root/radiance/ray/CMakeLists.txt
Revision: 1.27
Committed: Tue May 16 22:58:18 2023 UTC (23 months, 2 weeks ago) by greg
Changes since 1.26: +9 -2 lines
chore: Removed qt from macOS X and Linux builds as it was having issues
1 cmake_minimum_required(VERSION 3.0)
2 cmake_policy(SET CMP0020 NEW)
3 cmake_policy(SET CMP0048 NEW)
4 if(NOT ${CMAKE_VERSION} VERSION_LESS "3.1")
5 cmake_policy(SET CMP0054 NEW)
6 endif()
7
8 project(radiance VERSION 5.2.0)
9
10 set(PROJECT_VERSION_TWEAK "Unknown" CACHE STRING "Commit Hash")
11 find_package(Git)
12 if(GIT_FOUND)
13 execute_process(COMMAND "${GIT_EXECUTABLE}" "rev-parse" "--short=10" "HEAD"
14 WORKING_DIRECTORY "${CMAKE_SOURCE_DIR}"
15 TIMEOUT 10
16 RESULT_VARIABLE RESULT
17 OUTPUT_VARIABLE GIT_VERSION
18 ERROR_QUIET
19 OUTPUT_STRIP_TRAILING_WHITESPACE
20 )
21 if(${RESULT} EQUAL 0 AND NOT "${GIT_VERSION}" EQUAL "${PROJECT_VERSION_TWEAK}")
22 set(PROJECT_VERSION_TWEAK ${GIT_VERSION} CACHE STRING "Commit Hash" FORCE)
23 endif()
24 endif()
25
26 enable_testing()
27 include(CTest)
28
29 option(BUILD_SHARED_LIBS "Build radiance using shared libraries?" OFF)
30 option(BUILD_HEADLESS "Build radiance without any GUI components?" OFF)
31 option(BUILD_PABOPTO_UTILS "Build PABOpto Utilities?" OFF)
32 option(BUILD_LIBTIFF "Build libtiff?" OFF)
33 option(BUILD_QT "Build Qt related stuff?" OFF)
34
35 if(NOT WIN32)
36 set(CPACK_INCLUDE_TOPLEVEL_DIRECTORY 1)
37 install(DIRECTORY "${CMAKE_CURRENT_SOURCE_DIR}/doc/man/" DESTINATION man)
38 if(BUILD_QT)
39 set(qt_plugin_term "PLUGIN")
40 endif()
41 endif()
42
43 if(WIN32)
44 set(CPACK_NSIS_INSTALL_ROOT "C:")
45 set(CPACK_NSIS_MODIFY_PATH 1)
46 if(BUILD_QT)
47 set(qt_plugin_term "LIBRARY")
48 endif()
49
50 # Set RAYPATH on install
51 set(CPACK_NSIS_EXTRA_INSTALL_COMMANDS
52 "WriteRegExpandStr HKLM \\\"SYSTEM\\\\CurrentControlSet\\\\Control\\\\Session Manager\\\\Environment\\\" RAYPATH '\\\$INSTDIR\\\\lib\\\;.'"
53 )
54
55 # Unset RAYPATH on uninstall
56 set(CPACK_NSIS_EXTRA_UNINSTALL_COMMANDS
57 "DeleteRegValue HKLM \\\"SYSTEM\\\\CurrentControlSet\\\\Control\\\\Session Manager\\\\Environment\\\" RAYPATH"
58 )
59 endif()
60
61 if(UNIX)
62 set(CPACK_PACKAGING_INSTALL_PREFIX "/usr/local/radiance")
63 add_definitions(-Dlinux -D_FILE_OFFSET_BITS=64 -DNOSTEREO)
64 else()
65 set(CPACK_PACKAGING_INSTALL_PREFIX "/")
66 endif()
67
68 set(CPACK_PACKAGE_FILE_NAME "${CMAKE_PROJECT_NAME}-${PROJECT_VERSION_MAJOR}.${PROJECT_VERSION_MINOR}.${PROJECT_VERSION_TWEAK}-${CMAKE_SYSTEM_NAME}")
69
70 if(APPLE)
71 set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -std=c11 -std=c++11 -stdlib=libc++")
72 add_definitions(-DBSD -DNOSTEREO -Dfreebsd)
73 set(CMAKE_C_FLAGS "${CMAKE_C_FLAGS} -mmacosx-version-min=10.7")
74 endif()
75
76 if(BUILD_LIBTIFF)
77 include(ExternalProject)
