root/radiance/ray/CMakeLists.txt
Revision: 1.21
Committed: Wed Jun 20 20:51:24 2018 UTC (6 years, 11 months ago) by greg
Changes since 1.20: +1 -3 lines
Updates to package installers from Rob G.
# User Rev Content
1 greg 1.19 cmake_minimum_required(VERSION 3.0)
2     cmake_policy(SET CMP0020 NEW)
3     cmake_policy(SET CMP0048 NEW)
4     if(NOT ${CMAKE_VERSION} VERSION_LESS "3.1")
5     cmake_policy(SET CMP0054 NEW)
6     endif()
7
8     project(radiance VERSION 5.2.0)
9
10     set(PROJECT_VERSION_TWEAK "Unknown" CACHE STRING "Commit Hash")
11     find_package(Git)
12     if(GIT_FOUND)
13     execute_process(COMMAND "${GIT_EXECUTABLE}" "rev-parse" "--short=10" "HEAD"
14     WORKING_DIRECTORY "${CMAKE_SOURCE_DIR}"
15     TIMEOUT 10
16     RESULT_VARIABLE RESULT
17     OUTPUT_VARIABLE GIT_VERSION
18     ERROR_QUIET
19     OUTPUT_STRIP_TRAILING_WHITESPACE
20     )
21     if(${RESULT} EQUAL 0 AND NOT "${GIT_VERSION}" EQUAL "${PROJECT_VERSION_TWEAK}")
22     set(PROJECT_VERSION_TWEAK ${GIT_VERSION} CACHE STRING "Commit Hash" FORCE)
23 greg 1.15 endif()
24     endif()
25
26 greg 1.1 enable_testing()
27     include(CTest)
28
29     option(BUILD_SHARED_LIBS "Build radiance using shared libraries?" OFF)
30 greg 1.9 option(BUILD_HEADLESS "Build radiance without any GUI components?" OFF)
31 greg 1.18 option(BUILD_PABOPTO_UTILS "Build PABOpto Utilities?" OFF)
32 greg 1.19 option(BUILD_LIBTIFF "Build libtiff?" OFF)
33 greg 1.1
34     if(NOT WIN32)
35 greg 1.4 set(CPACK_INCLUDE_TOPLEVEL_DIRECTORY 1)
36 greg 1.19 install(DIRECTORY "${CMAKE_CURRENT_SOURCE_DIR}/doc/man/" DESTINATION man)
37 greg 1.6 set(qt_plugin_term "PLUGIN")
38 greg 1.1 endif()
39 greg 1.4
40 greg 1.19 if(WIN32)
41 greg 1.10 set(CPACK_NSIS_MODIFY_PATH 1)
42     set(qt_plugin_term "LIBRARY")
43 greg 1.4
44 greg 1.10 # Set RAYPATH on install
45     set(CPACK_NSIS_EXTRA_INSTALL_COMMANDS
46 greg 1.11 "WriteRegExpandStr HKLM \\\"SYSTEM\\\\CurrentControlSet\\\\Control\\\\Session Manager\\\\Environment\\\" RAYPATH '\\\$INSTDIR\\\\lib\\\;.'"
47 greg 1.10 )
48 greg 1.4
49 greg 1.10 # Unset RAYPATH on uninstall
50     set(CPACK_NSIS_EXTRA_UNINSTALL_COMMANDS
51     "DeleteRegValue HKLM \\\"SYSTEM\\\\CurrentControlSet\\\\Control\\\\Session Manager\\\\Environment\\\" RAYPATH"
52     )
53 greg 1.4 endif()
54
55     if(UNIX)
56     set(CPACK_PACKAGING_INSTALL_PREFIX "/usr/local/radiance")
57     add_definitions(-Dlinux -D_FILE_OFFSET_BITS=64 -DNOSTEREO)
58     else()
59 greg 1.5 set(CPACK_PACKAGING_INSTALL_PREFIX "/")
60 greg 1.4 endif()
61
62 greg 1.21 set(CPACK_PACKAGE_FILE_NAME "${CMAKE_PROJECT_NAME}-${PROJECT_VERSION_MAJOR}.${PROJECT_VERSION_MINOR}.${PROJECT_VERSION_TWEAK}-${CMAKE_SYSTEM_NAME}")
63 greg 1.19
64 greg 1.4 if(APPLE)
65 greg 1.19 set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -std=c11 -std=c++11 -stdlib=libc++")
66 greg 1.4 add_definitions(-DBSD -DNOSTEREO -Dfreebsd)
67 greg 1.19 set(CMAKE_C_FLAGS "${CMAKE_C_FLAGS} -mmacosx-version-min=10.7")
68 greg 1.4 endif()
69
70 greg 1.19 if(BUILD_LIBTIFF)
