--- ray/CMakeLists.txt 2011/10/26 16:48:01 1.3 +++ ray/CMakeLists.txt 2014/08/21 19:38:23 1.13 @@ -5,21 +5,81 @@ enable_testing() include(CTest) option(BUILD_SHARED_LIBS "Build radiance using shared libraries?" OFF) +option(BUILD_HEADLESS "Build radiance without any GUI components?" OFF) +option(CPACK_NREL_SUPPORT "Include OpenStudio ToolFinder Help?" OFF) + +if( CPACK_NREL_SUPPORT ) + # find git so we can query for the current git tag + find_program(git git) + if (NOT git) + message(ERROR "Please specify the path to the git executable") + endif() + + # call git log to get output containing the tag + execute_process( + COMMAND ${git} describe --tag --exact-match + WORKING_DIRECTORY ${CMAKE_SOURCE_DIR} + OUTPUT_VARIABLE git_tag_output) + + # create & install the source version .txt file + file(WRITE "NREL_ver.txt" "Radiance version ${git_tag_output}") + install(FILES NREL_ver.txt DESTINATION bin/..) +endif() + if(NOT WIN32) - set(CPACK_INCLUDE_TOPLEVEL_DIRECTORY 1) + set(CPACK_INCLUDE_TOPLEVEL_DIRECTORY 1) + install(DIRECTORY ${CMAKE_CURRENT_SOURCE_DIR}/doc/man/ DESTINATION man) + set(qt_plugin_term "PLUGIN") endif() -set(CPACK_PACKAGING_INSTALL_PREFIX "/") + +if (WIN32) + set(CPACK_NSIS_MODIFY_PATH 1) + set(qt_plugin_term "LIBRARY") + + # Set RAYPATH on install + set(CPACK_NSIS_EXTRA_INSTALL_COMMANDS + "WriteRegExpandStr HKLM \\\"SYSTEM\\\\CurrentControlSet\\\\Control\\\\Session Manager\\\\Environment\\\" RAYPATH '\\\$INSTDIR\\\\lib\\\;.'" + ) + + # Unset RAYPATH on uninstall + set(CPACK_NSIS_EXTRA_UNINSTALL_COMMANDS + "DeleteRegValue HKLM \\\"SYSTEM\\\\CurrentControlSet\\\\Control\\\\Session Manager\\\\Environment\\\" RAYPATH" + ) +endif() + +if(UNIX) + set(CPACK_PACKAGING_INSTALL_PREFIX "/usr/local/radiance") + add_definitions(-Dlinux -D_FILE_OFFSET_BITS=64 -DNOSTEREO) +else() + set(CPACK_PACKAGING_INSTALL_PREFIX "/") +endif() + +if(APPLE) + add_definitions(-DBSD -DNOSTEREO -Dfreebsd) + include_directories(/usr/X11R6/include) + SET(CMAKE_C_FLAGS "${CMAKE_C_FLAGS} -mmacosx-version-min=10.6") +endif() + +IF( BUILD_PACKAGE ) + INCLUDE(radianceCPack.cmake ) +ENDIF( BUILD_PACKAGE ) + set(CPACK_PACKAGE_VERSION_MAJOR 4) -set(CPACK_PACKAGE_VERSION_MINOR 1) -set(CPACK_PACKAGE_VERSION_PATCH 0) -set(CPACK_PACKAGE_INSTALL_DIRECTORY "Radiance ${CPACK_PACKAGE_VERSION_MAJOR}.${CPACK_PACKAGE_VERSION_MINOR}.${CPACK_PACKAGE_VERSION_PATCH}") +set(CPACK_PACKAGE_VERSION_MINOR 3) +set(CPACK_PACKAGE_VERSION_PATCH a) +set(CPACK_PACKAGE_INSTALL_DIRECTORY "Radiance") SET(CPACK_RESOURCE_FILE_WELCOME "${radiance_SOURCE_DIR}/Welcome.txt") -SET(CPACK_RESOURCE_FILE_README "${radiance_SOURCE_DIR}/README") +SET(CPACK_RESOURCE_FILE_README "${radiance_SOURCE_DIR}/README.txt") SET(CPACK_RESOURCE_FILE_LICENSE "${radiance_SOURCE_DIR}/License.txt") + + include(CPack) -find_package(Qt4 COMPONENTS QtCore QtGui) +if(NOT BUILD_HEADLESS) + find_package(Qt4 COMPONENTS QtCore QtGui) + find_package(X11) +endif() SET(EXECUTABLE_OUTPUT_PATH ${PROJECT_BINARY_DIR}/bin) @@ -35,67 +95,78 @@ endif() add_subdirectory("src") -#download and extract radiance support files -include(ExternalProject) -set(base "${CMAKE_BINARY_DIR}/Downloads") -set_property(DIRECTORY PROPERTY EP_BASE ${base}) -ExternalProject_Add(radiance_support - URL http://www.radiance-online.org/software/non-cvs/rad4R0supp.tar.gz - URL_MD5 123e3e40af59c8b246e1fdbf0661e877 - CONFIGURE_COMMAND "" - BUILD_COMMAND "" - INSTALL_COMMAND "" -) - -#install support files. -set(lib_dir ${base}/Source/radiance_support/lib) set(test_dir ${CMAKE_CURRENT_SOURCE_DIR}/test/test\ data) +option(BUILD_TESTING "Download support tarball & enable testing?" ON) + +if(BUILD_TESTING) + #download and extract radiance support files + include(ExternalProject) + set(base "${CMAKE_BINARY_DIR}/Downloads") + set_property(DIRECTORY PROPERTY EP_BASE ${base}) + ExternalProject_Add(radiance_support + URL http://www.radiance-online.org/software/non-cvs/rad4R1supp.tar.gz + URL_MD5 efd82970e1d0747eede8eb64c01048f4 + CONFIGURE_COMMAND "" + BUILD_COMMAND "" + INSTALL_COMMAND "" + ) + + #install support files. + set(lib_dir ${base}/Source/radiance_support/lib) + install( + FILES + ${lib_dir}/Earth.cal ${lib_dir}/He.cal ${lib_dir}/He3.cal + ${lib_dir}/adobe.cal ${lib_dir}/ball.cal ${lib_dir}/brick.cal + ${lib_dir}/brickweave.cal ${lib_dir}/carpet.cal ${lib_dir}/climit.cal + ${lib_dir}/corrug.cal ${lib_dir}/covelight.cal ${lib_dir}/cyl.cal + ${lib_dir}/dichroic.cal ${lib_dir}/dirt.cal ${lib_dir}/fisheye.cal + ${lib_dir}/fishgeom.cal ${lib_dir}/fprism.cal ${lib_dir}/globe.cal + ${lib_dir}/gloss.cal ${lib_dir}/grating.cal ${lib_dir}/jigglepic.cal + ${lib_dir}/lcp0.cal ${lib_dir}/limit.cal ${lib_dir}/marble.cal + ${lib_dir}/orange.cal ${lib_dir}/picture.cal ${lib_dir}/plink.cal + ${lib_dir}/prism.cal ${lib_dir}/retrorefl.cal ${lib_dir}/serraglaze.cal + ${lib_dir}/slate.cal ${lib_dir}/surf.cal ${lib_dir}/tim1.cal + ${lib_dir}/weave.cal ${lib_dir}/winxmit.cal ${lib_dir}/woodpat.cal + ${lib_dir}/woodtex.cal ${lib_dir}/wrinkle.cal + ${lib_dir}/page1.txt ${lib_dir}/page2.txt + ${lib_dir}/Pix.fnt + ${lib_dir}/PixOblique.fnt + ${lib_dir}/Veerdana.fnt + ${lib_dir}/VeerdanaBold.fnt + ${lib_dir}/VeerdanaBoldItalic.fnt + ${lib_dir}/VeerdanaItalic.fnt + ${lib_dir}/helvet.fnt + ${lib_dir}/hexbit4x1.fnt + ${test_dir}/model.oct + ${test_dir}/model.vp + DESTINATION lib + ) + + install(FILES ${lib_dir}/Earth.hdr DESTINATION lib RENAME Earth.pic) + install(FILES ${lib_dir}/EarthBig.hdr DESTINATION lib RENAME EarthBig.pic) + install(FILES ${lib_dir}/alberta.hdr DESTINATION lib RENAME alberta.pic) + install(FILES ${lib_dir}/brick.hdr DESTINATION lib RENAME brick.pic) + install(FILES ${lib_dir}/brickweave.hdr DESTINATION lib RENAME brickweave.pic) + install(FILES ${lib_dir}/cabin.hdr DESTINATION lib RENAME cabin.pic) + install(FILES ${lib_dir}/forestfl.hdr DESTINATION lib RENAME forestfl.pic) + install(FILES ${lib_dir}/oakfloor.hdr DESTINATION lib RENAME oakfloor.pic) + install(FILES ${lib_dir}/pine.hdr