1 |
cmake_minimum_required(VERSION 2.8.4) |
2 |
project("radiance") |
3 |
4 |
enable_testing() |
5 |
include(CTest) |
6 |
7 |
option(BUILD_SHARED_LIBS "Build radiance using shared libraries?" OFF) |
8 |
option(BUILD_HEADLESS "Build radiance without any GUI components?" OFF) |
9 |
10 |
option(CPACK_NREL_SUPPORT "Include OpenStudio ToolFinder Help?" OFF) |
11 |
12 |
if( CPACK_NREL_SUPPORT ) |
13 |
# find git so we can query for the current git tag |
14 |
find_program(git git) |
15 |
if (NOT git) |
16 |
message(ERROR "Please specify the path to the git executable") |
17 |
endif() |
18 |
19 |
# call git log to get output containing the tag |
20 |
execute_process( |
21 |
COMMAND ${git} describe --tag --exact-match |
22 |
WORKING_DIRECTORY ${CMAKE_SOURCE_DIR} |
23 |
OUTPUT_VARIABLE git_tag_output) |
24 |
25 |
# create & install the source version .txt file |
26 |
file(WRITE "NREL_ver.txt" "Radiance version ${git_tag_output}") |
27 |
install(FILES NREL_ver.txt DESTINATION bin/..) |
28 |
endif() |
29 |
30 |
if(NOT WIN32) |
31 |
set(CPACK_INCLUDE_TOPLEVEL_DIRECTORY 1) |
32 |
install(DIRECTORY ${CMAKE_CURRENT_SOURCE_DIR}/doc/man/ DESTINATION man) |
33 |
set(qt_plugin_term "PLUGIN") |
34 |
endif() |
35 |
36 |
if (WIN32) |
37 |
set(CPACK_NSIS_MODIFY_PATH 1) |
38 |
set(qt_plugin_term "LIBRARY") |
39 |
40 |
# Set RAYPATH on install |
41 |
set(CPACK_NSIS_EXTRA_INSTALL_COMMANDS |
42 |
"WriteRegExpandStr HKLM \\\"SYSTEM\\\\CurrentControlSet\\\\Control\\\\Session Manager\\\\Environment\\\" RAYPATH '\\\$INSTDIR\\\\lib\\\;.'" |
43 |
44 |
45 |
# Unset RAYPATH on uninstall |
46 |
set(CPACK_NSIS_EXTRA_UNINSTALL_COMMANDS |
47 |
"DeleteRegValue HKLM \\\"SYSTEM\\\\CurrentControlSet\\\\Control\\\\Session Manager\\\\Environment\\\" RAYPATH" |
48 |
49 |
endif() |
50 |
51 |
if(UNIX) |
52 |
set(CPACK_PACKAGING_INSTALL_PREFIX "/usr/local/radiance") |
53 |
add_definitions(-Dlinux -D_FILE_OFFSET_BITS=64 -DNOSTEREO) |
54 |
else() |
55 |
set(CPACK_PACKAGING_INSTALL_PREFIX "/") |
56 |
endif() |
57 |
58 |
if(APPLE) |
59 |
add_definitions(-DBSD -DNOSTEREO -Dfreebsd) |
60 |
include_directories(/usr/X11R6/include) |
61 |
SET(CMAKE_C_FLAGS "${CMAKE_C_FLAGS} -mmacosx-version-min=10.6") |
62 |
endif() |
63 |
64 |
IF( BUILD_PACKAGE ) |
65 |
INCLUDE(radianceCPack.cmake ) |
66 |
ENDIF( BUILD_PACKAGE ) |
67 |
68 |
set(CPACK_PACKAGE_VERSION_MAJOR 4) |
69 |
set(CPACK_PACKAGE_VERSION_MINOR 2) |
70 |
set(CPACK_PACKAGE_VERSION_PATCH a) |
71 |
set(CPACK_PACKAGE_INSTALL_DIRECTORY "Radiance") |
72 |
SET(CPACK_RESOURCE_FILE_WELCOME "${radiance_SOURCE_DIR}/Welcome.txt") |
73 |
SET(CPACK_RESOURCE_FILE_README "${radiance_SOURCE_DIR}/README.txt") |
74 |
SET(CPACK_RESOURCE_FILE_LICENSE "${radiance_SOURCE_DIR}/License.txt") |
75 |
76 |
77 |
include(CPack) |
78 |
79 |
if(NOT BUILD_HEADLESS) |
80 |
find_package(Qt4 COMPONENTS QtCore QtGui) |
81 |
find_package(X11) |
82 |
endif() |
83 |
84 |
SET(EXECUTABLE_OUTPUT_PATH ${PROJECT_BINARY_DIR}/bin) |
85 |
86 |
if(WIN32 AND "${CMAKE_C_COMPILER_ID}" MATCHES "^(Intel)$") |
87 |
set(_INTEL_WINDOWS 1) |
88 |
endif() |
89 |
if(MSVC OR _INTEL_WINDOWS) |
90 |
add_definitions(-D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE) |
91 |
endif() |
92 |
if(WIN32) |
93 |
add_definitions(-DEZXML_NOMMAP -Dfseeko=fseek -Dstrcasecmp=_stricmp) |
94 |
endif() |
95 |
96 |
add_subdirectory("src") |
97 |
98 |
set(test_dir ${CMAKE_CURRENT_SOURCE_DIR}/test/test\ data) |
99 |
option(BUILD_TESTING "Download support tarball & enable testing?" ON) |
