root/radiance/ray/CMakeLists.txt
Revision: 1.10
Committed: Tue Mar 25 21:22:30 2014 UTC (11 years, 1 month ago) by greg
Changes since 1.9: +10 -6 lines
Changes to set RAYPATH on Windows platforms more reliably
1 cmake_minimum_required(VERSION 2.8.4)
2 project("radiance")
3
4 enable_testing()
5 include(CTest)
6
7 option(BUILD_SHARED_LIBS "Build radiance using shared libraries?" OFF)
8 option(BUILD_HEADLESS "Build radiance without any GUI components?" OFF)
9
10 if(NOT WIN32)
11 set(CPACK_INCLUDE_TOPLEVEL_DIRECTORY 1)
12 install(DIRECTORY ${CMAKE_CURRENT_SOURCE_DIR}/doc/man/ DESTINATION man)
13 set(qt_plugin_term "PLUGIN")
14 endif()
15
16
17 if (WIN32)
18 set(CPACK_NSIS_MODIFY_PATH 1)
19 set(qt_plugin_term "LIBRARY")
20
21 # Set RAYPATH on install
22 set(CPACK_NSIS_EXTRA_INSTALL_COMMANDS
23 "WriteRegExpandStr HKLM \\\"SYSTEM\\\\CurrentControlSet\\\\Control\\\\Session Manager\\\\Environment\\\" RAYPATH '\\\"$INSTDIR\\\\lib\\\"'"
24 )
25
26 # Unset RAYPATH on uninstall
27 set(CPACK_NSIS_EXTRA_UNINSTALL_COMMANDS
28 "DeleteRegValue HKLM \\\"SYSTEM\\\\CurrentControlSet\\\\Control\\\\Session Manager\\\\Environment\\\" RAYPATH"
29 )
30 endif()
31
32 if(UNIX)
33 set(CPACK_PACKAGING_INSTALL_PREFIX "/usr/local/radiance")
34 add_definitions(-Dlinux -D_FILE_OFFSET_BITS=64 -DNOSTEREO)
35 else()
36 set(CPACK_PACKAGING_INSTALL_PREFIX "/")
37 endif()
38
39 if(APPLE)
40 add_definitions(-DBSD -DNOSTEREO -Dfreebsd)
41 include_directories(/usr/X11R6/include)
42 SET(CMAKE_C_FLAGS "${CMAKE_C_FLAGS} -mmacosx-version-min=10.6")
43 endif()
44
45 IF( BUILD_PACKAGE )
46 INCLUDE(radianceCPack.cmake )
47 ENDIF( BUILD_PACKAGE )
48
49 set(CPACK_PACKAGE_VERSION_MAJOR 4)
50 set(CPACK_PACKAGE_VERSION_MINOR 2)
51 set(CPACK_PACKAGE_VERSION_PATCH a)
52 set(CPACK_PACKAGE_INSTALL_DIRECTORY "Radiance")
53 SET(CPACK_RESOURCE_FILE_WELCOME "${radiance_SOURCE_DIR}/Welcome.txt")
54 SET(CPACK_RESOURCE_FILE_README "${radiance_SOURCE_DIR}/README.txt")
55 SET(CPACK_RESOURCE_FILE_LICENSE "${radiance_SOURCE_DIR}/License.txt")
56
57
58 include(CPack)
59
60 if(NOT BUILD_HEADLESS)
61 find_package(Qt4 COMPONENTS QtCore QtGui)
62 find_package(X11)
63 endif()
64
65 SET(EXECUTABLE_OUTPUT_PATH ${PROJECT_BINARY_DIR}/bin)
66
67 if(WIN32 AND "${CMAKE_C_COMPILER_ID}" MATCHES "^(Intel)$")
68 set(_INTEL_WINDOWS 1)
69 endif()
70 if(MSVC OR _INTEL_WINDOWS)
71 add_definitions(-D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE)
72 endif()
73 if(WIN32)
74 add_definitions(-DEZXML_NOMMAP -Dfseeko=fseek -Dstrcasecmp=_stricmp)
75 endif()
76
77 add_subdirectory("src")
78
79 set(test_dir ${CMAKE_CURRENT_SOURCE_DIR}/test/test\ data)
80 option(BUILD_TESTING "Download support tarball & enable testing?" ON)
81
82 if(BUILD_TESTING)
83 #download and extract radiance support files
84 include(ExternalProject)
85 set(base "${CMAKE_BINARY_DIR}/Downloads")
86 set_property(DIRECTORY PROPERTY EP_BASE ${base})
87 ExternalProject_Add(radiance_support
88 URL http://www.radiance-online.org/software/non-cvs/rad4R1supp.tar.gz
89 URL_MD5 efd82970e1d0747eede8eb64c01048f4
90 CONFIGURE_COMMAND ""
91 BUILD_COMMAND ""
92 INSTALL_COMMAND ""
93 )
94
95 #install support files.
