root/radiance/ray/CMakeLists.txt
Revision: 1.20
Committed: Wed Jun 20 03:04:44 2018 UTC (6 years ago) by greg
Changes since 1.19: +4 -1 lines
Changes by Randolph Fritz to make cmake compiles smoother on Mac
1 cmake_minimum_required(VERSION 3.0)
2 cmake_policy(SET CMP0020 NEW)
3 cmake_policy(SET CMP0048 NEW)
4 if(NOT ${CMAKE_VERSION} VERSION_LESS "3.1")
5 cmake_policy(SET CMP0054 NEW)
6 endif()
7
8 project(radiance VERSION 5.2.0)
9
10 set(PROJECT_VERSION_TWEAK "Unknown" CACHE STRING "Commit Hash")
11 find_package(Git)
12 if(GIT_FOUND)
13 execute_process(COMMAND "${GIT_EXECUTABLE}" "rev-parse" "--short=10" "HEAD"
14 WORKING_DIRECTORY "${CMAKE_SOURCE_DIR}"
15 TIMEOUT 10
16 RESULT_VARIABLE RESULT
17 OUTPUT_VARIABLE GIT_VERSION
18 ERROR_QUIET
19 OUTPUT_STRIP_TRAILING_WHITESPACE
20 )
21 if(${RESULT} EQUAL 0 AND NOT "${GIT_VERSION}" EQUAL "${PROJECT_VERSION_TWEAK}")
22 set(PROJECT_VERSION_TWEAK ${GIT_VERSION} CACHE STRING "Commit Hash" FORCE)
23 endif()
24 endif()
25
26 enable_testing()
27 include(CTest)
28
29 option(BUILD_SHARED_LIBS "Build radiance using shared libraries?" OFF)
30 option(BUILD_HEADLESS "Build radiance without any GUI components?" OFF)
31 option(BUILD_PABOPTO_UTILS "Build PABOpto Utilities?" OFF)
32 option(BUILD_LIBTIFF "Build libtiff?" OFF)
33
34 if(NOT WIN32)
35 set(CPACK_INCLUDE_TOPLEVEL_DIRECTORY 1)
36 install(DIRECTORY "${CMAKE_CURRENT_SOURCE_DIR}/doc/man/" DESTINATION man)
37 set(qt_plugin_term "PLUGIN")
38 endif()
39
40 if(WIN32)
41 set(CPACK_NSIS_MODIFY_PATH 1)
42 set(qt_plugin_term "LIBRARY")
43
44 # Set RAYPATH on install
45 set(CPACK_NSIS_EXTRA_INSTALL_COMMANDS
46 "WriteRegExpandStr HKLM \\\"SYSTEM\\\\CurrentControlSet\\\\Control\\\\Session Manager\\\\Environment\\\" RAYPATH '\\\$INSTDIR\\\\lib\\\;.'"
47 )
48
49 # Unset RAYPATH on uninstall
50 set(CPACK_NSIS_EXTRA_UNINSTALL_COMMANDS
51 "DeleteRegValue HKLM \\\"SYSTEM\\\\CurrentControlSet\\\\Control\\\\Session Manager\\\\Environment\\\" RAYPATH"
52 )
53 endif()
54
55 if(UNIX)
56 set(CPACK_PACKAGING_INSTALL_PREFIX "/usr/local/radiance")
57 add_definitions(-Dlinux -D_FILE_OFFSET_BITS=64 -DNOSTEREO)
58 else()
59 set(CPACK_PACKAGING_INSTALL_PREFIX "/")
60 endif()
61
62 set(CPACK_PACKAGE_FILE_NAME "${CMAKE_PROJECT_NAME}-${PROJECT_VERSION_MAJOR}.${PROJECT_VERSION_MINOR}.${PROJECT_VERSION_PATCH}.${PROJECT_VERSION_TWEAK}-${CMAKE_SYSTEM_NAME}")
63
64 if(APPLE)
65 set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -std=c11 -std=c++11 -stdlib=libc++")
66 add_definitions(-DBSD -DNOSTEREO -Dfreebsd)
67 #include_directories(/usr/X11R6/include)
68 set(CMAKE_C_FLAGS "${CMAKE_C_FLAGS} -mmacosx-version-min=10.7")
69 endif()
70
