| 1 |
# RCSid $Id: CMakeLists.txt,v 1.33 2025/07/24 01:24:01 greg Exp $ |
| 2 |
| 3 |
cmake_minimum_required(VERSION 3.12) |
| 4 |
cmake_policy(SET CMP0020 NEW) |
| 5 |
cmake_policy(SET CMP0048 NEW) |
| 6 |
cmake_policy(SET CMP0054 NEW) |
| 7 |
cmake_policy(SET CMP0074 NEW) |
| 8 |
| 9 |
# project-defined modules |
| 10 |
set(CMAKE_MODULE_PATH "${CMAKE_CURRENT_LIST_DIR}/resources/cmake/modules") |
| 11 |
| 12 |
set(SUPPORTED_LANGUAGES C CXX) |
| 13 |
| 14 |
# Get the project version. |
| 15 |
set(VERSIONFILE "${CMAKE_CURRENT_LIST_DIR}/src/rt/VERSION") |
| 16 |
if(EXISTS ${VERSIONFILE}) |
| 17 |
file(READ ${VERSIONFILE} NAMEVERSION) |
| 18 |
if(${NAMEVERSION} MATCHES "^([A-Za-z]+) +([0-9]+\\.[0-9]+)") |
| 19 |
# project name must be lower case, or the CPack module fails |
| 20 |
string(TOLOWER ${CMAKE_MATCH_1} PROGNAME) |
| 21 |
project(${PROGNAME} VERSION ${CMAKE_MATCH_2} LANGUAGES ${SUPPORTED_LANGUAGES}) |
| 22 |
endif() |
| 23 |
else() |
| 24 |
project(radiance LANGUAGES ${SUPPORTED_LANGUAGES}) |
| 25 |
endif() |
| 26 |
| 27 |
message("Project: " ${CMAKE_PROJECT_NAME} " " ${PROJECT_VERSION}) |
| 28 |
| 29 |
set(PROJECT_VERSION_TWEAK "Unknown" CACHE STRING "Commit Hash") |
| 30 |
find_package(Git) |
| 31 |
if(GIT_FOUND) |
| 32 |
execute_process(COMMAND "${GIT_EXECUTABLE}" "rev-parse" "--short=10" "HEAD" |
| 33 |
WORKING_DIRECTORY "${CMAKE_SOURCE_DIR}" |
| 34 |
TIMEOUT 10 |
| 35 |
RESULT_VARIABLE RESULT |
| 36 |
OUTPUT_VARIABLE GIT_VERSION |
| 37 |
ERROR_QUIET |
| 38 |
OUTPUT_STRIP_TRAILING_WHITESPACE |
| 39 |
| 40 |
if(${RESULT} EQUAL 0 AND NOT "${GIT_VERSION}" EQUAL "${PROJECT_VERSION_TWEAK}") |
| 41 |
set(PROJECT_VERSION_TWEAK ${GIT_VERSION} CACHE STRING "Commit Hash" FORCE) |
| 42 |
endif() |
| 43 |
endif() |
| 44 |
| 45 |
enable_testing() |
| 46 |
include(CTest) |
| 47 |
| 48 |
option(BUILD_SHARED_LIBS "Build radiance using shared libraries?" OFF) |
| 49 |
option(BUILD_HEADLESS "Build radiance without any GUI components?" OFF) |
| 50 |
option(BUILD_PABOPTO_UTILS "Build PABOpto Utilities?" OFF) |
| 51 |
option(BUILD_LIBTIFF "Build libtiff?" OFF) |
| 52 |
option(BUILD_QT "Build Qt related stuff?" OFF) |
| 53 |
| 54 |
if(NOT WIN32) |
| 55 |
set(CPACK_INCLUDE_TOPLEVEL_DIRECTORY 1) |
| 56 |
install(DIRECTORY "${CMAKE_CURRENT_SOURCE_DIR}/doc/man/" DESTINATION man) |
| 57 |
if(BUILD_QT) |
| 58 |
set(qt_plugin_term "PLUGIN") |
| 59 |
endif() |
| 60 |
endif() |
| 61 |
| 62 |
if(WIN32) |
| 63 |
set(CPACK_NSIS_INSTALL_ROOT "C:") |
| 64 |
set(CPACK_NSIS_MODIFY_PATH 1) |
| 65 |
if(BUILD_QT) |