96 set(lib_dir ${base}/Source/radiance_support/lib)
97 install(
98 FILES
99 ${lib_dir}/Earth.cal ${lib_dir}/He.cal ${lib_dir}/He3.cal
100 ${lib_dir}/adobe.cal ${lib_dir}/ball.cal ${lib_dir}/brick.cal
101 ${lib_dir}/brickweave.cal ${lib_dir}/carpet.cal ${lib_dir}/climit.cal
102 ${lib_dir}/corrug.cal ${lib_dir}/covelight.cal ${lib_dir}/cyl.cal
103 ${lib_dir}/dichroic.cal ${lib_dir}/dirt.cal ${lib_dir}/fisheye.cal
104 ${lib_dir}/fishgeom.cal ${lib_dir}/fprism.cal ${lib_dir}/globe.cal
105 ${lib_dir}/gloss.cal ${lib_dir}/grating.cal ${lib_dir}/jigglepic.cal
106 ${lib_dir}/lcp0.cal ${lib_dir}/limit.cal ${lib_dir}/marble.cal
107 ${lib_dir}/orange.cal ${lib_dir}/picture.cal ${lib_dir}/plink.cal
108 ${lib_dir}/prism.cal ${lib_dir}/retrorefl.cal ${lib_dir}/serraglaze.cal
109 ${lib_dir}/slate.cal ${lib_dir}/surf.cal ${lib_dir}/tim1.cal
110 ${lib_dir}/weave.cal ${lib_dir}/winxmit.cal ${lib_dir}/woodpat.cal
111 ${lib_dir}/woodtex.cal ${lib_dir}/wrinkle.cal
112 ${lib_dir}/page1.txt ${lib_dir}/page2.txt
113 ${lib_dir}/Pix.fnt
114 ${lib_dir}/PixOblique.fnt
115 ${lib_dir}/Veerdana.fnt
116 ${lib_dir}/VeerdanaBold.fnt
117 ${lib_dir}/VeerdanaBoldItalic.fnt
118 ${lib_dir}/VeerdanaItalic.fnt
119 ${lib_dir}/helvet.fnt
120 ${lib_dir}/hexbit4x1.fnt
121 ${test_dir}/model.oct
122 ${test_dir}/model.vp
123 DESTINATION lib
124 )
125
126 install(FILES ${lib_dir}/Earth.hdr DESTINATION lib RENAME Earth.pic)
127 install(FILES ${lib_dir}/EarthBig.hdr DESTINATION lib RENAME EarthBig.pic)
128 install(FILES ${lib_dir}/alberta.hdr DESTINATION lib RENAME alberta.pic)
129 install(FILES ${lib_dir}/brick.hdr DESTINATION lib RENAME brick.pic)
130 install(FILES ${lib_dir}/brickweave.hdr DESTINATION lib RENAME brickweave.pic)
131 install(FILES ${lib_dir}/cabin.hdr DESTINATION lib RENAME cabin.pic)
132 install(FILES ${lib_dir}/forestfl.hdr DESTINATION lib RENAME forestfl.pic)
133 install(FILES ${lib_dir}/oakfloor.hdr DESTINATION lib RENAME oakfloor.pic)
134 install(FILES ${lib_dir}/pine.hdr DESTINATION lib RENAME pine.pic)
135 install(FILES ${lib_dir}/pinebark.hdr DESTINATION lib RENAME pinebark.pic)
136 install(FILES ${lib_dir}/podlife.hdr DESTINATION lib RENAME podlife.pic)
137 install(FILES ${lib_dir}/richgrove.hdr DESTINATION lib RENAME richgrove.pic)
138 install(FILES ${lib_dir}/shingle.hdr DESTINATION lib RENAME shingle.pic)
139 install(FILES ${lib_dir}/summercab.hdr DESTINATION lib RENAME summercab.pic)
140 install(FILES ${lib_dir}/tulips.hdr DESTINATION lib RENAME tulips.pic)
141
142 add_subdirectory(cmake_tests)
143 endif()
144
145 install(
146 FILES
147 ${test_dir}/model.oct
148 ${test_dir}/model.vp
149 DESTINATION lib
150 )
151
152 include(InstallRequiredSystemLibraries)
153 add_subdirectory(InstallRules)
