root/radiance/ray/INSTALL.scons
Revision: 1.7
Committed: Tue Jan 9 00:08:57 2018 UTC (6 years, 5 months ago) by schorsch
CVS Tags: rad5R4, rad5R2, rad5R3, HEAD
Changes since 1.6: +5 -0 lines
SCons Option to build Pmap with OOC data on unix
# User Rev Content
1 schorsch 1.1 Building and Installing Radiance with SCons
2     -------------------------------------------
3
4     This file describes how to build and install Radiance using the SCons
5 schorsch 1.6 based build system, an alternative to the traditional makeall script
6     explained in the README file.
7 schorsch 1.1
8
9     Requirements
10     ------------
11
12     Please make sure that you have dowloaded and unpacked BOTH the Radiance
13 schorsch 1.3 source package AND the archive with the auxiliary support files.
14     Crucial parts of the system will be missing if you only have one of
15     them, and SCons will be unable to build the software.
16 schorsch 1.1
17     SCons is a platform-independent software configuration and build system
18     written in Python. If SCons and Python are not already installed on your
19     system, then you need to download and install them first.
20 schorsch 1.6 At the time of this writing, all versions of SCons work with Python 2.7.
21     SCons versions from 3.0 up also work with Python 3.x, even if the
22     documentation may still say otherwise.
23 schorsch 1.1
24     Python: http://www.python.org/
25     SCons: http://www.scons.org/
26
27 schorsch 1.2 For many systems, precompiled packages are available, such as Installer
28 schorsch 1.1 files for Windows. Most Linux distributions already come with Python
29     installed and ready to use.
30
31 schorsch 1.4 SCons *may* use a libtiff already installed on your system. On posix
32     systems it usually does. Otherwise the executables requiring it are
33     not built.
34 schorsch 1.1
35 schorsch 1.5 On Windows, Radiance gets built with MS Visual Studio if present, the
36 schorsch 1.6 free (of cost) community editions are sufficient.
37     Warning: when VS 2015 came out, the new "universal CRT" from Windows 10,
38     which was used at the time, had a bug that corrupts data in text pipes.
39     (Technically, the UCRT is now part of the OS instead of the compiler,
40     so you need to make sure you have a fixed version of the CRT SDK.)
41     Since VS 2017, the "universal CRT" bug is fixed and everyting works fine.
42 schorsch 1.5
43 schorsch 1.1
44     Building
45     --------
46
47     For building Radiance, go to the "ray" directory (where this file
48     resides) in a console window and type:
49
50     $> scons build
51
52     or just
53
54     $> scons
55
56     The Scons program will find the necessary information, display a
57 schorsch 1.6 copyright message for you to acknowledge (once), and proceed to build
58     the software.
59 schorsch 1.1
60 schorsch 1.6 On Windows, the distribution includes a file named "scons.bat", in
61     case the SCons script is not on the system execution path. You may
62     need to change this file to point to your actual Python installation.
63 schorsch 1.1
64 schorsch 1.6 All build products are stored under "ray/scbuild/<platform>/", where
65     they are then available for testing and installation.
66
67
68     Configuration
69     -------------
70 schorsch 1.1
71     In the subdirectory "ray/platform/" there are a number of configuration
72     files for various build environments. In this context, a "platform" is a
73 schorsch 1.6 specific combination of operating system, Memory model (32 or 64 bit),
74     and build tools (eg. compiler).
75 schorsch 1.1 On unix based systems, the compiler usually doesn't make much of a
76     difference, but on Windows, there are seperate build environments for
77 schorsch 1.4 toolkits like MingW.
78 schorsch 1.1
79     The file "ray/platform/README" explains the settings that can be
80     configured in those files, and how to create a new one, if you use a
81     platform that isn't supported yet.
82
83
84     Options
85     -------
86
87     You can add the following command line options when invoking Scons.
88     The directories given here will override those specified in the
89     configuration file.
