--- ray/CMakeLists.txt 2014/03/25 21:22:30 1.10 +++ ray/CMakeLists.txt 2015/05/08 18:07:38 1.15 @@ -1,26 +1,55 @@ cmake_minimum_required(VERSION 2.8.4) project("radiance") +if(NOT ${CMAKE_VERSION} VERSION_LESS "2.8.11") + cmake_policy(SET CMP0020 NEW) + if(NOT ${CMAKE_VERSION} VERSION_LESS "3.0") + cmake_policy(SET CMP0042 NEW) + if(NOT ${CMAKE_VERSION} VERSION_LESS "3.1") + cmake_policy(SET CMP0054 NEW) + endif() + endif() +endif() + enable_testing() include(CTest) option(BUILD_SHARED_LIBS "Build radiance using shared libraries?" OFF) option(BUILD_HEADLESS "Build radiance without any GUI components?" OFF) +option(CPACK_NREL_SUPPORT "Include OpenStudio ToolFinder Help?" OFF) + +if( CPACK_NREL_SUPPORT ) + # find git so we can query for the current git tag + find_program(git git) + if (NOT git) + message(ERROR "Please specify the path to the git executable") + endif() + + # call git log to get output containing the tag + execute_process( + COMMAND ${git} describe --tag --exact-match + WORKING_DIRECTORY ${CMAKE_SOURCE_DIR} + OUTPUT_VARIABLE git_tag_output) + + # create & install the source version .txt file + file(WRITE "NREL_ver.txt" "Radiance version ${git_tag_output}") + install(FILES NREL_ver.txt DESTINATION bin/..) +endif() + if(NOT WIN32) set(CPACK_INCLUDE_TOPLEVEL_DIRECTORY 1) install(DIRECTORY ${CMAKE_CURRENT_SOURCE_DIR}/doc/man/ DESTINATION man) set(qt_plugin_term "PLUGIN") endif() - if (WIN32) set(CPACK_NSIS_MODIFY_PATH 1) set(qt_plugin_term "LIBRARY") # Set RAYPATH on install set(CPACK_NSIS_EXTRA_INSTALL_COMMANDS - "WriteRegExpandStr HKLM \\\"SYSTEM\\\\CurrentControlSet\\\\Control\\\\Session Manager\\\\Environment\\\" RAYPATH '\\\"$INSTDIR\\\\lib\\\"'" + "WriteRegExpandStr HKLM \\\"SYSTEM\\\\CurrentControlSet\\\\Control\\\\Session Manager\\\\Environment\\\" RAYPATH '\\\$INSTDIR\\\\lib\\\;.'" ) # Unset RAYPATH on uninstall @@ -46,8 +75,8 @@ IF( BUILD_PACKAGE ) INCLUDE(radianceCPack.cmake ) ENDIF( BUILD_PACKAGE ) -set(CPACK_PACKAGE_VERSION_MAJOR 4) -set(CPACK_PACKAGE_VERSION_MINOR 2) +set(CPACK_PACKAGE_VERSION_MAJOR 5) +set(CPACK_PACKAGE_VERSION_MINOR 0) set(CPACK_PACKAGE_VERSION_PATCH a) set(CPACK_PACKAGE_INSTALL_DIRECTORY "Radiance") SET(CPACK_RESOURCE_FILE_WELCOME "${radiance_SOURCE_DIR}/Welcome.txt") @@ -58,7 +87,7 @@ SET(CPACK_RESOURCE_FILE_LICENSE "${radiance_SOURCE_DIR include(CPack) if(NOT BUILD_HEADLESS) - find_package(Qt4 COMPONENTS QtCore QtGui) + find_package(Qt5Widgets) find_package(X11) endif()
