root/radiance/ray/CMakeLists.txt
Revision: 1.15
Committed: Fri May 8 18:07:38 2015 UTC (9 years ago) by greg
Changes since 1.14: +11 -1 lines
Fixes for rvu under Windows
1 cmake_minimum_required(VERSION 2.8.4)
2 project("radiance")
3
4 if(NOT ${CMAKE_VERSION} VERSION_LESS "2.8.11")
5 cmake_policy(SET CMP0020 NEW)
6 if(NOT ${CMAKE_VERSION} VERSION_LESS "3.0")
7 cmake_policy(SET CMP0042 NEW)
8 if(NOT ${CMAKE_VERSION} VERSION_LESS "3.1")
9 cmake_policy(SET CMP0054 NEW)
10 endif()
11 endif()
12 endif()
13
14 enable_testing()
15 include(CTest)
16
17 option(BUILD_SHARED_LIBS "Build radiance using shared libraries?" OFF)
18 option(BUILD_HEADLESS "Build radiance without any GUI components?" OFF)
19
20 option(CPACK_NREL_SUPPORT "Include OpenStudio ToolFinder Help?" OFF)
21
22 if( CPACK_NREL_SUPPORT )
23 # find git so we can query for the current git tag
24 find_program(git git)
25 if (NOT git)
26 message(ERROR "Please specify the path to the git executable")
27 endif()
28
29 # call git log to get output containing the tag
30 execute_process(
31 COMMAND ${git} describe --tag --exact-match
32 WORKING_DIRECTORY ${CMAKE_SOURCE_DIR}
33 OUTPUT_VARIABLE git_tag_output)
34
35 # create & install the source version .txt file
36 file(WRITE "NREL_ver.txt" "Radiance version ${git_tag_output}")
37 install(FILES NREL_ver.txt DESTINATION bin/..)
38 endif()
39
40 if(NOT WIN32)
41 set(CPACK_INCLUDE_TOPLEVEL_DIRECTORY 1)
42 install(DIRECTORY ${CMAKE_CURRENT_SOURCE_DIR}/doc/man/ DESTINATION man)
43 set(qt_plugin_term "PLUGIN")
44 endif()
45
46 if (WIN32)
47 set(CPACK_NSIS_MODIFY_PATH 1)
48 set(qt_plugin_term "LIBRARY")
49
50 # Set RAYPATH on install
51 set(CPACK_NSIS_EXTRA_INSTALL_COMMANDS
52 "WriteRegExpandStr HKLM \\\"SYSTEM\\\\CurrentControlSet\\\\Control\\\\Session Manager\\\\Environment\\\" RAYPATH '\\\$INSTDIR\\\\lib\\\;.'"
53 )
54
55 # Unset RAYPATH on uninstall
56 set(CPACK_NSIS_EXTRA_UNINSTALL_COMMANDS
57 "DeleteRegValue HKLM \\\"SYSTEM\\\\CurrentControlSet\\\\Control\\\\Session Manager\\\\Environment\\\" RAYPATH"
58 )
59 endif()
60
61 if(UNIX)
62 set(CPACK_PACKAGING_INSTALL_PREFIX "/usr/local/radiance")
63 add_definitions(-Dlinux -D_FILE_OFFSET_BITS=64 -DNOSTEREO)
64 else()
65 set(CPACK_PACKAGING_INSTALL_PREFIX "/")
66 endif()
67
68 if(APPLE)
69 add_definitions(-DBSD -DNOSTEREO -Dfreebsd)
70 include_directories(/usr/X11R6/include)
71 SET(CMAKE_C_FLAGS "${CMAKE_C_FLAGS} -mmacosx-version-min=10.6")
72 endif()
73
74 IF( BUILD_PACKAGE )
75 INCLUDE(radianceCPack.cmake )
76 ENDIF( BUILD_PACKAGE )
77
78 set(CPACK_PACKAGE_VERSION_MAJOR 5)
79 set(CPACK_PACKAGE_VERSION_MINOR 0)
80 set(CPACK_PACKAGE_VERSION_PATCH a)
81 set(CPACK_PACKAGE_INSTALL_DIRECTORY "Radiance")
82 SET(CPACK_RESOURCE_FILE_WELCOME "${radiance_SOURCE_DIR}/Welcome.txt")
83 SET(CPACK_RESOURCE_FILE_README "${radiance_SOURCE_DIR}/README.txt")
84 SET(CPACK_RESOURCE_FILE_LICENSE "${radiance_SOURCE_DIR}/License.txt")
85
86
87 include(CPack)
88
89 if(NOT BUILD_HEADLESS)
90 find_package(Qt5Widgets)
91 find_package(X11)
92 endif()
93
94 SET(EXECUTABLE_OUTPUT_PATH ${PROJECT_BINARY_DIR}/bin)
95
96 if(WIN32 AND "${CMAKE_C_COMPILER_ID}" MATCHES "^(Intel)$")
97 set(_INTEL_WINDOWS 1)
98 endif()
99 if(MSVC OR _INTEL_WINDOWS)
100 add_definitions(-D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE)
101 endif()
102 if(WIN32)
103 add_definitions(-DEZXML_NOMMAP -Dfseeko=fseek -Dstrcasecmp=_stricmp)
104 endif()
105
106 add_subdirectory("src")
107
108 set(test_dir ${CMAKE_CURRENT_SOURCE_DIR}/test/test\ data)
109 option(BUILD_TESTING "Download support tarball & enable testing?" ON)
110
111 if(BUILD_TESTING)
112 #download and extract radiance support files
113 include(ExternalProject)
114 set(base "${CMAKE_BINARY_DIR}/Downloads")
115 set_property(DIRECTORY PROPERTY EP_BASE ${base})
116 ExternalProject_Add(radiance_support
117 URL http://www.radiance-online.org/software/non-cvs/rad4R1supp.tar.gz
118 URL_MD5 efd82970e1d0747eede8eb64c01048f4
119 CONFIGURE_COMMAND ""
120 BUILD_COMMAND ""
121 INSTALL_COMMAND ""
122 )
123
124 #install support files.
