root/radiance/ray/CMakeLists.txt
Revision: 1.31
Committed: Tue Dec 5 21:47:27 2023 UTC (5 months ago) by greg
Changes since 1.30: +4 -2 lines
chore: Added cmake support for C++ compilation
1 cmake_minimum_required(VERSION 3.12)
2 cmake_policy(SET CMP0020 NEW)
3 cmake_policy(SET CMP0048 NEW)
4 cmake_policy(SET CMP0054 NEW)
5 cmake_policy(SET CMP0074 NEW)
6
7 # project-defined modules
8 set(CMAKE_MODULE_PATH "${CMAKE_CURRENT_LIST_DIR}/resources/cmake/modules")
9
10 set(SUPPORTED_LANGUAGES C CXX)
11
12 # Get the project version.
13 set(VERSIONFILE "${CMAKE_CURRENT_LIST_DIR}/src/rt/VERSION")
14 if(EXISTS ${VERSIONFILE})
15 file(READ ${VERSIONFILE} NAMEVERSION)
16 if(${NAMEVERSION} MATCHES "^([A-Za-z]+) +([0-9]+\\.[0-9]+)")
17 # project name must be lower case, or the CPack module fails
18 string(TOLOWER ${CMAKE_MATCH_1} PROGNAME)
19 project(${PROGNAME} VERSION ${CMAKE_MATCH_2} LANGUAGES ${SUPPORTED_LANGUAGES})
20 endif()
21 else()
22 project(radiance LANGUAGES ${SUPPORTED_LANGUAGES})
23 endif()
24
25 message("Project: " ${CMAKE_PROJECT_NAME} " " ${PROJECT_VERSION})
26
27 set(PROJECT_VERSION_TWEAK "Unknown" CACHE STRING "Commit Hash")
28 find_package(Git)
29 if(GIT_FOUND)
30 execute_process(COMMAND "${GIT_EXECUTABLE}" "rev-parse" "--short=10" "HEAD"
31 WORKING_DIRECTORY "${CMAKE_SOURCE_DIR}"
32 TIMEOUT 10
33 RESULT_VARIABLE RESULT
34 OUTPUT_VARIABLE GIT_VERSION
35 ERROR_QUIET
36 OUTPUT_STRIP_TRAILING_WHITESPACE
37 )
38 if(${RESULT} EQUAL 0 AND NOT "${GIT_VERSION}" EQUAL "${PROJECT_VERSION_TWEAK}")
39 set(PROJECT_VERSION_TWEAK ${GIT_VERSION} CACHE STRING "Commit Hash" FORCE)
40 endif()
41 endif()
42
43 enable_testing()
44 include(CTest)
45
46 option(BUILD_SHARED_LIBS "Build radiance using shared libraries?" OFF)
47 option(BUILD_HEADLESS "Build radiance without any GUI components?" OFF)
48 option(BUILD_PABOPTO_UTILS "Build PABOpto Utilities?" OFF)
49 option(BUILD_LIBTIFF "Build libtiff?" OFF)
50 option(BUILD_QT "Build Qt related stuff?" OFF)
51
52 if(NOT WIN32)
53 set(CPACK_INCLUDE_TOPLEVEL_DIRECTORY 1)
54 install(DIRECTORY "${CMAKE_CURRENT_SOURCE_DIR}/doc/man/" DESTINATION man)
55 if(BUILD_QT)
56 set(qt_plugin_term "PLUGIN")
57 endif()
58 endif()
59
60 if(WIN32)
61 set(CPACK_NSIS_INSTALL_ROOT "C:")
62 set(CPACK_NSIS_MODIFY_PATH 1)
63 if(BUILD_QT)
64 set(qt_plugin_term "LIBRARY")
65 endif()
66
67 # Set RAYPATH on install
68 set(CPACK_NSIS_EXTRA_INSTALL_COMMANDS
69 "WriteRegExpandStr HKLM \\\"SYSTEM\\\\CurrentControlSet\\\\Control\\\\Session Manager\\\\Environment\\\" RAYPATH '\\\$INSTDIR\\\\lib\\\;.'"
