root/radiance/ray/CMakeLists.txt
Revision: 1.4
Committed: Wed Apr 25 22:21:06 2012 UTC (13 years, 2 months ago) by greg
Changes since 1.3: +51 -24 lines
1 cmake_minimum_required(VERSION 2.8.4)
2 project("radiance")
3
4 enable_testing()
5 include(CTest)
6
7 option(BUILD_SHARED_LIBS "Build radiance using shared libraries?" OFF)
8
9 if(NOT WIN32)
10 set(CPACK_INCLUDE_TOPLEVEL_DIRECTORY 1)
11 install(DIRECTORY ${CMAKE_CURRENT_SOURCE_DIR}/doc/man/ DESTINATION man)
12 endif()
13
14
15 if (WIN32)
16
17 set(CPACK_NSIS_MODIFY_PATH 0)
18
19 set(CPACK_BINARY_ZIP 1)
20
21 set(CPACK_NSIS_EXTRA_INSTALL_COMMANDS "")
22
23 endif()
24
25 if(UNIX)
26 set(CPACK_PACKAGING_INSTALL_PREFIX "/usr/local/radiance")
27 add_definitions(-Dlinux -D_FILE_OFFSET_BITS=64 -DNOSTEREO)
28 else()
29 set(CPACK_PACKAGING_INSTALL_PREFIX "/radiance")
30 endif()
31
32 if(APPLE)
33 add_definitions(-DBSD -DNOSTEREO -Dfreebsd)
34 include_directories(/usr/X11R6/include)
35 endif()
36
37 set(CPACK_PACKAGE_VERSION_MAJOR 4)
38 set(CPACK_PACKAGE_VERSION_MINOR 2)
39 set(CPACK_PACKAGE_VERSION_PATCH a)
40 set(CPACK_PACKAGE_INSTALL_DIRECTORY "Radiance ${CPACK_PACKAGE_VERSION_MAJOR}.${CPACK_PACKAGE_VERSION_MINOR}${CPACK_PACKAGE_VERSION_PATCH}")
41 SET(CPACK_RESOURCE_FILE_WELCOME "${radiance_SOURCE_DIR}/Welcome.txt")
42 SET(CPACK_RESOURCE_FILE_README "${radiance_SOURCE_DIR}/README.txt")
43 SET(CPACK_RESOURCE_FILE_LICENSE "${radiance_SOURCE_DIR}/License.txt")
44
45
46 include(CPack)
47
48 find_package(Qt4 COMPONENTS QtCore QtGui)
49 find_package(X11)
50
51 SET(EXECUTABLE_OUTPUT_PATH ${PROJECT_BINARY_DIR}/bin)
52
53 if(WIN32 AND "${CMAKE_C_COMPILER_ID}" MATCHES "^(Intel)$")
54 set(_INTEL_WINDOWS 1)
55 endif()
56 if(MSVC OR _INTEL_WINDOWS)
57 add_definitions(-D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE)
58 endif()
59 if(WIN32)
60 add_definitions(-DEZXML_NOMMAP -Dfseeko=fseek -Dstrcasecmp=_stricmp)
61 endif()
62
63 add_subdirectory("src")
64
65 #download and extract radiance support files
66 include(ExternalProject)
67 set(base "${CMAKE_BINARY_DIR}/Downloads")
68 set_property(DIRECTORY PROPERTY EP_BASE ${base})
69 ExternalProject_Add(radiance_support
70 URL http://www.radiance-online.org/software/non-cvs/rad4R1supp.tar.gz
71 URL_MD5 efd82970e1d0747eede8eb64c01048f4
72 CONFIGURE_COMMAND ""
73 BUILD_COMMAND ""
74 INSTALL_COMMAND ""
75 )
76
77 #install support files.