| 66 |
set(qt_plugin_term "LIBRARY") |
| 67 |
endif() |
| 68 |
| 69 |
# Set RAYPATH on install |
| 70 |
set(CPACK_NSIS_EXTRA_INSTALL_COMMANDS |
| 71 |
"WriteRegExpandStr HKLM \\\"SYSTEM\\\\CurrentControlSet\\\\Control\\\\Session Manager\\\\Environment\\\" RAYPATH '\\\$INSTDIR\\\\lib\\\;.'" |
| 72 |
| 73 |
| 74 |
# Unset RAYPATH on uninstall |
| 75 |
set(CPACK_NSIS_EXTRA_UNINSTALL_COMMANDS |
| 76 |
"DeleteRegValue HKLM \\\"SYSTEM\\\\CurrentControlSet\\\\Control\\\\Session Manager\\\\Environment\\\" RAYPATH" |
| 77 |
| 78 |
endif() |
| 79 |
| 80 |
if(UNIX) |
| 81 |
set(CPACK_PACKAGING_INSTALL_PREFIX "/usr/local/radiance") |
| 82 |
add_definitions(-Dlinux -D_FILE_OFFSET_BITS=64 -DNOSTEREO) |
| 83 |
else() |
| 84 |
set(CPACK_PACKAGING_INSTALL_PREFIX "/") |
| 85 |
endif() |
| 86 |
| 87 |
set(CPACK_PACKAGE_FILE_NAME "${CMAKE_PROJECT_NAME}-${PROJECT_VERSION_MAJOR}.${PROJECT_VERSION_MINOR}.${PROJECT_VERSION_TWEAK}-${CMAKE_SYSTEM_NAME}") |
| 88 |
| 89 |
if(APPLE) |
| 90 |
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -std=c11 -std=c++11 -stdlib=libc++") |
| 91 |
add_compile_options(-O2 -DBSD -DNOSTEREO -Dfreebsd) |
| 92 |
add_definitions(-DBSD -DNOSTEREO -Dfreebsd) |
| 93 |
set(CMAKE_OSX_DEPLOYMENT_TARGET "10.13") |
| 94 |
endif() |
| 95 |
| 96 |
if(BUILD_LIBTIFF) |
| 97 |
include(ExternalProject) |
| 98 |
set(LIBTIFF_URL http://download.osgeo.org/libtiff/tiff-4.7.0.tar.gz) |
| 99 |
set(LIBTIFF_MD5 3A0FA4A270A4A192B08913F88D0CFBDD) |
| 100 |
if(WIN32) |
| 101 |
ExternalProject_Add(libtiff |
| 102 |
URL ${LIBTIFF_URL} |
| 103 |
URL_MD5 ${LIBTIFF_MD5} |
| 104 |
CMAKE_GENERATOR "NMake Makefiles" |
| 105 |
CMAKE_ARGS |
| 106 |
"-DBUILD_SHARED_LIBS=OFF" |
| 107 |
"-DCMAKE_BUILD_TYPE=Release" |
| 108 |
"-Djpeg=OFF" |
| 109 |
"-Dzlib=OFF" |
| 110 |
"-Dwebp=OFF" |
| 111 |
"-Dlzma=OFF" |
| 112 |
"-Dtiff-tools=OFF" |
| 113 |
"-Dtiff-tests=OFF" |
| 114 |
"-Dtiff-docs=OFF" |
| 115 |
"../libtiff" |
| 116 |
INSTALL_COMMAND "" |
| 117 |
| 118 |
set(TIFF_LIBRARY ${CMAKE_BINARY_DIR}/libtiff-prefix/src/libtiff-build/libtiff/tiff.lib) |
| 119 |
else() |
| 120 |
| 121 |
| 122 |
| 123 |
CMAKE_ARGS |
| 124 |
| 125 |
| 126 |
"-Djpeg=OFF" |
| 127 |
"-Dzlib=OFF" |
| 128 |
"-Dwebp=OFF" |
| 129 |
"-Dlzma=OFF" |
| 130 |
| 131 |
| 132 |
"-Dtiff-docs=OFF" |
| 133 |
"../libtiff" |
| 134 |
| 135 |
| 136 |
set(TIFF_LIBRARY ${CMAKE_BINARY_DIR}/libtiff-prefix/src/libtiff-build/libtiff/libtiff.a) |
| 137 |
endif() |
| 138 |
set(TIFF_INCLUDE_DIR ${CMAKE_BINARY_DIR}/libtiff/src/libtiff/libtiff) |
| 139 |
endif() |
| 140 |