71     include(ExternalProject)
72     set(LIBTIFF_URL http://download.osgeo.org/libtiff/tiff-4.0.9.tar.gz)
73     set(LIBTIFF_MD5 54BAD211279CC93EB4FCA31BA9BFDC79)
74     if(WIN32)
75     ExternalProject_Add(libtiff
76     URL ${LIBTIFF_URL}
77     URL_MD5 ${LIBTIFF_MD5}
78     CMAKE_GENERATOR "NMake Makefiles"
79     CMAKE_ARGS
80     "-DBUILD_SHARED_LIBS=OFF"
81     "-DCMAKE_BUILD_TYPE=Release"
82     "-Dzlib=OFF"
83     "../libtiff"
84     INSTALL_COMMAND ""
85     )
86     set(TIFF_LIBRARY ${CMAKE_BINARY_DIR}/libtiff-prefix/src/libtiff-build/libtiff/tiff.lib)
87     else()
88     ExternalProject_Add(libtiff
89     URL ${LIBTIFF_URL}
90     URL_MD5 ${LIBTIFF_MD5}
91     CMAKE_ARGS
92     "-DBUILD_SHARED_LIBS=OFF"
93     "-DCMAKE_BUILD_TYPE=Release"
94     "-Dzlib=OFF"
95     "../libtiff"
96     INSTALL_COMMAND ""
97     )
98     set(TIFF_LIBRARY ${CMAKE_BINARY_DIR}/libtiff-prefix/src/libtiff-build/libtiff/libtiff.a)
99     endif()
100     set(TIFF_INCLUDE_DIR ${CMAKE_BINARY_DIR}/libtiff/src/libtiff/libtiff)
101     endif()
102 greg 1.7
103 greg 1.19 set(CPACK_PACKAGE_VERSION_MAJOR ${PROJECT_VERSION_MAJOR})
104     set(CPACK_PACKAGE_VERSION_MINOR ${PROJECT_VERSION_MINOR})
105 greg 1.5 set(CPACK_PACKAGE_INSTALL_DIRECTORY "Radiance")
106 greg 1.19 set(CPACK_RESOURCE_FILE_WELCOME "${radiance_SOURCE_DIR}/Welcome.txt")
107     set(CPACK_RESOURCE_FILE_README "${radiance_SOURCE_DIR}/README.txt")
108     set(CPACK_RESOURCE_FILE_LICENSE "${radiance_SOURCE_DIR}/License.txt")
109 greg 1.4
110 greg 1.19 if(APPLE)
111     set(CPACK_GENERATOR "PackageMaker")
112     elseif(UNIX)
113     set(CPACK_GENERATOR "TGZ")
114     endif()
115 greg 1.4
116 greg 1.1 include(CPack)
117
118 greg 1.9 if(NOT BUILD_HEADLESS)
119 greg 1.15 find_package(Qt5Widgets)
120 greg 1.19 get_target_property(QT_LIBRARY_DIR Qt5::Core LOCATION)
121     get_filename_component(QT_LIBRARY_DIR ${QT_LIBRARY_DIR} PATH)
122     get_filename_component(QT_LIBRARY_DIR "${QT_LIBRARY_DIR}/.." ABSOLUTE)
123 greg 1.9 find_package(X11)
124 greg 1.20 if(APPLE)
125     include_directories(${X11_INCLUDE_DIR})
126     endif()
127 greg 1.9 endif()
128 greg 1.1
129 greg 1.19 set(EXECUTABLE_OUTPUT_PATH ${PROJECT_BINARY_DIR}/bin)
130 greg 1.1
131 greg 1.19 if(MSVC)
132     add_definitions(/MP)
133     endif()
134 greg 1.1 if(WIN32 AND "${CMAKE_C_COMPILER_ID}" MATCHES "^(Intel)$")
135     set(_INTEL_WINDOWS 1)
136     endif()
137     if(MSVC OR _INTEL_WINDOWS)
138     add_definitions(-D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE)
139     endif()
140     if(WIN32)
141     add_definitions(-DEZXML_NOMMAP -Dfseeko=fseek -Dstrcasecmp=_stricmp)
142     endif()
143
144     add_subdirectory("src")
145
146 greg 1.19 set(test_dir "${CMAKE_CURRENT_SOURCE_DIR}/test/test data")
147 greg 1.5
148 greg 1.19 add_subdirectory(resources)
149 greg 1.5
150 greg 1.19 install(DIRECTORY "${CMAKE_BINARY_DIR}/lib/"
151     DESTINATION "lib"
152 greg 1.1 )
153
154     include(InstallRequiredSystemLibraries)
155     add_subdirectory(InstallRules)