DESTINATION lib RENAME pine.pic) + install(FILES ${lib_dir}/pinebark.hdr DESTINATION lib RENAME pinebark.pic) + install(FILES ${lib_dir}/podlife.hdr DESTINATION lib RENAME podlife.pic) + install(FILES ${lib_dir}/richgrove.hdr DESTINATION lib RENAME richgrove.pic) + install(FILES ${lib_dir}/shingle.hdr DESTINATION lib RENAME shingle.pic) + install(FILES ${lib_dir}/summercab.hdr DESTINATION lib RENAME summercab.pic) + install(FILES ${lib_dir}/tulips.hdr DESTINATION lib RENAME tulips.pic) + + add_subdirectory(cmake_tests) +endif() + install( FILES - ${lib_dir}/Earth.cal ${lib_dir}/He.cal ${lib_dir}/He3.cal - ${lib_dir}/adobe.cal ${lib_dir}/ball.cal ${lib_dir}/brick.cal - ${lib_dir}/brickweave.cal ${lib_dir}/carpet.cal ${lib_dir}/climit.cal - ${lib_dir}/corrug.cal ${lib_dir}/covelight.cal ${lib_dir}/cyl.cal - ${lib_dir}/dichroic.cal ${lib_dir}/dirt.cal ${lib_dir}/fisheye.cal - ${lib_dir}/fishgeom.cal ${lib_dir}/fprism.cal ${lib_dir}/globe.cal - ${lib_dir}/gloss.cal ${lib_dir}/grating.cal ${lib_dir}/jigglepic.cal - ${lib_dir}/lcp0.cal ${lib_dir}/limit.cal ${lib_dir}/marble.cal - ${lib_dir}/orange.cal ${lib_dir}/picture.cal ${lib_dir}/plink.cal - ${lib_dir}/prism.cal ${lib_dir}/retrorefl.cal ${lib_dir}/serraglaze.cal - ${lib_dir}/slate.cal ${lib_dir}/surf.cal ${lib_dir}/tim1.cal - ${lib_dir}/weave.cal ${lib_dir}/winxmit.cal ${lib_dir}/woodpat.cal - ${lib_dir}/woodtex.cal ${lib_dir}/wrinkle.cal - ${lib_dir}/page1.txt ${lib_dir}/page2.txt - ${lib_dir}/Pix.fnt - ${lib_dir}/PixOblique.fnt - ${lib_dir}/Veerdana.fnt - ${lib_dir}/VeerdanaBold.fnt - ${lib_dir}/VeerdanaBoldItalic.fnt - ${lib_dir}/VeerdanaItalic.fnt - ${lib_dir}/helvet.fnt - ${lib_dir}/hexbit4x1.fnt ${test_dir}/model.oct ${test_dir}/model.vp - DESTINATION bin + DESTINATION lib ) - -install(FILES ${lib_dir}/Earth.hdr DESTINATION bin RENAME Earth.pic) -install(FILES ${lib_dir}/EarthBig.hdr DESTINATION bin RENAME EarthBig.pic) -install(FILES ${lib_dir}/alberta.hdr DESTINATION bin RENAME alberta.pic) -install(FILES ${lib_dir}/brick.hdr DESTINATION bin RENAME brick.pic) -install(FILES ${lib_dir}/brickweave.hdr DESTINATION bin RENAME brickweave.pic) -install(FILES ${lib_dir}/cabin.hdr DESTINATION bin RENAME cabin.pic) -install(FILES ${lib_dir}/forestfl.hdr DESTINATION bin RENAME forestfl.pic) -install(FILES ${lib_dir}/oakfloor.hdr DESTINATION bin RENAME oakfloor.pic) -install(FILES ${lib_dir}/pine.hdr DESTINATION bin RENAME pine.pic) -install(FILES ${lib_dir}/pinebark.hdr DESTINATION bin RENAME pinebark.pic) -install(FILES ${lib_dir}/podlife.hdr DESTINATION bin RENAME podlife.pic) -install(FILES ${lib_dir}/richgrove.hdr DESTINATION bin RENAME richgrove.pic) -install(FILES ${lib_dir}/shingle.hdr DESTINATION bin RENAME shingle.pic) -install(FILES ${lib_dir}/summercab.hdr DESTINATION bin RENAME summercab.pic) -install(FILES ${lib_dir}/tulips.hdr DESTINATION bin RENAME tulips.pic) - -add_subdirectory(cmake_tests) include(InstallRequiredSystemLibraries) add_subdirectory(InstallRules)
