root/radiance/ray/CMakeLists.txt
Revision: 1.9
Committed: Thu Mar 20 22:49:21 2014 UTC (10 years, 2 months ago) by greg
Changes since 1.8: +5 -2 lines
Changes to speed installation on cloud computing systems
1 cmake_minimum_required(VERSION 2.8.4)
2 project("radiance")
3
4 enable_testing()
5 include(CTest)
6
7 option(BUILD_SHARED_LIBS "Build radiance using shared libraries?" OFF)
8 option(BUILD_HEADLESS "Build radiance without any GUI components?" OFF)
9
10 if(NOT WIN32)
11 set(CPACK_INCLUDE_TOPLEVEL_DIRECTORY 1)
12 install(DIRECTORY ${CMAKE_CURRENT_SOURCE_DIR}/doc/man/ DESTINATION man)
13 set(qt_plugin_term "PLUGIN")
14 endif()
15
16
17 if (WIN32)
18
19 set(CPACK_NSIS_MODIFY_PATH 0)
20
21 set(CPACK_BINARY_ZIP 1)
22
23 set(CPACK_NSIS_EXTRA_INSTALL_COMMANDS "")
24 set(qt_plugin_term "LIBRARY")
25
26 endif()
27
28 if(UNIX)
29 set(CPACK_PACKAGING_INSTALL_PREFIX "/usr/local/radiance")
30 add_definitions(-Dlinux -D_FILE_OFFSET_BITS=64 -DNOSTEREO)
31 else()
32 set(CPACK_PACKAGING_INSTALL_PREFIX "/")
33 endif()
34
35 if(APPLE)
36 add_definitions(-DBSD -DNOSTEREO -Dfreebsd)
37 include_directories(/usr/X11R6/include)
38 SET(CMAKE_C_FLAGS "${CMAKE_C_FLAGS} -mmacosx-version-min=10.6")
39 endif()
40
41 IF( BUILD_PACKAGE )
42 INCLUDE(radianceCPack.cmake )
43 ENDIF( BUILD_PACKAGE )
44
45 set(CPACK_PACKAGE_VERSION_MAJOR 4)
46 set(CPACK_PACKAGE_VERSION_MINOR 2)
47 set(CPACK_PACKAGE_VERSION_PATCH a)
48 set(CPACK_PACKAGE_INSTALL_DIRECTORY "Radiance")
49 SET(CPACK_RESOURCE_FILE_WELCOME "${radiance_SOURCE_DIR}/Welcome.txt")
50 SET(CPACK_RESOURCE_FILE_README "${radiance_SOURCE_DIR}/README.txt")
51 SET(CPACK_RESOURCE_FILE_LICENSE "${radiance_SOURCE_DIR}/License.txt")
52
53
54 include(CPack)
55
56 if(NOT BUILD_HEADLESS)
57 find_package(Qt4 COMPONENTS QtCore QtGui)
58 find_package(X11)
59 endif()
60
61 SET(EXECUTABLE_OUTPUT_PATH ${PROJECT_BINARY_DIR}/bin)
62
63 if(WIN32 AND "${CMAKE_C_COMPILER_ID}" MATCHES "^(Intel)$")
64 set(_INTEL_WINDOWS 1)
65 endif()
66 if(MSVC OR _INTEL_WINDOWS)
67 add_definitions(-D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE)
68 endif()
69 if(WIN32)
70 add_definitions(-DEZXML_NOMMAP -Dfseeko=fseek -Dstrcasecmp=_stricmp)
71 endif()
72
73 add_subdirectory("src")
74
75 set(test_dir ${CMAKE_CURRENT_SOURCE_DIR}/test/test\ data)
76 option(BUILD_TESTING "Download support tarball & enable testing?" ON)
77
78 if(BUILD_TESTING)
79 #download and extract radiance support files
80 include(ExternalProject)
81 set(base "${CMAKE_BINARY_DIR}/Downloads")
82 set_property(DIRECTORY PROPERTY EP_BASE ${base})
83 ExternalProject_Add(radiance_support
84 URL http://www.radiance-online.org/software/non-cvs/rad4R1supp.tar.gz
85 URL_MD5 efd82970e1d0747eede8eb64c01048f4
86 CONFIGURE_COMMAND ""
87 BUILD_COMMAND ""
88 INSTALL_COMMAND ""
89 )
90
91 #install support files.
