root/Development/ray/CMakeLists.txt
Revision: 1.12
Committed: Fri Apr 18 20:51:49 2014 UTC (11 years, 8 months ago) by greg
CVS Tags: rad4R2
Installation fix
# User Rev Content
1 greg 1.1 cmake_minimum_required(VERSION 2.8.4)
2     project("radiance")
3
4     enable_testing()
5     include(CTest)
6
7     option(BUILD_SHARED_LIBS "Build radiance using shared libraries?" OFF)
8 greg 1.9 option(BUILD_HEADLESS "Build radiance without any GUI components?" OFF)
9 greg 1.1
10 greg 1.11 option(CPACK_NREL_SUPPORT "Include OpenStudio ToolFinder Help?" OFF)
11
12     if( CPACK_NREL_SUPPORT )
13     # find git so we can query for the current git tag
14     find_program(git git)
15     if (NOT git)
16     message(ERROR "Please specify the path to the git executable")
17     endif()
18
19     # call git log to get output containing the tag
20     execute_process(
21 greg 1.12 COMMAND ${git} describe --tag --exact-match
22 greg 1.11 WORKING_DIRECTORY ${CMAKE_SOURCE_DIR}
23 greg 1.12 OUTPUT_VARIABLE git_tag_output)
24 greg 1.11
25     # create & install the source version .txt file
26 greg 1.12 file(WRITE "NREL_ver.txt" "Radiance version ${git_tag_output}")
27 greg 1.11 install(FILES NREL_ver.txt DESTINATION bin/..)
28     endif()
29
30 greg 1.1 if(NOT WIN32)
31 greg 1.4 set(CPACK_INCLUDE_TOPLEVEL_DIRECTORY 1)
32     install(DIRECTORY ${CMAKE_CURRENT_SOURCE_DIR}/doc/man/ DESTINATION man)
33 greg 1.6 set(qt_plugin_term "PLUGIN")
34 greg 1.1 endif()
35 greg 1.4
36     if (WIN32)
37 greg 1.10 set(CPACK_NSIS_MODIFY_PATH 1)
38     set(qt_plugin_term "LIBRARY")
39 greg 1.4
40 greg 1.10 # Set RAYPATH on install
41     set(CPACK_NSIS_EXTRA_INSTALL_COMMANDS
42 greg 1.11 "WriteRegExpandStr HKLM \\\"SYSTEM\\\\CurrentControlSet\\\\Control\\\\Session Manager\\\\Environment\\\" RAYPATH '\\\$INSTDIR\\\\lib\\\;.'"
43 greg 1.10 )
44 greg 1.4
45 greg 1.10 # Unset RAYPATH on uninstall
46     set(CPACK_NSIS_EXTRA_UNINSTALL_COMMANDS
47     "DeleteRegValue HKLM \\\"SYSTEM\\\\CurrentControlSet\\\\Control\\\\Session Manager\\\\Environment\\\" RAYPATH"
48     )
49 greg 1.4 endif()
50
51     if(UNIX)
52     set(CPACK_PACKAGING_INSTALL_PREFIX "/usr/local/radiance")
53     add_definitions(-Dlinux -D_FILE_OFFSET_BITS=64 -DNOSTEREO)
54     else()
55 greg 1.5 set(CPACK_PACKAGING_INSTALL_PREFIX "/")
56 greg 1.4 endif()
57
58     if(APPLE)
59     add_definitions(-DBSD -DNOSTEREO -Dfreebsd)
60     include_directories(/usr/X11R6/include)
61 greg 1.8 SET(CMAKE_C_FLAGS "${CMAKE_C_FLAGS} -mmacosx-version-min=10.6")
62 greg 1.4 endif()
63
64 greg 1.7 IF( BUILD_PACKAGE )
65     INCLUDE(radianceCPack.cmake )
66     ENDIF( BUILD_PACKAGE )
67
68 greg 1.2 set(CPACK_PACKAGE_VERSION_MAJOR 4)
69 greg 1.4 set(CPACK_PACKAGE_VERSION_MINOR 2)
70     set(CPACK_PACKAGE_VERSION_PATCH a)
71 greg 1.5 set(CPACK_PACKAGE_INSTALL_DIRECTORY "Radiance")
72 greg 1.3 SET(CPACK_RESOURCE_FILE_WELCOME "${radiance_SOURCE_DIR}/Welcome.txt")
73 greg 1.4 SET(CPACK_RESOURCE_FILE_README "${radiance_SOURCE_DIR}/README.txt")
74 greg 1.3 SET(CPACK_RESOURCE_FILE_LICENSE "${radiance_SOURCE_DIR}/License.txt")
75 greg 1.4
76
77 greg 1.1 include(CPack)
78
79 greg 1.9 if(NOT BUILD_HEADLESS)
80     find_package(Qt4 COMPONENTS QtCore QtGui)
81     find_package(X11)
82     endif()
83 greg 1.1
84     SET(EXECUTABLE_OUTPUT_PATH ${PROJECT_BINARY_DIR}/bin)
85
86     if(WIN32 AND "${CMAKE_C_COMPILER_ID}" MATCHES "^(Intel)$")
87     set(_INTEL_WINDOWS 1)
88     endif()
89     if(MSVC OR _INTEL_WINDOWS)
90     add_definitions(-D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE)
91     endif()
92     if(WIN32)
93     add_definitions(-DEZXML_NOMMAP -Dfseeko=fseek -Dstrcasecmp=_stricmp)
94     endif()
95
96     add_subdirectory("src")
97
98 greg 1.5 set(test_dir ${CMAKE_CURRENT_SOURCE_DIR}/test/test\ data)
99     option(BUILD_TESTING "Download support tarball & enable testing?" ON)
100
101     if(BUILD_TESTING)
102     #download and extract radiance support files
103     include(ExternalProject)
104     set(base "${CMAKE_BINARY_DIR}/Downloads")
105     set_property(DIRECTORY PROPERTY EP_BASE ${base})
106     ExternalProject_Add(radiance_support
107     URL http://www.radiance-online.org/software/non-cvs/rad4R1supp.tar.gz
108     URL_MD5 efd82970e1d0747eede8eb64c01048f4
109     CONFIGURE_COMMAND ""
110     BUILD_COMMAND ""
111     INSTALL_COMMAND ""
112     )
113
114     #install support files.