70 )
71
72 # Unset RAYPATH on uninstall
73 set(CPACK_NSIS_EXTRA_UNINSTALL_COMMANDS
74 "DeleteRegValue HKLM \\\"SYSTEM\\\\CurrentControlSet\\\\Control\\\\Session Manager\\\\Environment\\\" RAYPATH"
75 )
76 endif()
77
78 if(UNIX)
79 set(CPACK_PACKAGING_INSTALL_PREFIX "/usr/local/radiance")
80 add_definitions(-Dlinux -D_FILE_OFFSET_BITS=64 -DNOSTEREO)
81 else()
82 set(CPACK_PACKAGING_INSTALL_PREFIX "/")
83 endif()
84
85 set(CPACK_PACKAGE_FILE_NAME "${CMAKE_PROJECT_NAME}-${PROJECT_VERSION_MAJOR}.${PROJECT_VERSION_MINOR}.${PROJECT_VERSION_TWEAK}-${CMAKE_SYSTEM_NAME}")
86
87 if(APPLE)
88 set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -std=c11 -std=c++11 -stdlib=libc++")
89 add_definitions(-DBSD -DNOSTEREO -Dfreebsd)
90 set(CMAKE_OSX_DEPLOYMENT_TARGET "10.13")
91 endif()
92
93 if(BUILD_LIBTIFF)
94 include(ExternalProject)
95 set(LIBTIFF_URL http://download.osgeo.org/libtiff/tiff-4.0.9.tar.gz)
96 set(LIBTIFF_MD5 54BAD211279CC93EB4FCA31BA9BFDC79)
97 if(WIN32)
98 ExternalProject_Add(libtiff
99 URL ${LIBTIFF_URL}
100 URL_MD5 ${LIBTIFF_MD5}
101 CMAKE_GENERATOR "NMake Makefiles"
102 CMAKE_ARGS
103 "-UHAVE_UNISTD_H"
104 "-DBUILD_SHARED_LIBS=OFF"
105 "-DCMAKE_BUILD_TYPE=Release"
106 "-Dzlib=OFF"
107 "../libtiff"
108 INSTALL_COMMAND ""
109 )
110 set(TIFF_LIBRARY ${CMAKE_BINARY_DIR}/libtiff-prefix/src/libtiff-build/libtiff/tiff.lib)
111 else()
112 ExternalProject_Add(libtiff
113 URL ${LIBTIFF_URL}
114 URL_MD5 ${LIBTIFF_MD5}
115 CMAKE_ARGS
116 "-DBUILD_SHARED_LIBS=OFF"
117 "-DCMAKE_BUILD_TYPE=Release"
118 "-Dzlib=OFF"
119 "../libtiff"
120 INSTALL_COMMAND ""
121 )
122 set(TIFF_LIBRARY ${CMAKE_BINARY_DIR}/libtiff-prefix/src/libtiff-build/libtiff/libtiff.a)
123 endif()
124 set(TIFF_INCLUDE_DIR ${CMAKE_BINARY_DIR}/libtiff/src/libtiff/libtiff)
125 endif()
126
127 set(CPACK_PACKAGE_VERSION_MAJOR ${PROJECT_VERSION_MAJOR})
128 set(CPACK_PACKAGE_VERSION_MINOR ${PROJECT_VERSION_MINOR})
129 set(CPACK_PACKAGE_INSTALL_DIRECTORY "Radiance")
130 set(CPACK_RESOURCE_FILE_WELCOME "${radiance_SOURCE_DIR}/Welcome.txt")
131 set(CPACK_RESOURCE_FILE_README "${radiance_SOURCE_DIR}/README.txt")
132 set(CPACK_RESOURCE_FILE_LICENSE "${radiance_SOURCE_DIR}/License.txt")
133
134 if(APPLE)
135 set(CPACK_GENERATOR "PackageMaker")
136 elseif(UNIX)
137 set(CPACK_GENERATOR "TGZ")
138 endif()
139
140 include(CPack)
141
142 if(NOT BUILD_HEADLESS)
143 if(BUILD_QT)
144 find_package(Qt5Widgets)
145 get_target_property(QT_LIBRARY_DIR Qt5::Core LOCATION)
146 get_filename_component(QT_LIBRARY_DIR ${QT_LIBRARY_DIR} PATH)
147 get_filename_component(QT_LIBRARY_DIR "${QT_LIBRARY_DIR}/.." ABSOLUTE)
148 endif()
149 if(APPLE)
150 set(X11_ROOT "/opt/X11")
151 endif()
152 find_package(X11)
153 if(APPLE)
154 include_directories(${X11_INCLUDE_DIR})
155 endif()
156 if(APPLE AND X11_FOUND)
157 set(CMAKE_FIND_FRAMEWORK NEVER)
158 set(OpenGL_ROOT "/opt/X11")
159 find_package(OpenGL)
160 set(CMAKE_FIND_FRAMEWORK "")
161 else()
162 find_package(OpenGL)
163 endif()
164
165 endif()
166
167 set(EXECUTABLE_OUTPUT_PATH ${PROJECT_BINARY_DIR}/bin)
168
169 if(MSVC)
170 add_definitions(/MP)
171 # Suppress warnings about double-to-float assignments and initializations
172 add_compile_options(/wd"4244" /wd"4305")
173 endif()
174 if(WIN32 AND "${CMAKE_C_COMPILER_ID}" MATCHES "^(Intel)$")
175 set(_INTEL_WINDOWS 1)
176 endif()
177 if(MSVC OR _INTEL_WINDOWS)
178 add_definitions(-D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE)
179 endif()
180 if(WIN32)
181 add_definitions(-DEZXML_NOMMAP -Dfseeko=fseek -Dstrcasecmp=_stricmp)
182 endif()
183
184 add_subdirectory("src")
185
186 set(test_dir "${CMAKE_CURRENT_SOURCE_DIR}/test/test data")
187
188 add_subdirectory(resources)
189
190 install(DIRECTORY "${CMAKE_BINARY_DIR}/lib/"
191 DESTINATION "lib"
192 )
193
194 # copy make tests to build
195 file(COPY test DESTINATION ${CMAKE_BINARY_DIR})
196
197
198 include(InstallRequiredSystemLibraries)
199 add_subdirectory(InstallRules)