92 set(lib_dir ${base}/Source/radiance_support/lib)
93 install(
94 FILES
95 ${lib_dir}/Earth.cal ${lib_dir}/He.cal ${lib_dir}/He3.cal
96 ${lib_dir}/adobe.cal ${lib_dir}/ball.cal ${lib_dir}/brick.cal
97 ${lib_dir}/brickweave.cal ${lib_dir}/carpet.cal ${lib_dir}/climit.cal
98 ${lib_dir}/corrug.cal ${lib_dir}/covelight.cal ${lib_dir}/cyl.cal
99 ${lib_dir}/dichroic.cal ${lib_dir}/dirt.cal ${lib_dir}/fisheye.cal
100 ${lib_dir}/fishgeom.cal ${lib_dir}/fprism.cal ${lib_dir}/globe.cal
101 ${lib_dir}/gloss.cal ${lib_dir}/grating.cal ${lib_dir}/jigglepic.cal
102 ${lib_dir}/lcp0.cal ${lib_dir}/limit.cal ${lib_dir}/marble.cal
103 ${lib_dir}/orange.cal ${lib_dir}/picture.cal ${lib_dir}/plink.cal
104 ${lib_dir}/prism.cal ${lib_dir}/retrorefl.cal ${lib_dir}/serraglaze.cal
105 ${lib_dir}/slate.cal ${lib_dir}/surf.cal ${lib_dir}/tim1.cal
106 ${lib_dir}/weave.cal ${lib_dir}/winxmit.cal ${lib_dir}/woodpat.cal
107 ${lib_dir}/woodtex.cal ${lib_dir}/wrinkle.cal
108 ${lib_dir}/page1.txt ${lib_dir}/page2.txt
109 ${lib_dir}/Pix.fnt
110 ${lib_dir}/PixOblique.fnt
111 ${lib_dir}/Veerdana.fnt
112 ${lib_dir}/VeerdanaBold.fnt
113 ${lib_dir}/VeerdanaBoldItalic.fnt
114 ${lib_dir}/VeerdanaItalic.fnt
115 ${lib_dir}/helvet.fnt
116 ${lib_dir}/hexbit4x1.fnt
117 ${test_dir}/model.oct
118 ${test_dir}/model.vp
119 DESTINATION lib
120 )
121
122 install(FILES ${lib_dir}/Earth.hdr DESTINATION lib RENAME Earth.pic)
123 install(FILES ${lib_dir}/EarthBig.hdr DESTINATION lib RENAME EarthBig.pic)
124 install(FILES ${lib_dir}/alberta.hdr DESTINATION lib RENAME alberta.pic)
125 install(FILES ${lib_dir}/brick.hdr DESTINATION lib RENAME brick.pic)
126 install(FILES ${lib_dir}/brickweave.hdr DESTINATION lib RENAME brickweave.pic)
127 install(FILES ${lib_dir}/cabin.hdr DESTINATION lib RENAME cabin.pic)
128 install(FILES ${lib_dir}/forestfl.hdr DESTINATION lib RENAME forestfl.pic)
129 install(FILES ${lib_dir}/oakfloor.hdr DESTINATION lib RENAME oakfloor.pic)
130 install(FILES ${lib_dir}/pine.hdr DESTINATION lib RENAME pine.pic)
131 install(FILES ${lib_dir}/pinebark.hdr DESTINATION lib RENAME pinebark.pic)
132 install(FILES ${lib_dir}/podlife.hdr DESTINATION lib RENAME podlife.pic)
133 install(FILES ${lib_dir}/richgrove.hdr DESTINATION lib RENAME richgrove.pic)
134 install(FILES ${lib_dir}/shingle.hdr DESTINATION lib RENAME shingle.pic)
135 install(FILES ${lib_dir}/summercab.hdr DESTINATION lib RENAME summercab.pic)
136 install(FILES ${lib_dir}/tulips.hdr DESTINATION lib RENAME tulips.pic)
137
138 add_subdirectory(cmake_tests)
139 endif()
140
141 install(
142 FILES
143 ${test_dir}/model.oct
144 ${test_dir}/model.vp
145 DESTINATION lib
146 )
147
148 include(InstallRequiredSystemLibraries)
149 add_subdirectory(InstallRules)