125 set(lib_dir ${base}/Source/radiance_support/lib)
126 install(
127 FILES
128 ${lib_dir}/Earth.cal ${lib_dir}/He.cal ${lib_dir}/He3.cal
129 ${lib_dir}/adobe.cal ${lib_dir}/ball.cal ${lib_dir}/brick.cal
130 ${lib_dir}/brickweave.cal ${lib_dir}/carpet.cal ${lib_dir}/climit.cal
131 ${lib_dir}/corrug.cal ${lib_dir}/covelight.cal ${lib_dir}/cyl.cal
132 ${lib_dir}/dichroic.cal ${lib_dir}/dirt.cal ${lib_dir}/fisheye.cal
133 ${lib_dir}/fishgeom.cal ${lib_dir}/fprism.cal ${lib_dir}/globe.cal
134 ${lib_dir}/gloss.cal ${lib_dir}/grating.cal ${lib_dir}/jigglepic.cal
135 ${lib_dir}/lcp0.cal ${lib_dir}/limit.cal ${lib_dir}/marble.cal
136 ${lib_dir}/orange.cal ${lib_dir}/picture.cal ${lib_dir}/plink.cal
137 ${lib_dir}/prism.cal ${lib_dir}/retrorefl.cal ${lib_dir}/serraglaze.cal
138 ${lib_dir}/slate.cal ${lib_dir}/surf.cal ${lib_dir}/tim1.cal
139 ${lib_dir}/weave.cal ${lib_dir}/winxmit.cal ${lib_dir}/woodpat.cal
140 ${lib_dir}/woodtex.cal ${lib_dir}/wrinkle.cal
141 ${lib_dir}/page1.txt ${lib_dir}/page2.txt
142 ${lib_dir}/Pix.fnt
143 ${lib_dir}/PixOblique.fnt
144 ${lib_dir}/Veerdana.fnt
145 ${lib_dir}/VeerdanaBold.fnt
146 ${lib_dir}/VeerdanaBoldItalic.fnt
147 ${lib_dir}/VeerdanaItalic.fnt
148 ${lib_dir}/helvet.fnt
149 ${lib_dir}/hexbit4x1.fnt
150 ${test_dir}/model.oct
151 ${test_dir}/model.vp
152 DESTINATION lib
153 )
154
155 install(FILES ${lib_dir}/Earth.hdr DESTINATION lib RENAME Earth.pic)
156 install(FILES ${lib_dir}/EarthBig.hdr DESTINATION lib RENAME EarthBig.pic)
157 install(FILES ${lib_dir}/alberta.hdr DESTINATION lib RENAME alberta.pic)
158 install(FILES ${lib_dir}/brick.hdr DESTINATION lib RENAME brick.pic)
159 install(FILES ${lib_dir}/brickweave.hdr DESTINATION lib RENAME brickweave.pic)
160 install(FILES ${lib_dir}/cabin.hdr DESTINATION lib RENAME cabin.pic)
161 install(FILES ${lib_dir}/forestfl.hdr DESTINATION lib RENAME forestfl.pic)
162 install(FILES ${lib_dir}/oakfloor.hdr DESTINATION lib RENAME oakfloor.pic)
163 install(FILES ${lib_dir}/pine.hdr DESTINATION lib RENAME pine.pic)
164 install(FILES ${lib_dir}/pinebark.hdr DESTINATION lib RENAME pinebark.pic)
165 install(FILES ${lib_dir}/podlife.hdr DESTINATION lib RENAME podlife.pic)
166 install(FILES ${lib_dir}/richgrove.hdr DESTINATION lib RENAME richgrove.pic)
167 install(FILES ${lib_dir}/shingle.hdr DESTINATION lib RENAME shingle.pic)
168 install(FILES ${lib_dir}/summercab.hdr DESTINATION lib RENAME summercab.pic)
169 install(FILES ${lib_dir}/tulips.hdr DESTINATION lib RENAME tulips.pic)
170
171 add_subdirectory(cmake_tests)
172 endif()
173
174 install(
175 FILES
176 ${test_dir}/model.oct
177 ${test_dir}/model.vp
178 DESTINATION lib
179 )
180
181 include(InstallRequiredSystemLibraries)
182 add_subdirectory(InstallRules)
