root/Development/ray/CMakeLists.txt
Revision: 1.34
Committed: Sun Sep 28 19:53:23 2025 UTC (5 weeks, 1 day ago) by greg
Changes since 1.33: +15 -4 lines
chore: Mingbo fixed libtiff issues under Windows
1 # RCSid $Id: CMakeLists.txt,v 1.33 2025/07/24 01:24:01 greg Exp $
2
3 cmake_minimum_required(VERSION 3.12)
4 cmake_policy(SET CMP0020 NEW)
5 cmake_policy(SET CMP0048 NEW)
6 cmake_policy(SET CMP0054 NEW)
7 cmake_policy(SET CMP0074 NEW)
8
9 # project-defined modules
10 set(CMAKE_MODULE_PATH "${CMAKE_CURRENT_LIST_DIR}/resources/cmake/modules")
11
12 set(SUPPORTED_LANGUAGES C CXX)
13
14 # Get the project version.
15 set(VERSIONFILE "${CMAKE_CURRENT_LIST_DIR}/src/rt/VERSION")
16 if(EXISTS ${VERSIONFILE})
17 file(READ ${VERSIONFILE} NAMEVERSION)
18 if(${NAMEVERSION} MATCHES "^([A-Za-z]+) +([0-9]+\\.[0-9]+)")
19 # project name must be lower case, or the CPack module fails
20 string(TOLOWER ${CMAKE_MATCH_1} PROGNAME)
21 project(${PROGNAME} VERSION ${CMAKE_MATCH_2} LANGUAGES ${SUPPORTED_LANGUAGES})
22 endif()
23 else()
24 project(radiance LANGUAGES ${SUPPORTED_LANGUAGES})
25 endif()
26
27 message("Project: " ${CMAKE_PROJECT_NAME} " " ${PROJECT_VERSION})
28
29 set(PROJECT_VERSION_TWEAK "Unknown" CACHE STRING "Commit Hash")
30 find_package(Git)
31 if(GIT_FOUND)
32 execute_process(COMMAND "${GIT_EXECUTABLE}" "rev-parse" "--short=10" "HEAD"
33 WORKING_DIRECTORY "${CMAKE_SOURCE_DIR}"
34 TIMEOUT 10
35 RESULT_VARIABLE RESULT
36 OUTPUT_VARIABLE GIT_VERSION
37 ERROR_QUIET
38 OUTPUT_STRIP_TRAILING_WHITESPACE
39 )
40 if(${RESULT} EQUAL 0 AND NOT "${GIT_VERSION}" EQUAL "${PROJECT_VERSION_TWEAK}")
41 set(PROJECT_VERSION_TWEAK ${GIT_VERSION} CACHE STRING "Commit Hash" FORCE)
42 endif()
43 endif()
44
45 enable_testing()
46 include(CTest)
47
48 option(BUILD_SHARED_LIBS "Build radiance using shared libraries?" OFF)
49 option(BUILD_HEADLESS "Build radiance without any GUI components?" OFF)
50 option(BUILD_PABOPTO_UTILS "Build PABOpto Utilities?" OFF)
51 option(BUILD_LIBTIFF "Build libtiff?" OFF)
52 option(BUILD_QT "Build Qt related stuff?" OFF)
53
54 if(NOT WIN32)
55 set(CPACK_INCLUDE_TOPLEVEL_DIRECTORY 1)
56 install(DIRECTORY "${CMAKE_CURRENT_SOURCE_DIR}/doc/man/" DESTINATION man)
57 if(BUILD_QT)
58 set(qt_plugin_term "PLUGIN")
59 endif()
60 endif()
61
62 if(WIN32)
63 set(CPACK_NSIS_INSTALL_ROOT "C:")
64 set(CPACK_NSIS_MODIFY_PATH 1)
65 if(BUILD_QT)
66 set(qt_plugin_term "LIBRARY")
67 endif()
68
69 # Set RAYPATH on install
70 set(CPACK_NSIS_EXTRA_INSTALL_COMMANDS
71 "WriteRegExpandStr HKLM \\\"SYSTEM\\\\CurrentControlSet\\\\Control\\\\Session Manager\\\\Environment\\\" RAYPATH '\\\$INSTDIR\\\\lib\\\;.'"
