuration file.
81
82 RAD_BINDIR=<directory>
83 Install executables here
84 (Default read from config file)
85
86 RAD_MANDIR=<directory>
87 Install man pages here
88 (Default read from config file)
89
90 RAD_RLIBDIR=<directory>
91 Install support files here
92 (Default read from config file)
93
94 RAD_DEBUG=1|0
95 1: Build a debug version
96 0: Build a production version (default)
97
98 SKIP=1|0
99 1: Skip display of License terms
100 0: Don't skip (default)
101
102 MSVC_VERSION=12.0|14.0
103 "12.0" is the default for Visual Studio 2013.
104 Once the text pipe bug in the universal CRT is fixed, the default
105 will be changed to "14.0" for Visual Studio 2015.
106
107 SCons will remember the values given with those options. You don't need
108 to supply them again each time when you run repeated builds and
109 installs, but only when something changes.
110
111 Invoking SCons with the -H flag will display informtion about many other
112 options, but you won't normally need any of those.
113
114
115 Testing
116 -------
117
118 Radiance comes with a (still very incomplete) test suite, which can be
119 run by invoking
120
121 $> scons test
122
123 This executes a series of tests, each indicating success or failure.
124 Testing will use the Radiance binaries in the "ray/bin/" directory, and the
125 support files in "ray/lib/", where they are located after building but
126 before installing. However, it will not trigger a (re-)build if any of
127 those files are out of date or missing (instead, it will complain about
128 failed tests because of missing executables etc.). You need to manually
129 invoke building and testing after each other to ensure that everything
130 is where it should be.
131
132 Users (that means you!) are invited to contribute more test cases.
133 The goal is that eventually (almost) all Radiance functionality can be
134 tested for compliance with the specification and/or expected results.
135
136 See the file "ray/test/README.txt" for details about the testing framework
137 and instructions on how to contribute test cases.
138
139
140 Installation
141 ------------
142
143 The software will be installed into the directories given either in the
144 configuration file or through command options, by invoking
145
146 $> scons install
147
148 To do this you need write permission in the target directories.
149 Any files that are not present or not up to date will be (re-)built
150 before being installed.
151
152 You can install parts of the software by specifying one of three special
153 targets:
154
155 $> scons bininstall # only executable files
156 $> scons rlibinstall # only support files
157 $> scons maninstall # only manual pages
158
159
160 Cleanup
161 -------
162
163 To save disk space on your system, or in preparation of a fresh build
164 with different settings, you can clean up the source tree by invoking
165
166 $> scons -c
167
168 This will delete all the generated object files, libraries, and
169 executables in and below the "ray/src/" subdirectory.
170
171