| 141 |
set(CPACK_PACKAGE_VERSION_MAJOR ${PROJECT_VERSION_MAJOR}) |
| 142 |
set(CPACK_PACKAGE_VERSION_MINOR ${PROJECT_VERSION_MINOR}) |
| 143 |
set(CPACK_PACKAGE_INSTALL_DIRECTORY "Radiance") |
| 144 |
set(CPACK_RESOURCE_FILE_WELCOME "${radiance_SOURCE_DIR}/Welcome.txt") |
| 145 |
set(CPACK_RESOURCE_FILE_README "${radiance_SOURCE_DIR}/README.txt") |
| 146 |
set(CPACK_RESOURCE_FILE_LICENSE "${radiance_SOURCE_DIR}/License.txt") |
| 147 |
| 148 |
if(APPLE) |
| 149 |
set(CPACK_GENERATOR "PackageMaker") |
| 150 |
elseif(UNIX) |
| 151 |
set(CPACK_GENERATOR "TGZ") |
| 152 |
endif() |
| 153 |
| 154 |
include(CPack) |
| 155 |
| 156 |
if(NOT BUILD_HEADLESS) |
| 157 |
if(BUILD_QT) |
| 158 |
find_package(Qt5Widgets) |
| 159 |
get_target_property(QT_LIBRARY_DIR Qt5::Core LOCATION) |
| 160 |
get_filename_component(QT_LIBRARY_DIR ${QT_LIBRARY_DIR} PATH) |
| 161 |
get_filename_component(QT_LIBRARY_DIR "${QT_LIBRARY_DIR}/.." ABSOLUTE) |
| 162 |
endif() |
| 163 |
if(APPLE) |
| 164 |
set(X11_ROOT "/opt/X11") |
| 165 |
endif() |
| 166 |
find_package(X11) |
| 167 |
if(APPLE) |
| 168 |
include_directories(${X11_INCLUDE_DIR}) |
| 169 |
endif() |
| 170 |
if(APPLE AND X11_FOUND) |
| 171 |
set(CMAKE_FIND_FRAMEWORK NEVER) |
| 172 |
set(OpenGL_ROOT "/opt/X11") |
| 173 |
find_package(OpenGL) |
| 174 |
set(CMAKE_FIND_FRAMEWORK "") |
| 175 |
else() |
| 176 |
| 177 |
endif() |
| 178 |
| 179 |
endif() |
| 180 |
| 181 |
set(EXECUTABLE_OUTPUT_PATH ${PROJECT_BINARY_DIR}/bin) |
| 182 |
| 183 |
if(MSVC) |
| 184 |
add_definitions(/MP) |
| 185 |
# Suppress warnings about double-to-float assignments and initializations |
| 186 |
add_compile_options(/wd"4244" /wd"4305") |
| 187 |
endif() |
| 188 |
if(WIN32 AND "${CMAKE_C_COMPILER_ID}" MATCHES "^(Intel)$") |
| 189 |
set(_INTEL_WINDOWS 1) |
| 190 |
endif() |
| 191 |
if(MSVC OR _INTEL_WINDOWS) |
| 192 |
add_definitions(-D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE) |
| 193 |
endif() |
| 194 |
if(WIN32) |
| 195 |
add_definitions(-DEZXML_NOMMAP -Dfseeko=fseek -Dstrcasecmp=_stricmp) |
| 196 |
endif() |
| 197 |
| 198 |
add_subdirectory("src") |
| 199 |
| 200 |
set(test_dir "${CMAKE_CURRENT_SOURCE_DIR}/test/test data") |
| 201 |
| 202 |
add_subdirectory(resources) |
| 203 |
| 204 |
install(DIRECTORY "${CMAKE_BINARY_DIR}/lib/" |
| 205 |
DESTINATION "lib" |
| 206 |
| 207 |
| 208 |
# copy make tests to build |
| 209 |
file(COPY test DESTINATION ${CMAKE_BINARY_DIR}) |
| 210 |
| 211 |
| 212 |
include(InstallRequiredSystemLibraries) |
| 213 |
add_subdirectory(InstallRules) |
