| 1 |
cmake_minimum_required(VERSION 2.8.4)
| 2 |
project("radiance")
| 3 |
| 4 |
enable_testing()
| 5 |
include(CTest)
| 6 |
| 7 |
option(BUILD_SHARED_LIBS "Build radiance using shared libraries?" OFF)
| 8 |
| 9 |
if(NOT WIN32)
| 10 |
set(CPACK_INCLUDE_TOPLEVEL_DIRECTORY 1)
| 11 |
install(DIRECTORY ${CMAKE_CURRENT_SOURCE_DIR}/doc/man/ DESTINATION man)
| 12 |
set(qt_plugin_term "PLUGIN")
| 13 |
endif()
| 14 |
| 15 |
| 16 |
if (WIN32)
| 17 |
| 18 |
set(CPACK_NSIS_MODIFY_PATH 0)
| 19 |
| 20 |
set(CPACK_BINARY_ZIP 1)
| 21 |
| 22 |
set(CPACK_NSIS_EXTRA_INSTALL_COMMANDS "")
| 23 |
set(qt_plugin_term "LIBRARY")
| 24 |
| 25 |
endif()
| 26 |
| 27 |
if(UNIX)
| 28 |
set(CPACK_PACKAGING_INSTALL_PREFIX "/usr/local/radiance")
| 29 |
add_definitions(-Dlinux -D_FILE_OFFSET_BITS=64 -DNOSTEREO)
| 30 |
else()
| 31 |
set(CPACK_PACKAGING_INSTALL_PREFIX "/")
| 32 |
endif()
| 33 |
| 34 |
if(APPLE)
| 35 |
add_definitions(-DBSD -DNOSTEREO -Dfreebsd)
| 36 |
include_directories(/usr/X11R6/include)
| 37 |
endif()
| 38 |
| 39 |
IF( BUILD_PACKAGE )
| 40 |
INCLUDE(radianceCPack.cmake )
| 41 |
ENDIF( BUILD_PACKAGE )
| 42 |
| 43 |
set(CPACK_PACKAGE_VERSION_MAJOR 4)
| 44 |
set(CPACK_PACKAGE_VERSION_MINOR 2)
| 45 |
set(CPACK_PACKAGE_VERSION_PATCH a)
| 46 |
set(CPACK_PACKAGE_INSTALL_DIRECTORY "Radiance")
| 47 |
SET(CPACK_RESOURCE_FILE_WELCOME "${radiance_SOURCE_DIR}/Welcome.txt")
| 48 |
SET(CPACK_RESOURCE_FILE_README "${radiance_SOURCE_DIR}/README.txt")
| 49 |
SET(CPACK_RESOURCE_FILE_LICENSE "${radiance_SOURCE_DIR}/License.txt")
| 50 |
| 51 |
| 52 |
include(CPack)
| 53 |
| 54 |
find_package(Qt4 COMPONENTS QtCore QtGui)
| 55 |
find_package(X11)
| 56 |
| 57 |
SET(EXECUTABLE_OUTPUT_PATH ${PROJECT_BINARY_DIR}/bin)
| 58 |
| 59 |
if(WIN32 AND "${CMAKE_C_COMPILER_ID}" MATCHES "^(Intel)$")
| 60 |
set(_INTEL_WINDOWS 1)
| 61 |
endif()
| 62 |
if(MSVC OR _INTEL_WINDOWS)
| 63 |
add_definitions(-D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE)
| 64 |
endif()
| 65 |
if(WIN32)
| 66 |
add_definitions(-DEZXML_NOMMAP -Dfseeko=fseek -Dstrcasecmp=_stricmp)
| 67 |
endif()
| 68 |
| 69 |
add_subdirectory("src")
| 70 |
| 71 |
set(test_dir ${CMAKE_CURRENT_SOURCE_DIR}/test/test\ data)
| 72 |
option(BUILD_TESTING "Download support tarball & enable testing?" ON)
| 73 |
| 74 |
if(BUILD_TESTING)
| 75 |
#download and extract radiance support files
| 76 |
include(ExternalProject)
| 77 |
set(base "${CMAKE_BINARY_DIR}/Downloads")
| 78 |
set_property(DIRECTORY PROPERTY EP_BASE ${base})
| 79 |
ExternalProject_Add(radiance_support
| 80 |
URL http://www.radiance-online.org/software/non-cvs/rad4R1supp.tar.gz
| 81 |
URL_MD5 efd82970e1d0747eede8eb64c01048f4
| 82 |
CONFIGURE_COMMAND ""
| 83 |
BUILD_COMMAND ""
| 84 |
INSTALL_COMMAND ""
| 85 |
| 86 |
| 87 |
#install support files.
