root/radiance/ray/CMakeLists.txt
Revision: 1.17
Committed: Tue Mar 22 21:36:24 2016 UTC (9 years, 2 months ago) by greg
Rob G. fixes for "headless" target
# User Rev Content
1 greg 1.1 cmake_minimum_required(VERSION 2.8.4)
2     project("radiance")
3
4 greg 1.15 if(NOT ${CMAKE_VERSION} VERSION_LESS "2.8.11")
5     cmake_policy(SET CMP0020 NEW)
6     if(NOT ${CMAKE_VERSION} VERSION_LESS "3.0")
7     cmake_policy(SET CMP0042 NEW)
8     if(NOT ${CMAKE_VERSION} VERSION_LESS "3.1")
9     cmake_policy(SET CMP0054 NEW)
10     endif()
11     endif()
12     endif()
13
14 greg 1.1 enable_testing()
15     include(CTest)
16
17     option(BUILD_SHARED_LIBS "Build radiance using shared libraries?" OFF)
18 greg 1.9 option(BUILD_HEADLESS "Build radiance without any GUI components?" OFF)
19 greg 1.1
20 greg 1.11 option(CPACK_NREL_SUPPORT "Include OpenStudio ToolFinder Help?" OFF)
21
22     if( CPACK_NREL_SUPPORT )
23     # find git so we can query for the current git tag
24     find_program(git git)
25     if (NOT git)
26     message(ERROR "Please specify the path to the git executable")
27     endif()
28
29     # call git log to get output containing the tag
30     execute_process(
31 greg 1.12 COMMAND ${git} describe --tag --exact-match
32 greg 1.11 WORKING_DIRECTORY ${CMAKE_SOURCE_DIR}
33 greg 1.12 OUTPUT_VARIABLE git_tag_output)
34 greg 1.11
35     # create & install the source version .txt file
36 greg 1.12 file(WRITE "NREL_ver.txt" "Radiance version ${git_tag_output}")
37 greg 1.11 install(FILES NREL_ver.txt DESTINATION bin/..)
38     endif()
39
40 greg 1.1 if(NOT WIN32)
41 greg 1.4 set(CPACK_INCLUDE_TOPLEVEL_DIRECTORY 1)
42     install(DIRECTORY ${CMAKE_CURRENT_SOURCE_DIR}/doc/man/ DESTINATION man)
43 greg 1.6 set(qt_plugin_term "PLUGIN")
44 greg 1.1 endif()
45 greg 1.4
46     if (WIN32)
47 greg 1.10 set(CPACK_NSIS_MODIFY_PATH 1)
48     set(qt_plugin_term "LIBRARY")
49 greg 1.4
50 greg 1.10 # Set RAYPATH on install
51     set(CPACK_NSIS_EXTRA_INSTALL_COMMANDS
52 greg 1.11 "WriteRegExpandStr HKLM \\\"SYSTEM\\\\CurrentControlSet\\\\Control\\\\Session Manager\\\\Environment\\\" RAYPATH '\\\$INSTDIR\\\\lib\\\;.'"
53 greg 1.10 )
54 greg 1.4
55 greg 1.10 # Unset RAYPATH on uninstall
56     set(CPACK_NSIS_EXTRA_UNINSTALL_COMMANDS
57     "DeleteRegValue HKLM \\\"SYSTEM\\\\CurrentControlSet\\\\Control\\\\Session Manager\\\\Environment\\\" RAYPATH"
58     )
59 greg 1.4 endif()
60
61     if(UNIX)
62     set(CPACK_PACKAGING_INSTALL_PREFIX "/usr/local/radiance")
63     add_definitions(-Dlinux -D_FILE_OFFSET_BITS=64 -DNOSTEREO)
64     else()
65 greg 1.5 set(CPACK_PACKAGING_INSTALL_PREFIX "/")
66 greg 1.4 endif()
67
68     if(APPLE)
69     add_definitions(-DBSD -DNOSTEREO -Dfreebsd)
70     include_directories(/usr/X11R6/include)
71 greg 1.8 SET(CMAKE_C_FLAGS "${CMAKE_C_FLAGS} -mmacosx-version-min=10.6")
72 greg 1.4 endif()
73
74 greg 1.7 IF( BUILD_PACKAGE )
75     INCLUDE(radianceCPack.cmake )
76     ENDIF( BUILD_PACKAGE )
77
78 greg 1.14 set(CPACK_PACKAGE_VERSION_MAJOR 5)
79     set(CPACK_PACKAGE_VERSION_MINOR 0)
80 greg 1.17 set(CPACK_PACKAGE_VERSION_PATCH a.8)
81 greg 1.5 set(CPACK_PACKAGE_INSTALL_DIRECTORY "Radiance")
82 greg 1.3 SET(CPACK_RESOURCE_FILE_WELCOME "${radiance_SOURCE_DIR}/Welcome.txt")
83 greg 1.4 SET(CPACK_RESOURCE_FILE_README "${radiance_SOURCE_DIR}/README.txt")
84 greg 1.3 SET(CPACK_RESOURCE_FILE_LICENSE "${radiance_SOURCE_DIR}/License.txt")
85 greg 1.4
86
87 greg 1.1 include(CPack)
88
89 greg 1.9 if(NOT BUILD_HEADLESS)
90 greg 1.15 find_package(Qt5Widgets)
91 greg 1.9 find_package(X11)
92     endif()
93 greg 1.1
94     SET(EXECUTABLE_OUTPUT_PATH ${PROJECT_BINARY_DIR}/bin)
95
96     if(WIN32 AND "${CMAKE_C_COMPILER_ID}" MATCHES "^(Intel)$")
97     set(_INTEL_WINDOWS 1)
98     endif()
99     if(MSVC OR _INTEL_WINDOWS)
100     add_definitions(-D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE)
101     endif()
102     if(WIN32)
103     add_definitions(-DEZXML_NOMMAP -Dfseeko=fseek -Dstrcasecmp=_stricmp)
104     endif()
105
106     add_subdirectory("src")
107
108 greg 1.5 set(test_dir ${CMAKE_CURRENT_SOURCE_DIR}/test/test\ data)
109     option(BUILD_TESTING "Download support tarball & enable testing?" ON)
110
111     if(BUILD_TESTING)
112     #download and extract radiance support files
113     include(ExternalProject)
114     set(base "${CMAKE_BINARY_DIR}/Downloads")
115     set_property(DIRECTORY PROPERTY EP_BASE ${base})
116     ExternalProject_Add(radiance_support
117     URL http://www.radiance-online.org/software/non-cvs/rad4R1supp.tar.gz
118     URL_MD5 efd82970e1d0747eede8eb64c01048f4
119     CONFIGURE_COMMAND ""
120     BUILD_COMMAND ""
121     INSTALL_COMMAND ""
122     )
123
124     #install support files.
