root/radiance/ray/CMakeLists.txt
Revision: 1.30
Committed: Wed Nov 22 17:12:58 2023 UTC (5 months, 3 weeks ago) by greg
Changes since 1.29: +33 -6 lines
chore: Fixes to cmake builds for holodeck and OpenGL thanks to Randolph Fritz
1 cmake_minimum_required(VERSION 3.12)
2 cmake_policy(SET CMP0020 NEW)
3 cmake_policy(SET CMP0048 NEW)
4 cmake_policy(SET CMP0054 NEW)
5 cmake_policy(SET CMP0074 NEW)
6
7 # project-defined modules
8 set(CMAKE_MODULE_PATH "${CMAKE_CURRENT_LIST_DIR}/resources/cmake/modules")
9
10 # Get the project version.
11 set(VERSIONFILE "${CMAKE_CURRENT_LIST_DIR}/src/rt/VERSION")
12 if(EXISTS ${VERSIONFILE})
13 file(READ ${VERSIONFILE} NAMEVERSION)
14 if(${NAMEVERSION} MATCHES "^([A-Za-z]+) +([0-9]+\\.[0-9]+)")
15 # project name must be lower case, or the CPack module fails
16 string(TOLOWER ${CMAKE_MATCH_1} PROGNAME)
17 project(${PROGNAME} VERSION ${CMAKE_MATCH_2} LANGUAGES C)
18 endif()
19 else()
20 project(radiance LANGUAGES C)
21 endif()
22
23 message("Project: " ${CMAKE_PROJECT_NAME} " " ${PROJECT_VERSION})
24
25 set(PROJECT_VERSION_TWEAK "Unknown" CACHE STRING "Commit Hash")
26 find_package(Git)
27 if(GIT_FOUND)
28 execute_process(COMMAND "${GIT_EXECUTABLE}" "rev-parse" "--short=10" "HEAD"
29 WORKING_DIRECTORY "${CMAKE_SOURCE_DIR}"
30 TIMEOUT 10
31 RESULT_VARIABLE RESULT
32 OUTPUT_VARIABLE GIT_VERSION
33 ERROR_QUIET
34 OUTPUT_STRIP_TRAILING_WHITESPACE
35 )
36 if(${RESULT} EQUAL 0 AND NOT "${GIT_VERSION}" EQUAL "${PROJECT_VERSION_TWEAK}")
37 set(PROJECT_VERSION_TWEAK ${GIT_VERSION} CACHE STRING "Commit Hash" FORCE)
38 endif()
39 endif()
40
41 enable_testing()
42 include(CTest)
43
44 option(BUILD_SHARED_LIBS "Build radiance using shared libraries?" OFF)
45 option(BUILD_HEADLESS "Build radiance without any GUI components?" OFF)
46 option(BUILD_PABOPTO_UTILS "Build PABOpto Utilities?" OFF)
47 option(BUILD_LIBTIFF "Build libtiff?" OFF)
48 option(BUILD_QT "Build Qt related stuff?" OFF)
49
50 if(NOT WIN32)
51 set(CPACK_INCLUDE_TOPLEVEL_DIRECTORY 1)
52 install(DIRECTORY "${CMAKE_CURRENT_SOURCE_DIR}/doc/man/" DESTINATION man)
53 if(BUILD_QT)
54 set(qt_plugin_term "PLUGIN")
55 endif()
56 endif()
57
58 if(WIN32)
59 set(CPACK_NSIS_INSTALL_ROOT "C:")
60 set(CPACK_NSIS_MODIFY_PATH 1)
61 if(BUILD_QT)
62 set(qt_plugin_term "LIBRARY")
63 endif()
64
65 # Set RAYPATH on install
66 set(CPACK_NSIS_EXTRA_INSTALL_COMMANDS
67 "WriteRegExpandStr HKLM \\\"SYSTEM\\\\CurrentControlSet\\\\Control\\\\Session Manager\\\\Environment\\\" RAYPATH '\\\$INSTDIR\\\\lib\\\;.'"