71 if(BUILD_LIBTIFF)
72 include(ExternalProject)
73 set(LIBTIFF_URL http://download.osgeo.org/libtiff/tiff-4.0.9.tar.gz)
74 set(LIBTIFF_MD5 54BAD211279CC93EB4FCA31BA9BFDC79)
75 if(WIN32)
76 ExternalProject_Add(libtiff
77 URL ${LIBTIFF_URL}
78 URL_MD5 ${LIBTIFF_MD5}
79 CMAKE_GENERATOR "NMake Makefiles"
80 CMAKE_ARGS
81 "-DBUILD_SHARED_LIBS=OFF"
82 "-DCMAKE_BUILD_TYPE=Release"
83 "-Dzlib=OFF"
84 "../libtiff"
85 INSTALL_COMMAND ""
86 )
87 set(TIFF_LIBRARY ${CMAKE_BINARY_DIR}/libtiff-prefix/src/libtiff-build/libtiff/tiff.lib)
88 else()
89 ExternalProject_Add(libtiff
90 URL ${LIBTIFF_URL}
91 URL_MD5 ${LIBTIFF_MD5}
92 CMAKE_ARGS
93 "-DBUILD_SHARED_LIBS=OFF"
94 "-DCMAKE_BUILD_TYPE=Release"
95 "-Dzlib=OFF"
96 "../libtiff"
97 INSTALL_COMMAND ""
98 )
99 set(TIFF_LIBRARY ${CMAKE_BINARY_DIR}/libtiff-prefix/src/libtiff-build/libtiff/libtiff.a)
100 endif()
101 set(TIFF_INCLUDE_DIR ${CMAKE_BINARY_DIR}/libtiff/src/libtiff/libtiff)
102 endif()
103
104 set(CPACK_PACKAGE_VERSION_MAJOR ${PROJECT_VERSION_MAJOR})
105 set(CPACK_PACKAGE_VERSION_MINOR ${PROJECT_VERSION_MINOR})
106 set(CPACK_PACKAGE_VERSION_PATCH ${PROJECT_VERSION_PATCH})
107 set(CPACK_PACKAGE_INSTALL_DIRECTORY "Radiance")
108 set(CPACK_RESOURCE_FILE_WELCOME "${radiance_SOURCE_DIR}/Welcome.txt")
109 set(CPACK_RESOURCE_FILE_README "${radiance_SOURCE_DIR}/README.txt")
110 set(CPACK_RESOURCE_FILE_LICENSE "${radiance_SOURCE_DIR}/License.txt")
111
112 if(APPLE)
113 set(CPACK_GENERATOR "PackageMaker")
114 elseif(UNIX)
115 set(CPACK_GENERATOR "TGZ")
116 endif()
117
118 include(CPack)
119
120 if(NOT BUILD_HEADLESS)
121 find_package(Qt5Widgets)
122 get_target_property(QT_LIBRARY_DIR Qt5::Core LOCATION)
123 get_filename_component(QT_LIBRARY_DIR ${QT_LIBRARY_DIR} PATH)
124 get_filename_component(QT_LIBRARY_DIR "${QT_LIBRARY_DIR}/.." ABSOLUTE)
125 find_package(X11)
126 if(APPLE)
127 include_directories(${X11_INCLUDE_DIR})
128 endif()
129 endif()
130
131 set(EXECUTABLE_OUTPUT_PATH ${PROJECT_BINARY_DIR}/bin)
132
133 if(MSVC)
134 add_definitions(/MP)
135 endif()
136 if(WIN32 AND "${CMAKE_C_COMPILER_ID}" MATCHES "^(Intel)$")
137 set(_INTEL_WINDOWS 1)
138 endif()
139 if(MSVC OR _INTEL_WINDOWS)
140 add_definitions(-D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE)
141 endif()
142 if(WIN32)
143 add_definitions(-DEZXML_NOMMAP -Dfseeko=fseek -Dstrcasecmp=_stricmp)
144 endif()
145
146 add_subdirectory("src")
147
148 set(test_dir "${CMAKE_CURRENT_SOURCE_DIR}/test/test data")
149
150 add_subdirectory(resources)
151
152 install(DIRECTORY "${CMAKE_BINARY_DIR}/lib/"
153 DESTINATION "lib"
154 )
155
156 include(InstallRequiredSystemLibraries)
157 add_subdirectory(InstallRules)