78 set(lib_dir ${base}/Source/radiance_support/lib)
79 set(test_dir ${CMAKE_CURRENT_SOURCE_DIR}/test/test\ data)
80 install(
81 FILES
82 ${lib_dir}/Earth.cal ${lib_dir}/He.cal ${lib_dir}/He3.cal
83 ${lib_dir}/adobe.cal ${lib_dir}/ball.cal ${lib_dir}/brick.cal
84 ${lib_dir}/brickweave.cal ${lib_dir}/carpet.cal ${lib_dir}/climit.cal
85 ${lib_dir}/corrug.cal ${lib_dir}/covelight.cal ${lib_dir}/cyl.cal
86 ${lib_dir}/dichroic.cal ${lib_dir}/dirt.cal ${lib_dir}/fisheye.cal
87 ${lib_dir}/fishgeom.cal ${lib_dir}/fprism.cal ${lib_dir}/globe.cal
88 ${lib_dir}/gloss.cal ${lib_dir}/grating.cal ${lib_dir}/jigglepic.cal
89 ${lib_dir}/lcp0.cal ${lib_dir}/limit.cal ${lib_dir}/marble.cal
90 ${lib_dir}/orange.cal ${lib_dir}/picture.cal ${lib_dir}/plink.cal
91 ${lib_dir}/prism.cal ${lib_dir}/retrorefl.cal ${lib_dir}/serraglaze.cal
92 ${lib_dir}/slate.cal ${lib_dir}/surf.cal ${lib_dir}/tim1.cal
93 ${lib_dir}/weave.cal ${lib_dir}/winxmit.cal ${lib_dir}/woodpat.cal
94 ${lib_dir}/woodtex.cal ${lib_dir}/wrinkle.cal
95 ${lib_dir}/page1.txt ${lib_dir}/page2.txt
96 ${lib_dir}/Pix.fnt
97 ${lib_dir}/PixOblique.fnt
98 ${lib_dir}/Veerdana.fnt
99 ${lib_dir}/VeerdanaBold.fnt
100 ${lib_dir}/VeerdanaBoldItalic.fnt
101 ${lib_dir}/VeerdanaItalic.fnt
102 ${lib_dir}/helvet.fnt
103 ${lib_dir}/hexbit4x1.fnt
104 ${test_dir}/model.oct
105 ${test_dir}/model.vp
106 DESTINATION lib
107 )
108
109 install(FILES ${lib_dir}/Earth.hdr DESTINATION lib RENAME Earth.pic)
110 install(FILES ${lib_dir}/EarthBig.hdr DESTINATION lib RENAME EarthBig.pic)
111 install(FILES ${lib_dir}/alberta.hdr DESTINATION lib RENAME alberta.pic)
112 install(FILES ${lib_dir}/brick.hdr DESTINATION lib RENAME brick.pic)
113 install(FILES ${lib_dir}/brickweave.hdr DESTINATION lib RENAME brickweave.pic)
114 install(FILES ${lib_dir}/cabin.hdr DESTINATION lib RENAME cabin.pic)
115 install(FILES ${lib_dir}/forestfl.hdr DESTINATION lib RENAME forestfl.pic)
116 install(FILES ${lib_dir}/oakfloor.hdr DESTINATION lib RENAME oakfloor.pic)
117 install(FILES ${lib_dir}/pine.hdr DESTINATION lib RENAME pine.pic)
118 install(FILES ${lib_dir}/pinebark.hdr DESTINATION lib RENAME pinebark.pic)
119 install(FILES ${lib_dir}/podlife.hdr DESTINATION lib RENAME podlife.pic)
120 install(FILES ${lib_dir}/richgrove.hdr DESTINATION lib RENAME richgrove.pic)
121 install(FILES ${lib_dir}/shingle.hdr DESTINATION lib RENAME shingle.pic)
122 install(FILES ${lib_dir}/summercab.hdr DESTINATION lib RENAME summercab.pic)
123 install(FILES ${lib_dir}/tulips.hdr DESTINATION lib RENAME tulips.pic)
124
125 add_subdirectory(cmake_tests)
126
127 include(InstallRequiredSystemLibraries)
128 add_subdirectory(InstallRules)