72 )
73
74 # Unset RAYPATH on uninstall
75 set(CPACK_NSIS_EXTRA_UNINSTALL_COMMANDS
76 "DeleteRegValue HKLM \\\"SYSTEM\\\\CurrentControlSet\\\\Control\\\\Session Manager\\\\Environment\\\" RAYPATH"
77 )
78 endif()
79
80 if(UNIX)
81 set(CPACK_PACKAGING_INSTALL_PREFIX "/usr/local/radiance")
82 add_definitions(-Dlinux -D_FILE_OFFSET_BITS=64 -DNOSTEREO)
83 else()
84 set(CPACK_PACKAGING_INSTALL_PREFIX "/")
85 endif()
86
87 set(CPACK_PACKAGE_FILE_NAME "${CMAKE_PROJECT_NAME}-${PROJECT_VERSION_MAJOR}.${PROJECT_VERSION_MINOR}.${PROJECT_VERSION_TWEAK}-${CMAKE_SYSTEM_NAME}")
88
89 if(APPLE)
90 set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -std=c11 -std=c++11 -stdlib=libc++")
91 add_compile_options(-O2 -DBSD -DNOSTEREO -Dfreebsd)
92 add_definitions(-DBSD -DNOSTEREO -Dfreebsd)
93 set(CMAKE_OSX_DEPLOYMENT_TARGET "10.13")
94 endif()
95
96 if(BUILD_LIBTIFF)
97 include(ExternalProject)
98 set(LIBTIFF_URL http://download.osgeo.org/libtiff/tiff-4.7.0.tar.gz)
99 set(LIBTIFF_MD5 3A0FA4A270A4A192B08913F88D0CFBDD)
100 if(WIN32)
101 ExternalProject_Add(libtiff
102 URL ${LIBTIFF_URL}
103 URL_MD5 ${LIBTIFF_MD5}
104 CMAKE_GENERATOR "NMake Makefiles"
105 CMAKE_ARGS
106 "-DBUILD_SHARED_LIBS=OFF"
107 "-DCMAKE_BUILD_TYPE=Release"
108 "-Djpeg=OFF"
109 "-Dzlib=OFF"
110 "-Dwebp=OFF"
111 "-Dlzma=OFF"
112 "-Dtiff-tools=OFF"
113 "-Dtiff-tests=OFF"
114 "-Dtiff-docs=OFF"
115 "../libtiff"
116 INSTALL_COMMAND ""
117 )
118 set(TIFF_LIBRARY ${CMAKE_BINARY_DIR}/libtiff-prefix/src/libtiff-build/libtiff/tiff.lib)
119 else()
120 ExternalProject_Add(libtiff
121 URL ${LIBTIFF_URL}
122 URL_MD5 ${LIBTIFF_MD5}
123 CMAKE_ARGS
124 "-DBUILD_SHARED_LIBS=OFF"
125 "-DCMAKE_BUILD_TYPE=Release"
126 "-Djpeg=OFF"
127 "-Dzlib=OFF"
128 "-Dwebp=OFF"
129 "-Dlzma=OFF"
130 "-Dtiff-tools=OFF"
131 "-Dtiff-tests=OFF"
132 "-Dtiff-docs=OFF"
133 "../libtiff"
134 INSTALL_COMMAND ""
135 )
136 set(TIFF_LIBRARY ${CMAKE_BINARY_DIR}/libtiff-prefix/src/libtiff-build/libtiff/libtiff.a)
137 endif()
138 set(TIFF_INCLUDE_DIR ${CMAKE_BINARY_DIR}/libtiff/src/libtiff/libtiff)
139 endif()
140
141 set(CPACK_PACKAGE_VERSION_MAJOR ${PROJECT_VERSION_MAJOR})
142 set(CPACK_PACKAGE_VERSION_MINOR ${PROJECT_VERSION_MINOR})
143 set(CPACK_PACKAGE_INSTALL_DIRECTORY "Radiance")
144 set(CPACK_RESOURCE_FILE_WELCOME "${radiance_SOURCE_DIR}/Welcome.txt")
145 set(CPACK_RESOURCE_FILE_README "${radiance_SOURCE_DIR}/README.txt")
146 set(CPACK_RESOURCE_FILE_LICENSE "${radiance_SOURCE_DIR}/License.txt")
147
148 if(APPLE)
149 set(CPACK_GENERATOR "PackageMaker")
150 elseif(UNIX)
151 set(CPACK_GENERATOR "TGZ")
152 endif()
153
154 include(CPack)
155
156 if(NOT BUILD_HEADLESS)
157 if(BUILD_QT)
158 find_package(Qt5Widgets)
159 get_target_property(QT_LIBRARY_DIR Qt5::Core LOCATION)
160 get_filename_component(QT_LIBRARY_DIR ${QT_LIBRARY_DIR} PATH)
161 get_filename_component(QT_LIBRARY_DIR "${QT_LIBRARY_DIR}/.." ABSOLUTE)
162 endif()
163 if(APPLE)
164 set(X11_ROOT "/opt/X11")
165 endif()
166 find_package(X11)
167 if(APPLE)
168 include_directories(${X11_INCLUDE_DIR})
169 endif()
170 if(APPLE AND X11_FOUND)
171 set(CMAKE_FIND_FRAMEWORK NEVER)
172 set(OpenGL_ROOT "/opt/X11")
173 find_package(OpenGL)
174 set(CMAKE_FIND_FRAMEWORK "")
175 else()
176 find_package(OpenGL)
177 endif()
178
179 endif()
180
181 set(EXECUTABLE_OUTPUT_PATH ${PROJECT_BINARY_DIR}/bin)
182
183 if(MSVC)
184 add_definitions(/MP)
185 # Suppress warnings about double-to-float assignments and initializations
186 add_compile_options(/wd"4244" /wd"4305")
187 endif()
188 if(WIN32 AND "${CMAKE_C_COMPILER_ID}" MATCHES "^(Intel)$")
189 set(_INTEL_WINDOWS 1)
190 endif()
191 if(MSVC OR _INTEL_WINDOWS)
192 add_definitions(-D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE)
193 endif()
194 if(WIN32)
195 add_definitions(-DEZXML_NOMMAP -Dfseeko=fseek -Dstrcasecmp=_stricmp)
196 endif()
197
198 add_subdirectory("src")
199
200 set(test_dir "${CMAKE_CURRENT_SOURCE_DIR}/test/test data")
201
202 add_subdirectory(resources)
203
204 install(DIRECTORY "${CMAKE_BINARY_DIR}/lib/"
205 DESTINATION "lib"
206 )
207
208 # copy make tests to build
209 file(COPY test DESTINATION ${CMAKE_BINARY_DIR})
210
211
212 include(InstallRequiredSystemLibraries)
213 add_subdirectory(InstallRules)
