root/radiance/ray/CMakeLists.txt
Tue Mar 22 21:36:24 2016 UTC (9 years ago) by greg
Diff to previous 1.16 , to selected 1.6
Rob G. fixes for "headless" target
Thu Feb 4 20:16:22 2016 UTC (9 years, 1 month ago) by greg
Diff to previous 1.15 , to selected 1.6
Change open filetype mask in rvu Windows app
Fri May 8 18:07:38 2015 UTC (9 years, 10 months ago) by greg
Changes since 1.14: +11 -1 lines
Diff to previous 1.14 , to selected 1.6
Fixes for rvu under Windows
Tue Apr 21 19:16:51 2015 UTC (9 years, 11 months ago) by greg
Changes since 1.13: +2 -2 lines
Diff to previous 1.13 , to selected 1.6
Fixes for Windows and photon map
Thu Aug 21 19:38:23 2014 UTC (10 years, 7 months ago) by greg
CVS Tags: rad4R2P1, rad4R2P2
Diff to previous 1.12 , to selected 1.6
Updated top-level cmake file
Fri Apr 18 20:51:49 2014 UTC (10 years, 11 months ago) by greg
CVS Tags: rad4R2
Diff to previous 1.11 , to selected 1.6
Installation fix
Wed Apr 16 20:48:07 2014 UTC (10 years, 11 months ago) by greg
Changes since 1.10: +21 -2 lines
Diff to previous 1.10 , to selected 1.6
Removed objview Ruby script, which is no longer needed for Windows
Tue Mar 25 21:22:30 2014 UTC (10 years, 11 months ago) by greg
Changes since 1.9: +10 -6 lines
Diff to previous 1.9 , to selected 1.6
Changes to set RAYPATH on Windows platforms more reliably
Thu Mar 20 22:49:21 2014 UTC (11 years ago) by greg
Changes since 1.8: +5 -2 lines
Diff to previous 1.8 , to selected 1.6
Changes to speed installation on cloud computing systems
Mon Sep 23 22:17:28 2013 UTC (11 years, 5 months ago) by greg
Changes since 1.7: +1 -0 lines
Diff to previous 1.7 , to selected 1.6
Make executables backwards-compatible to MacOS X 10.6.x
Thu Aug 16 17:59:45 2012 UTC (12 years, 7 months ago) by greg
Changes since 1.6: +4 -0 lines
Diff to previous 1.6
Added NREL acknowledgment
Revision 1.6 - (view) (download) (annotate) - [selected]
Tue Jun 19 16:41:46 2012 UTC (12 years, 9 months ago) by greg
Diff to previous 1.5
Added missing cmake files
Wed May 30 18:31:11 2012 UTC (12 years, 9 months ago) by greg
Changes since 1.4: +67 -56 lines
Diff to previous 1.4 , to selected 1.6
Patches to cmake build system and QT driver for rvu
Wed Apr 25 22:21:06 2012 UTC (12 years, 10 months ago) by greg
Changes since 1.3: +51 -24 lines
Diff to previous 1.3 , to selected 1.6
Wed Oct 26 16:48:01 2011 UTC (13 years, 4 months ago) by greg
Diff to previous 1.2 , to selected 1.6
Tue Oct 25 22:53:14 2011 UTC (13 years, 4 months ago) by greg
Changes since 1.1: +5 -5 lines
Diff to previous 1.1 , to selected 1.6
Added files needed by cmake
Sat Oct 22 22:38:10 2011 UTC (13 years, 5 months ago) by greg
Diff to selected 1.6
Added qt interface for rvu and cmake files from Bill Hoffman
