root/radiance/ray/INSTALL.scons
Revision: 1.5
Committed: Tue Apr 19 21:21:23 2016 UTC (9 years ago) by schorsch
Changes since 1.4: +15 -0 lines
Build with VC2013 until text pipe bug is fixed; prepare for pyinstaller on scripts
# User Rev Content
1 schorsch 1.1 Building and Installing Radiance with SCons
2     -------------------------------------------
3
4     This file describes how to build and install Radiance using the SCons
5     based build system (an alternative to the traditional makeall script
6 schorsch 1.2 explained in the README file).
7 schorsch 1.1
8
9     Requirements
10     ------------
11
12     Please make sure that you have dowloaded and unpacked BOTH the Radiance
13 schorsch 1.3 source package AND the archive with the auxiliary support files.
14     Crucial parts of the system will be missing if you only have one of
15     them, and SCons will be unable to build the software.
16 schorsch 1.1
17     SCons is a platform-independent software configuration and build system
18     written in Python. If SCons and Python are not already installed on your
19     system, then you need to download and install them first.
20
21     Python: http://www.python.org/
22     SCons: http://www.scons.org/
23
24 schorsch 1.2 For many systems, precompiled packages are available, such as Installer
25 schorsch 1.1 files for Windows. Most Linux distributions already come with Python
26     installed and ready to use.
27
28 schorsch 1.4 SCons *may* use a libtiff already installed on your system. On posix
29     systems it usually does. Otherwise the executables requiring it are
30     not built.
31 schorsch 1.1
32 schorsch 1.5 On Windows, Radiance gets built with MS Visual Studio if present, the
33     community editions are sufficient.
34     VS 2013 is currently the most recent version that does it correctly.
35     VS 2015 also performs the build, but it uses the new "universal CRT"
36     from Windows 10, which has a bug that corrupts data in text pipes.
37     A fix is apparently ready and should be released via autoupdate,
38     probably around the time of the "anniversary update" in summer 2016.
39     Older versions of VS may work as well, but haven't been tested with
40     the current sources.
41
42 schorsch 1.1
43     Building
44     --------
45
46     For building Radiance, go to the "ray" directory (where this file
47     resides) in a console window and type:
48
49     $> scons build
50
51     or just
52
53     $> scons
54
55     The Scons program will find the necessary information, display a
56     copyright message for you to acknowledge, and proceed to build the
57     software.
58
59
60     Configuring
61     -----------
62
63     In the subdirectory "ray/platform/" there are a number of configuration
64     files for various build environments. In this context, a "platform" is a
65     specific combination of operating system and build tools (eg. compiler).
66     On unix based systems, the compiler usually doesn't make much of a
67     difference, but on Windows, there are seperate build environments for
68 schorsch 1.4 toolkits like MingW.
69 schorsch 1.1
70     The file "ray/platform/README" explains the settings that can be
71     configured in those files, and how to create a new one, if you use a
72     platform that isn't supported yet.
73
74
75     Options
76     -------
77
78     You can add the following command line options when invoking Scons.
79     The directories given here will override those specified in the
80     configuration file.
81
82     RAD_BINDIR=<directory>
83     Install executables here
84     (Default read from config file)
85
86     RAD_MANDIR=<directory>
87     Install man pages here
88     (Default read from config file)
89
90     RAD_RLIBDIR=<directory>
91     Install support files here
92     (Default read from config file)
93
94     RAD_DEBUG=1|0
95     1: Build a debug version
96     0: Build a production version (default)
97
98     SKIP=1|0
99     1: Skip display of License terms
100     0: Don't skip (default)
101
102 schorsch 1.5 MSVC_VERSION=12.0|14.0
103     "12.0" is the default for Visual Studio 2013.
104     Once the text pipe bug in the universal CRT is fixed, the default
105     will be changed to "14.0" for Visual Studio 2015.
106
107 schorsch 1.1 SCons will remember the values given with those options. You don't need
108     to supply them again each time when you run repeated builds and
109     installs, but only when something changes.
110
111     Invoking SCons with the -H flag will display informtion about many other
112     options, but you won't normally need any of those.
113
114
115     Testing
116     -------
117
118     Radiance comes with a (still very incomplete) test suite, which can be
119     run by invoking
120
121     $> scons test
122
123     This executes a series of tests, each indicating success or failure.
124     Testing will use the Radiance binaries in the "ray/bin/" directory, and the
125     support files in "ray/lib/", where they are located after building but
126     before installing. However, it will not trigger a (re-)build if any of
127     those files are out of date or missing (instead, it will complain about
128     failed tests because of missing executables etc.). You need to manually
129     invoke building and testing after each other to ensure that everything
130     is where it should be.
131
132     Users (that means you!) are invited to contribute more test cases.
133     The goal is that eventually (almost) all Radiance functionality can be
134     tested for compliance with the specification and/or expected results.
135
136     See the file "ray/test/README.txt" for details about the testing framework
137     and instructions on how to contribute test cases.
138
139
140     Installation
141     ------------
142
143     The software will be installed into the directories given either in the
144 schorsch 1.2 configuration file or through command options, by invoking
145 schorsch 1.1
146     $> scons install
147
148     To do this you need write permission in the target directories.
149     Any files that are not present or not up to date will be (re-)built
150     before being installed.
151
152     You can install parts of the software by specifying one of three special
153     targets:
154
155     $> scons bininstall # only executable files
156     $> scons rlibinstall # only support files
157     $> scons maninstall # only manual pages
158
159
160     Cleanup
161     -------
162
163     To save disk space on your system, or in preparation of a fresh build
164     with different settings, you can clean up the source tree by invoking
165
166 schorsch 1.2 $> scons -c
167 schorsch 1.1
168     This will delete all the generated object files, libraries, and
169     executables in and below the "ray/src/" subdirectory.
170
171