115     set(lib_dir ${base}/Source/radiance_support/lib)
116     install(
117     FILES
118     ${lib_dir}/Earth.cal ${lib_dir}/He.cal ${lib_dir}/He3.cal
119     ${lib_dir}/adobe.cal ${lib_dir}/ball.cal ${lib_dir}/brick.cal
120     ${lib_dir}/brickweave.cal ${lib_dir}/carpet.cal ${lib_dir}/climit.cal
121     ${lib_dir}/corrug.cal ${lib_dir}/covelight.cal ${lib_dir}/cyl.cal
122     ${lib_dir}/dichroic.cal ${lib_dir}/dirt.cal ${lib_dir}/fisheye.cal
123     ${lib_dir}/fishgeom.cal ${lib_dir}/fprism.cal ${lib_dir}/globe.cal
124     ${lib_dir}/gloss.cal ${lib_dir}/grating.cal ${lib_dir}/jigglepic.cal
125     ${lib_dir}/lcp0.cal ${lib_dir}/limit.cal ${lib_dir}/marble.cal
126     ${lib_dir}/orange.cal ${lib_dir}/picture.cal ${lib_dir}/plink.cal
127     ${lib_dir}/prism.cal ${lib_dir}/retrorefl.cal ${lib_dir}/serraglaze.cal
128     ${lib_dir}/slate.cal ${lib_dir}/surf.cal ${lib_dir}/tim1.cal
129     ${lib_dir}/weave.cal ${lib_dir}/winxmit.cal ${lib_dir}/woodpat.cal
130     ${lib_dir}/woodtex.cal ${lib_dir}/wrinkle.cal
131     ${lib_dir}/page1.txt ${lib_dir}/page2.txt
132     ${lib_dir}/Pix.fnt
133     ${lib_dir}/PixOblique.fnt
134     ${lib_dir}/Veerdana.fnt
135     ${lib_dir}/VeerdanaBold.fnt
136     ${lib_dir}/VeerdanaBoldItalic.fnt
137     ${lib_dir}/VeerdanaItalic.fnt
138     ${lib_dir}/helvet.fnt
139     ${lib_dir}/hexbit4x1.fnt
140     ${test_dir}/model.oct
141     ${test_dir}/model.vp
142     DESTINATION lib
143     )
144
145     install(FILES ${lib_dir}/Earth.hdr DESTINATION lib RENAME Earth.pic)
146     install(FILES ${lib_dir}/EarthBig.hdr DESTINATION lib RENAME EarthBig.pic)
147     install(FILES ${lib_dir}/alberta.hdr DESTINATION lib RENAME alberta.pic)
148     install(FILES ${lib_dir}/brick.hdr DESTINATION lib RENAME brick.pic)
149     install(FILES ${lib_dir}/brickweave.hdr DESTINATION lib RENAME brickweave.pic)
150     install(FILES ${lib_dir}/cabin.hdr DESTINATION lib RENAME cabin.pic)
151     install(FILES ${lib_dir}/forestfl.hdr DESTINATION lib RENAME forestfl.pic)
152     install(FILES ${lib_dir}/oakfloor.hdr DESTINATION lib RENAME oakfloor.pic)
153     install(FILES ${lib_dir}/pine.hdr DESTINATION lib RENAME pine.pic)
154     install(FILES ${lib_dir}/pinebark.hdr DESTINATION lib RENAME pinebark.pic)
155     install(FILES ${lib_dir}/podlife.hdr DESTINATION lib RENAME podlife.pic)
156     install(FILES ${lib_dir}/richgrove.hdr DESTINATION lib RENAME richgrove.pic)
157     install(FILES ${lib_dir}/shingle.hdr DESTINATION lib RENAME shingle.pic)
158     install(FILES ${lib_dir}/summercab.hdr DESTINATION lib RENAME summercab.pic)
159     install(FILES ${lib_dir}/tulips.hdr DESTINATION lib RENAME tulips.pic)
160 greg 1.1
161 greg 1.5 add_subdirectory(cmake_tests)
162     endif()
163
164 greg 1.1 install(
165     FILES
166     ${test_dir}/model.oct
167     ${test_dir}/model.vp
168 greg 1.4 DESTINATION lib
169 greg 1.1 )
170
171     include(InstallRequiredSystemLibraries)
172     add_subdirectory(InstallRules)