100 |
101 |
if(BUILD_TESTING) |
102 |
#download and extract radiance support files |
103 |
include(ExternalProject) |
104 |
set(base "${CMAKE_BINARY_DIR}/Downloads") |
105 |
set_property(DIRECTORY PROPERTY EP_BASE ${base}) |
106 |
ExternalProject_Add(radiance_support |
107 |
URL http://www.radiance-online.org/software/non-cvs/rad4R1supp.tar.gz |
108 |
URL_MD5 efd82970e1d0747eede8eb64c01048f4 |
109 |
CONFIGURE_COMMAND "" |
110 |
BUILD_COMMAND "" |
111 |
INSTALL_COMMAND "" |
112 |
113 |
114 |
#install support files. |
115 |
set(lib_dir ${base}/Source/radiance_support/lib) |
116 |
install( |
117 |
FILES |
118 |
${lib_dir}/Earth.cal ${lib_dir}/He.cal ${lib_dir}/He3.cal |
119 |
${lib_dir}/adobe.cal ${lib_dir}/ball.cal ${lib_dir}/brick.cal |
120 |
${lib_dir}/brickweave.cal ${lib_dir}/carpet.cal ${lib_dir}/climit.cal |
121 |
${lib_dir}/corrug.cal ${lib_dir}/covelight.cal ${lib_dir}/cyl.cal |
122 |
${lib_dir}/dichroic.cal ${lib_dir}/dirt.cal ${lib_dir}/fisheye.cal |
123 |
${lib_dir}/fishgeom.cal ${lib_dir}/fprism.cal ${lib_dir}/globe.cal |
124 |
${lib_dir}/gloss.cal ${lib_dir}/grating.cal ${lib_dir}/jigglepic.cal |
125 |
${lib_dir}/lcp0.cal ${lib_dir}/limit.cal ${lib_dir}/marble.cal |
126 |
${lib_dir}/orange.cal ${lib_dir}/picture.cal ${lib_dir}/plink.cal |
127 |
${lib_dir}/prism.cal ${lib_dir}/retrorefl.cal ${lib_dir}/serraglaze.cal |
128 |
${lib_dir}/slate.cal ${lib_dir}/surf.cal ${lib_dir}/tim1.cal |
129 |
${lib_dir}/weave.cal ${lib_dir}/winxmit.cal ${lib_dir}/woodpat.cal |
130 |
${lib_dir}/woodtex.cal ${lib_dir}/wrinkle.cal |
131 |
${lib_dir}/page1.txt ${lib_dir}/page2.txt |
132 |
${lib_dir}/Pix.fnt |
133 |
${lib_dir}/PixOblique.fnt |
134 |
${lib_dir}/Veerdana.fnt |
135 |
${lib_dir}/VeerdanaBold.fnt |
136 |
${lib_dir}/VeerdanaBoldItalic.fnt |
137 |
${lib_dir}/VeerdanaItalic.fnt |
138 |
${lib_dir}/helvet.fnt |
139 |
${lib_dir}/hexbit4x1.fnt |
140 |
${test_dir}/model.oct |
141 |
${test_dir}/model.vp |
142 |
DESTINATION lib |
143 |
144 |
145 |
install(FILES ${lib_dir}/Earth.hdr DESTINATION lib RENAME Earth.pic) |
146 |
install(FILES ${lib_dir}/EarthBig.hdr DESTINATION lib RENAME EarthBig.pic) |
147 |
install(FILES ${lib_dir}/alberta.hdr DESTINATION lib RENAME alberta.pic) |
148 |
install(FILES ${lib_dir}/brick.hdr DESTINATION lib RENAME brick.pic) |
149 |
install(FILES ${lib_dir}/brickweave.hdr DESTINATION lib RENAME brickweave.pic) |
150 |
install(FILES ${lib_dir}/cabin.hdr DESTINATION lib RENAME cabin.pic) |
151 |
install(FILES ${lib_dir}/forestfl.hdr DESTINATION lib RENAME forestfl.pic) |
152 |
install(FILES ${lib_dir}/oakfloor.hdr DESTINATION lib RENAME oakfloor.pic) |
153 |
install(FILES ${lib_dir}/pine.hdr DESTINATION lib RENAME pine.pic) |
154 |
install(FILES ${lib_dir}/pinebark.hdr DESTINATION lib RENAME pinebark.pic) |
155 |
install(FILES ${lib_dir}/podlife.hdr DESTINATION lib RENAME podlife.pic) |
156 |
install(FILES ${lib_dir}/richgrove.hdr DESTINATION lib RENAME richgrove.pic) |
157 |
install(FILES ${lib_dir}/shingle.hdr DESTINATION lib RENAME shingle.pic) |
158 |
install(FILES ${lib_dir}/summercab.hdr DESTINATION lib RENAME summercab.pic) |
159 |
install(FILES ${lib_dir}/tulips.hdr DESTINATION lib RENAME tulips.pic) |
160 |
161 |
add_subdirectory(cmake_tests) |
162 |
endif() |
163 |
164 |
install( |
165 |
FILES |
166 |
167 |
168 |
DESTINATION lib |
169 |
170 |
171 |
include(InstallRequiredSystemLibraries) |
172 |
add_subdirectory(InstallRules) |
