--- ray/CMakeLists.txt 2014/03/20 22:49:21 1.9 +++ ray/CMakeLists.txt 2014/04/16 20:48:07 1.11 @@ -7,22 +7,45 @@ include(CTest) option(BUILD_SHARED_LIBS "Build radiance using shared libraries?" OFF) option(BUILD_HEADLESS "Build radiance without any GUI components?" OFF) +option(CPACK_NREL_SUPPORT "Include OpenStudio ToolFinder Help?" OFF) + +if( CPACK_NREL_SUPPORT ) + # find git so we can query for the current git tag + find_program(git git) + if (NOT git) + message(ERROR "Please specify the path to the git executable") + endif() + + # call git log to get output containing the tag + execute_process( + COMMAND ${git} branch + WORKING_DIRECTORY ${CMAKE_SOURCE_DIR} + OUTPUT_VARIABLE git_log_output) + + # create & install the source version .txt file + file(WRITE "NREL_ver.txt" "Radiance built from source branch(*):\n ${git_log_output}") + install(FILES NREL_ver.txt DESTINATION bin/..) +endif() + if(NOT WIN32) set(CPACK_INCLUDE_TOPLEVEL_DIRECTORY 1) install(DIRECTORY ${CMAKE_CURRENT_SOURCE_DIR}/doc/man/ DESTINATION man) set(qt_plugin_term "PLUGIN") endif() - if (WIN32) - - set(CPACK_NSIS_MODIFY_PATH 0) - - set(CPACK_BINARY_ZIP 1) - - set(CPACK_NSIS_EXTRA_INSTALL_COMMANDS "") + set(CPACK_NSIS_MODIFY_PATH 1) set(qt_plugin_term "LIBRARY") + # Set RAYPATH on install + set(CPACK_NSIS_EXTRA_INSTALL_COMMANDS + "WriteRegExpandStr HKLM \\\"SYSTEM\\\\CurrentControlSet\\\\Control\\\\Session Manager\\\\Environment\\\" RAYPATH '\\\$INSTDIR\\\\lib\\\;.'" + ) + + # Unset RAYPATH on uninstall + set(CPACK_NSIS_EXTRA_UNINSTALL_COMMANDS + "DeleteRegValue HKLM \\\"SYSTEM\\\\CurrentControlSet\\\\Control\\\\Session Manager\\\\Environment\\\" RAYPATH" + ) endif() if(UNIX)