78 set(LIBTIFF_URL http://download.osgeo.org/libtiff/tiff-4.0.9.tar.gz)
79 set(LIBTIFF_MD5 54BAD211279CC93EB4FCA31BA9BFDC79)
80 if(WIN32)
81 ExternalProject_Add(libtiff
82 URL ${LIBTIFF_URL}
83 URL_MD5 ${LIBTIFF_MD5}
84 CMAKE_GENERATOR "NMake Makefiles"
85 CMAKE_ARGS
86 "-UHAVE_UNISTD_H"
87 "-DBUILD_SHARED_LIBS=OFF"
88 "-DCMAKE_BUILD_TYPE=Release"
89 "-Dzlib=OFF"
90 "../libtiff"
91 INSTALL_COMMAND ""
92 )
93 set(TIFF_LIBRARY ${CMAKE_BINARY_DIR}/libtiff-prefix/src/libtiff-build/libtiff/tiff.lib)
94 else()
95 ExternalProject_Add(libtiff
96 URL ${LIBTIFF_URL}
97 URL_MD5 ${LIBTIFF_MD5}
98 CMAKE_ARGS
99 "-DBUILD_SHARED_LIBS=OFF"
100 "-DCMAKE_BUILD_TYPE=Release"
101 "-Dzlib=OFF"
102 "../libtiff"
103 INSTALL_COMMAND ""
104 )
105 set(TIFF_LIBRARY ${CMAKE_BINARY_DIR}/libtiff-prefix/src/libtiff-build/libtiff/libtiff.a)
106 endif()
107 set(TIFF_INCLUDE_DIR ${CMAKE_BINARY_DIR}/libtiff/src/libtiff/libtiff)
108 endif()
109
110 set(CPACK_PACKAGE_VERSION_MAJOR ${PROJECT_VERSION_MAJOR})
111 set(CPACK_PACKAGE_VERSION_MINOR ${PROJECT_VERSION_MINOR})
112 set(CPACK_PACKAGE_INSTALL_DIRECTORY "Radiance")
113 set(CPACK_RESOURCE_FILE_WELCOME "${radiance_SOURCE_DIR}/Welcome.txt")
114 set(CPACK_RESOURCE_FILE_README "${radiance_SOURCE_DIR}/README.txt")
115 set(CPACK_RESOURCE_FILE_LICENSE "${radiance_SOURCE_DIR}/License.txt")
116
117 if(APPLE)
118 set(CPACK_GENERATOR "PackageMaker")
119 elseif(UNIX)
120 set(CPACK_GENERATOR "TGZ")
121 endif()
122
123 include(CPack)
124
125 if(NOT BUILD_HEADLESS)
126 if(BUILD_QT)
127 find_package(Qt5Widgets)
128 get_target_property(QT_LIBRARY_DIR Qt5::Core LOCATION)
129 get_filename_component(QT_LIBRARY_DIR ${QT_LIBRARY_DIR} PATH)
130 get_filename_component(QT_LIBRARY_DIR "${QT_LIBRARY_DIR}/.." ABSOLUTE)
131 endif()
132 find_package(X11)
133 if(APPLE)
134 include_directories(${X11_INCLUDE_DIR})
135 endif()
136 endif()
137
138 set(EXECUTABLE_OUTPUT_PATH ${PROJECT_BINARY_DIR}/bin)
139
140 if(MSVC)
141 add_definitions(/MP)
142 # Suppress warnings about double-to-float assignments and initializations
143 add_compile_options(/wd"4244" /wd"4305")
144 endif()
145 if(WIN32 AND "${CMAKE_C_COMPILER_ID}" MATCHES "^(Intel)$")
146 set(_INTEL_WINDOWS 1)
147 endif()
148 if(MSVC OR _INTEL_WINDOWS)
149 add_definitions(-D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE)
150 endif()
151 if(WIN32)
152 add_definitions(-DEZXML_NOMMAP -Dfseeko=fseek -Dstrcasecmp=_stricmp)
153 endif()
154
155 add_subdirectory("src")
156
157 set(test_dir "${CMAKE_CURRENT_SOURCE_DIR}/test/test data")
158
159 add_subdirectory(resources)
160
161 install(DIRECTORY "${CMAKE_BINARY_DIR}/lib/"
162 DESTINATION "lib"
163 )
164
165 # copy make tests to build
166 file(COPY test DESTINATION ${CMAKE_BINARY_DIR})
167
168
169 include(InstallRequiredSystemLibraries)
170 add_subdirectory(InstallRules)