68 )
69
70 # Unset RAYPATH on uninstall
71 set(CPACK_NSIS_EXTRA_UNINSTALL_COMMANDS
72 "DeleteRegValue HKLM \\\"SYSTEM\\\\CurrentControlSet\\\\Control\\\\Session Manager\\\\Environment\\\" RAYPATH"
73 )
74 endif()
75
76 if(UNIX)
77 set(CPACK_PACKAGING_INSTALL_PREFIX "/usr/local/radiance")
78 add_definitions(-Dlinux -D_FILE_OFFSET_BITS=64 -DNOSTEREO)
79 else()
80 set(CPACK_PACKAGING_INSTALL_PREFIX "/")
81 endif()
82
83 set(CPACK_PACKAGE_FILE_NAME "${CMAKE_PROJECT_NAME}-${PROJECT_VERSION_MAJOR}.${PROJECT_VERSION_MINOR}.${PROJECT_VERSION_TWEAK}-${CMAKE_SYSTEM_NAME}")
84
85 if(APPLE)
86 set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -std=c11 -std=c++11 -stdlib=libc++")
87 add_definitions(-DBSD -DNOSTEREO -Dfreebsd)
88 set(CMAKE_OSX_DEPLOYMENT_TARGET "10.13")
89 endif()
90
91 if(BUILD_LIBTIFF)
92 include(ExternalProject)
93 set(LIBTIFF_URL http://download.osgeo.org/libtiff/tiff-4.0.9.tar.gz)
94 set(LIBTIFF_MD5 54BAD211279CC93EB4FCA31BA9BFDC79)
95 if(WIN32)
96 ExternalProject_Add(libtiff
97 URL ${LIBTIFF_URL}
98 URL_MD5 ${LIBTIFF_MD5}
99 CMAKE_GENERATOR "NMake Makefiles"
100 CMAKE_ARGS
101 "-UHAVE_UNISTD_H"
102 "-DBUILD_SHARED_LIBS=OFF"
103 "-DCMAKE_BUILD_TYPE=Release"
104 "-Dzlib=OFF"
105 "../libtiff"
106 INSTALL_COMMAND ""
107 )
108 set(TIFF_LIBRARY ${CMAKE_BINARY_DIR}/libtiff-prefix/src/libtiff-build/libtiff/tiff.lib)
109 else()
110 ExternalProject_Add(libtiff
111 URL ${LIBTIFF_URL}
112 URL_MD5 ${LIBTIFF_MD5}
113 CMAKE_ARGS
114 "-DBUILD_SHARED_LIBS=OFF"
115 "-DCMAKE_BUILD_TYPE=Release"
116 "-Dzlib=OFF"
117 "../libtiff"
118 INSTALL_COMMAND ""
119 )
120 set(TIFF_LIBRARY ${CMAKE_BINARY_DIR}/libtiff-prefix/src/libtiff-build/libtiff/libtiff.a)
121 endif()
122 set(TIFF_INCLUDE_DIR ${CMAKE_BINARY_DIR}/libtiff/src/libtiff/libtiff)
123 endif()
124
125 set(CPACK_PACKAGE_VERSION_MAJOR ${PROJECT_VERSION_MAJOR})
126 set(CPACK_PACKAGE_VERSION_MINOR ${PROJECT_VERSION_MINOR})
127 set(CPACK_PACKAGE_INSTALL_DIRECTORY "Radiance")
128 set(CPACK_RESOURCE_FILE_WELCOME "${radiance_SOURCE_DIR}/Welcome.txt")
129 set(CPACK_RESOURCE_FILE_README "${radiance_SOURCE_DIR}/README.txt")
130 set(CPACK_RESOURCE_FILE_LICENSE "${radiance_SOURCE_DIR}/License.txt")
131
132 if(APPLE)
133 set(CPACK_GENERATOR "PackageMaker")
134 elseif(UNIX)
135 set(CPACK_GENERATOR "TGZ")
136 endif()
137
138 include(CPack)
139
140 if(NOT BUILD_HEADLESS)
141 if(BUILD_QT)
142 find_package(Qt5Widgets)
143 get_target_property(QT_LIBRARY_DIR Qt5::Core LOCATION)
144 get_filename_component(QT_LIBRARY_DIR ${QT_LIBRARY_DIR} PATH)
145 get_filename_component(QT_LIBRARY_DIR "${QT_LIBRARY_DIR}/.." ABSOLUTE)
146 endif()
147 if(APPLE)
148 set(X11_ROOT "/opt/X11")
149 endif()
150 find_package(X11)
151 if(APPLE)
152 include_directories(${X11_INCLUDE_DIR})
153 endif()
154 if(APPLE AND X11_FOUND)
155 set(CMAKE_FIND_FRAMEWORK NEVER)
156 set(OpenGL_ROOT "/opt/X11")
157 find_package(OpenGL)
158 set(CMAKE_FIND_FRAMEWORK "")
159 else()
160 find_package(OpenGL)
161 endif()
162
163 endif()
164
165 set(EXECUTABLE_OUTPUT_PATH ${PROJECT_BINARY_DIR}/bin)
166
167 if(MSVC)
168 add_definitions(/MP)
169 # Suppress warnings about double-to-float assignments and initializations
170 add_compile_options(/wd"4244" /wd"4305")
171 endif()
172 if(WIN32 AND "${CMAKE_C_COMPILER_ID}" MATCHES "^(Intel)$")
173 set(_INTEL_WINDOWS 1)
174 endif()
175 if(MSVC OR _INTEL_WINDOWS)
176 add_definitions(-D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE)
177 endif()
178 if(WIN32)
179 add_definitions(-DEZXML_NOMMAP -Dfseeko=fseek -Dstrcasecmp=_stricmp)
180 endif()
181
182 add_subdirectory("src")
183
184 set(test_dir "${CMAKE_CURRENT_SOURCE_DIR}/test/test data")
185
186 add_subdirectory(resources)
187
188 install(DIRECTORY "${CMAKE_BINARY_DIR}/lib/"
189 DESTINATION "lib"
190 )
191
192 # copy make tests to build
193 file(COPY test DESTINATION ${CMAKE_BINARY_DIR})
194
195
196 include(InstallRequiredSystemLibraries)
197 add_subdirectory(InstallRules)