125     set(lib_dir ${base}/Source/radiance_support/lib)
126     install(
127     FILES
128     ${lib_dir}/Earth.cal ${lib_dir}/He.cal ${lib_dir}/He3.cal
129     ${lib_dir}/adobe.cal ${lib_dir}/ball.cal ${lib_dir}/brick.cal
130     ${lib_dir}/brickweave.cal ${lib_dir}/carpet.cal ${lib_dir}/climit.cal
131     ${lib_dir}/corrug.cal ${lib_dir}/covelight.cal ${lib_dir}/cyl.cal
132     ${lib_dir}/dichroic.cal ${lib_dir}/dirt.cal ${lib_dir}/fisheye.cal
133     ${lib_dir}/fishgeom.cal ${lib_dir}/fprism.cal ${lib_dir}/globe.cal
134     ${lib_dir}/gloss.cal ${lib_dir}/grating.cal ${lib_dir}/jigglepic.cal
135     ${lib_dir}/lcp0.cal ${lib_dir}/limit.cal ${lib_dir}/marble.cal
136     ${lib_dir}/orange.cal ${lib_dir}/picture.cal ${lib_dir}/plink.cal
137     ${lib_dir}/prism.cal ${lib_dir}/retrorefl.cal ${lib_dir}/serraglaze.cal
138     ${lib_dir}/slate.cal ${lib_dir}/surf.cal ${lib_dir}/tim1.cal
139     ${lib_dir}/weave.cal ${lib_dir}/winxmit.cal ${lib_dir}/woodpat.cal
140     ${lib_dir}/woodtex.cal ${lib_dir}/wrinkle.cal
141     ${lib_dir}/page1.txt ${lib_dir}/page2.txt
142     ${lib_dir}/Pix.fnt
143     ${lib_dir}/PixOblique.fnt
144     ${lib_dir}/Veerdana.fnt
145     ${lib_dir}/VeerdanaBold.fnt
146     ${lib_dir}/VeerdanaBoldItalic.fnt
147     ${lib_dir}/VeerdanaItalic.fnt
148     ${lib_dir}/helvet.fnt
149     ${lib_dir}/hexbit4x1.fnt
150     ${test_dir}/model.oct
151     ${test_dir}/model.vp
152     DESTINATION lib
153     )
154
155     install(FILES ${lib_dir}/Earth.hdr DESTINATION lib RENAME Earth.pic)
156     install(FILES ${lib_dir}/EarthBig.hdr DESTINATION lib RENAME EarthBig.pic)
157     install(FILES ${lib_dir}/alberta.hdr DESTINATION lib RENAME alberta.pic)
158     install(FILES ${lib_dir}/brick.hdr DESTINATION lib RENAME brick.pic)
159     install(FILES ${lib_dir}/brickweave.hdr DESTINATION lib RENAME brickweave.pic)
160     install(FILES ${lib_dir}/cabin.hdr DESTINATION lib RENAME cabin.pic)
161     install(FILES ${lib_dir}/forestfl.hdr DESTINATION lib RENAME forestfl.pic)
162     install(FILES ${lib_dir}/oakfloor.hdr DESTINATION lib RENAME oakfloor.pic)
163     install(FILES ${lib_dir}/pine.hdr DESTINATION lib RENAME pine.pic)
164     install(FILES ${lib_dir}/pinebark.hdr DESTINATION lib RENAME pinebark.pic)
165     install(FILES ${lib_dir}/podlife.hdr DESTINATION lib RENAME podlife.pic)
166     install(FILES ${lib_dir}/richgrove.hdr DESTINATION lib RENAME richgrove.pic)
167     install(FILES ${lib_dir}/shingle.hdr DESTINATION lib RENAME shingle.pic)
168     install(FILES ${lib_dir}/summercab.hdr DESTINATION lib RENAME summercab.pic)
169     install(FILES ${lib_dir}/tulips.hdr DESTINATION lib RENAME tulips.pic)
170 greg 1.1
171 greg 1.5 add_subdirectory(cmake_tests)
172     endif()
173
174 greg 1.1 install(
175     FILES
176     ${test_dir}/model.oct
177     ${test_dir}/model.vp
178 greg 1.4 DESTINATION lib
179 greg 1.1 )
180
181     include(InstallRequiredSystemLibraries)
182     add_subdirectory(InstallRules)