| 88 |
set(lib_dir ${base}/Source/radiance_support/lib)
| 89 |
install(
| 90 |
FILES
| 91 |
${lib_dir}/Earth.cal ${lib_dir}/He.cal ${lib_dir}/He3.cal
| 92 |
${lib_dir}/adobe.cal ${lib_dir}/ball.cal ${lib_dir}/brick.cal
| 93 |
${lib_dir}/brickweave.cal ${lib_dir}/carpet.cal ${lib_dir}/climit.cal
| 94 |
${lib_dir}/corrug.cal ${lib_dir}/covelight.cal ${lib_dir}/cyl.cal
| 95 |
${lib_dir}/dichroic.cal ${lib_dir}/dirt.cal ${lib_dir}/fisheye.cal
| 96 |
${lib_dir}/fishgeom.cal ${lib_dir}/fprism.cal ${lib_dir}/globe.cal
| 97 |
${lib_dir}/gloss.cal ${lib_dir}/grating.cal ${lib_dir}/jigglepic.cal
| 98 |
${lib_dir}/lcp0.cal ${lib_dir}/limit.cal ${lib_dir}/marble.cal
| 99 |
${lib_dir}/orange.cal ${lib_dir}/picture.cal ${lib_dir}/plink.cal
| 100 |
${lib_dir}/prism.cal ${lib_dir}/retrorefl.cal ${lib_dir}/serraglaze.cal
| 101 |
${lib_dir}/slate.cal ${lib_dir}/surf.cal ${lib_dir}/tim1.cal
| 102 |
${lib_dir}/weave.cal ${lib_dir}/winxmit.cal ${lib_dir}/woodpat.cal
| 103 |
${lib_dir}/woodtex.cal ${lib_dir}/wrinkle.cal
| 104 |
${lib_dir}/page1.txt ${lib_dir}/page2.txt
| 105 |
${lib_dir}/Pix.fnt
| 106 |
${lib_dir}/PixOblique.fnt
| 107 |
${lib_dir}/Veerdana.fnt
| 108 |
${lib_dir}/VeerdanaBold.fnt
| 109 |
${lib_dir}/VeerdanaBoldItalic.fnt
| 110 |
${lib_dir}/VeerdanaItalic.fnt
| 111 |
${lib_dir}/helvet.fnt
| 112 |
${lib_dir}/hexbit4x1.fnt
| 113 |
${test_dir}/model.oct
| 114 |
${test_dir}/model.vp
| 115 |
DESTINATION lib
| 116 |
| 117 |
| 118 |
install(FILES ${lib_dir}/Earth.hdr DESTINATION lib RENAME Earth.pic)
| 119 |
install(FILES ${lib_dir}/EarthBig.hdr DESTINATION lib RENAME EarthBig.pic)
| 120 |
install(FILES ${lib_dir}/alberta.hdr DESTINATION lib RENAME alberta.pic)
| 121 |
install(FILES ${lib_dir}/brick.hdr DESTINATION lib RENAME brick.pic)
| 122 |
install(FILES ${lib_dir}/brickweave.hdr DESTINATION lib RENAME brickweave.pic)
| 123 |
install(FILES ${lib_dir}/cabin.hdr DESTINATION lib RENAME cabin.pic)
| 124 |
install(FILES ${lib_dir}/forestfl.hdr DESTINATION lib RENAME forestfl.pic)
| 125 |
install(FILES ${lib_dir}/oakfloor.hdr DESTINATION lib RENAME oakfloor.pic)
| 126 |
install(FILES ${lib_dir}/pine.hdr DESTINATION lib RENAME pine.pic)
| 127 |
install(FILES ${lib_dir}/pinebark.hdr DESTINATION lib RENAME pinebark.pic)
| 128 |
install(FILES ${lib_dir}/podlife.hdr DESTINATION lib RENAME podlife.pic)
| 129 |
install(FILES ${lib_dir}/richgrove.hdr DESTINATION lib RENAME richgrove.pic)
| 130 |
install(FILES ${lib_dir}/shingle.hdr DESTINATION lib RENAME shingle.pic)
| 131 |
install(FILES ${lib_dir}/summercab.hdr DESTINATION lib RENAME summercab.pic)
| 132 |
install(FILES ${lib_dir}/tulips.hdr DESTINATION lib RENAME tulips.pic)
| 133 |
| 134 |
add_subdirectory(cmake_tests)
| 135 |
endif()
| 136 |
| 137 |
install(
| 138 |
FILES
| 139 |
| 140 |
| 141 |
DESTINATION lib
| 142 |
| 143 |
| 144 |
include(InstallRequiredSystemLibraries)
| 145 |
add_subdirectory(InstallRules)