90
91 schorsch 1.6 RAD_BASEDIR=<directory>
92     The base directory for the installation
93     (Default read from config file, depending on platform)
94
95 schorsch 1.1 RAD_BINDIR=<directory>
96 schorsch 1.6 Install executables here
97     (Default read from config file, usually relative to RAD_BASEDIR)
98 schorsch 1.1
99     RAD_MANDIR=<directory>
100 schorsch 1.6 Install man pages here
101     (Default read from config file, usually relative to RAD_BASEDIR)
102 schorsch 1.1
103     RAD_RLIBDIR=<directory>
104 schorsch 1.6 Install support files here
105     (Default read from config file, usually relative to RAD_BASEDIR)
106 schorsch 1.1
107     RAD_DEBUG=1|0
108 schorsch 1.6 1: Build a debug version
109     0: Build a production version (default)
110 schorsch 1.1
111     SKIP=1|0
112 schorsch 1.6 1: Skip display of License terms
113     0: Don't skip (default)
114 schorsch 1.1
115 schorsch 1.7 PMAP_OOC=1|0
116     This is not yet available on Windows
117     1: Build Photon-Maps with Out-of-core Octree (default on unix)
118     0: Build Photon-Maps with In-core KD-Tree (hard set on Windows)
119
120 schorsch 1.6 MSVC_VERSION=12.0|13.0|14.1
121     This is only relevant for building with VC on Windows.
122     "12.0" for Visual C/C++ 2013.
123     "13.0" for Visual C/C++ 2015 (watch out for CRT bug).
124     "14.1" for Visual C/C++ 2017 with up-to-date service packs as of
125     this writing.
126     By default, SCons will select the C/C++ toolset from the most recent
127     installed VC version. If it doesn't select the one you want, you can
128     supply an invalid value (eg. 'xxx') and it will print out a list
129     of the versions that it found to be available.
130
131     SCons will remember the values given with those options, for each
132     platform seperately. You don't need to supply them again each time when
133     you run repeated builds and installs, but only when something changes.
134 schorsch 1.1
135     Invoking SCons with the -H flag will display informtion about many other
136     options, but you won't normally need any of those.
137
138
139     Testing
140     -------
141
142     Radiance comes with a (still very incomplete) test suite, which can be
143     run by invoking
144
145     $> scons test
146
147     This executes a series of tests, each indicating success or failure.
148 schorsch 1.6
149     Testing via SCons will use the Radiance binaries in the
150     "ray/scbuild/<platform>/bin" directory, where they are located after
151     building but before installing, and the support files in "ray/lib/"
152     or elsewhere in the source tree.
153     However, it will not trigger a (re-)build if any of those files are out
154     of date or missing. Instead, it will complain about failed tests because
155     of missing executables and other files. You need to manually invoke
156     building and testing runs one after the other to ensure that everything
157 schorsch 1.1 is where it should be.
158
159     Users (that means you!) are invited to contribute more test cases.
160     The goal is that eventually (almost) all Radiance functionality can be
161     tested for compliance with the specification and/or expected results.
162
163     See the file "ray/test/README.txt" for details about the testing framework
164     and instructions on how to contribute test cases.
165
166
167     Installation
168     ------------
169
170 schorsch 1.6 At the begin of each run, SCons will print the currently configured
171     installations directories to the console, even when it won't actually
172     install anything. You can use this to verify that you're about to
173     install in the right location. If uncertain, just start another build
174     run (possibly resulting just in a "`build' is up to date." message) while
175     supplying eg. a new "RAD_BASEDIR=..." parameter to verify the output.
176     If the path configuration seems botched up, just remove the file
177     "ray/scbuild/<platform>/install_paths.py" and start from scratch.
178
179     The default installation directory structure is as follows:
180     Base: <> # default depending on platform
181     Binaries: <>/bin
182     Library: <>/share/lib
183     Manpages: <>/share/man
184     If you keep this structure, make sure to set the PATH, RAYPATH, and
185     MANPATH environment variables accordingly.
186
187 schorsch 1.1 The software will be installed into the directories given either in the
188 schorsch 1.2 configuration file or through command options, by invoking
189 schorsch 1.1
190     $> scons install
191
192     To do this you need write permission in the target directories.
193     Any files that are not present or not up to date will be (re-)built
194     before being installed.
195
196     You can install parts of the software by specifying one of three special
197     targets:
198
199     $> scons bininstall # only executable files
200     $> scons rlibinstall # only support files
201     $> scons maninstall # only manual pages
202
203
204     Cleanup
205     -------
206
207     To save disk space on your system, or in preparation of a fresh build
208     with different settings, you can clean up the source tree by invoking
209
210 schorsch 1.2 $> scons -c
211 schorsch 1.1
212     This will delete all the generated object files, libraries, and
213 schorsch 1.6 executables below the respective "ray/scbuild/<platform>/" subdirectory.
214 schorsch 1.1
215
