root/radiance/ray/CMakeLists.txt
Revision: 1.25
Committed: Wed Jan 11 23:18:57 2023 UTC (16 months, 1 week ago) by greg
Changes since 1.24: +6 -5 lines
chore(libtiff): Trying to fix compile issue for libtiff under Windows
1 cmake_minimum_required(VERSION 3.0)
2 cmake_policy(SET CMP0020 NEW)
3 cmake_policy(SET CMP0048 NEW)
4 if(NOT ${CMAKE_VERSION} VERSION_LESS "3.1")
5 cmake_policy(SET CMP0054 NEW)
6 endif()
7
8 project(radiance VERSION 5.2.0)
9
10 set(PROJECT_VERSION_TWEAK "Unknown" CACHE STRING "Commit Hash")
11 find_package(Git)
12 if(GIT_FOUND)
13 execute_process(COMMAND "${GIT_EXECUTABLE}" "rev-parse" "--short=10" "HEAD"
14 WORKING_DIRECTORY "${CMAKE_SOURCE_DIR}"
15 TIMEOUT 10
16 RESULT_VARIABLE RESULT
17 OUTPUT_VARIABLE GIT_VERSION
18 ERROR_QUIET
19 OUTPUT_STRIP_TRAILING_WHITESPACE
20 )
21 if(${RESULT} EQUAL 0 AND NOT "${GIT_VERSION}" EQUAL "${PROJECT_VERSION_TWEAK}")
22 set(PROJECT_VERSION_TWEAK ${GIT_VERSION} CACHE STRING "Commit Hash" FORCE)
23 endif()
24 endif()
25
26 enable_testing()
27 include(CTest)
28
29 option(BUILD_SHARED_LIBS "Build radiance using shared libraries?" OFF)
30 option(BUILD_HEADLESS "Build radiance without any GUI components?" OFF)
31 option(BUILD_PABOPTO_UTILS "Build PABOpto Utilities?" OFF)
32 option(BUILD_LIBTIFF "Build libtiff?" OFF)
33
34 if(NOT WIN32)
35 set(CPACK_INCLUDE_TOPLEVEL_DIRECTORY 1)
36 install(DIRECTORY "${CMAKE_CURRENT_SOURCE_DIR}/doc/man/" DESTINATION man)
37 # set(qt_plugin_term "PLUGIN")
38 endif()
39
40 if(WIN32)
41 set(CPACK_NSIS_INSTALL_ROOT "C:")
42 set(CPACK_NSIS_MODIFY_PATH 1)
43 set(qt_plugin_term "LIBRARY")
44
45 # Set RAYPATH on install
46 set(CPACK_NSIS_EXTRA_INSTALL_COMMANDS
47 "WriteRegExpandStr HKLM \\\"SYSTEM\\\\CurrentControlSet\\\\Control\\\\Session Manager\\\\Environment\\\" RAYPATH '\\\$INSTDIR\\\\lib\\\;.'"
48 )
49
50 # Unset RAYPATH on uninstall
51 set(CPACK_NSIS_EXTRA_UNINSTALL_COMMANDS
52 "DeleteRegValue HKLM \\\"SYSTEM\\\\CurrentControlSet\\\\Control\\\\Session Manager\\\\Environment\\\" RAYPATH"
53 )
54 endif()
55
56 if(UNIX)
57 set(CPACK_PACKAGING_INSTALL_PREFIX "/usr/local/radiance")
58 add_definitions(-Dlinux -D_FILE_OFFSET_BITS=64 -DNOSTEREO)
59 else()
60 set(CPACK_PACKAGING_INSTALL_PREFIX "/")
61 endif()
62
63 set(CPACK_PACKAGE_FILE_NAME "${CMAKE_PROJECT_NAME}-${PROJECT_VERSION_MAJOR}.${PROJECT_VERSION_MINOR}.${PROJECT_VERSION_TWEAK}-${CMAKE_SYSTEM_NAME}")
64
65 if(APPLE)
66 set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -std=c11 -std=c++11 -stdlib=libc++")
67 add_definitions(-DBSD -DNOSTEREO -Dfreebsd)
68 set(CMAKE_C_FLAGS "${CMAKE_C_FLAGS} -mmacosx-version-min=10.7")
69 endif()
70
71 if(BUILD_LIBTIFF)
72 include(ExternalProject)
73 set(LIBTIFF_URL http://download.osgeo.org/libtiff/tiff-4.0.9.tar.gz)
74 set(LIBTIFF_MD5 54BAD211279CC93EB4FCA31BA9BFDC79)
75 if(WIN32)
76 ExternalProject_Add(libtiff
77 URL ${LIBTIFF_URL}
78 URL_MD5 ${LIBTIFF_MD5}
79 CMAKE_GENERATOR "NMake Makefiles"
80 CMAKE_ARGS
81 "-UHAVE_UNISTD_H"
82 "-DBUILD_SHARED_LIBS=OFF"
83 "-DCMAKE_BUILD_TYPE=Release"
84 "-Dzlib=OFF"
85 "../libtiff"
86 INSTALL_COMMAND ""
87 )
88 set(TIFF_LIBRARY ${CMAKE_BINARY_DIR}/libtiff-prefix/src/libtiff-build/libtiff/tiff.lib)
89 else()
90 ExternalProject_Add(libtiff
91 URL ${LIBTIFF_URL}
92 URL_MD5 ${LIBTIFF_MD5}
93 CMAKE_ARGS
94 "-DBUILD_SHARED_LIBS=OFF"
95 "-DCMAKE_BUILD_TYPE=Release"
96 "-Dzlib=OFF"
97 "../libtiff"
98 INSTALL_COMMAND ""
99 )
100 set(TIFF_LIBRARY ${CMAKE_BINARY_DIR}/libtiff-prefix/src/libtiff-build/libtiff/libtiff.a)
101 endif()
102 set(TIFF_INCLUDE_DIR ${CMAKE_BINARY_DIR}/libtiff/src/libtiff/libtiff)
103 endif()
104
105 set(CPACK_PACKAGE_VERSION_MAJOR ${PROJECT_VERSION_MAJOR})
106 set(CPACK_PACKAGE_VERSION_MINOR ${PROJECT_VERSION_MINOR})
107 set(CPACK_PACKAGE_INSTALL_DIRECTORY "Radiance")
108 set(CPACK_RESOURCE_FILE_WELCOME "${radiance_SOURCE_DIR}/Welcome.txt")
109 set(CPACK_RESOURCE_FILE_README "${radiance_SOURCE_DIR}/README.txt")
110 set(CPACK_RESOURCE_FILE_LICENSE "${radiance_SOURCE_DIR}/License.txt")
111
112 if(APPLE)
113 set(CPACK_GENERATOR "PackageMaker")
114 elseif(UNIX)
115 set(CPACK_GENERATOR "TGZ")
116 endif()
117
118 include(CPack)
119
120 if(NOT BUILD_HEADLESS)
121 # find_package(Qt5Widgets)
122 # get_target_property(QT_LIBRARY_DIR Qt5::Core LOCATION)
123 # get_filename_component(QT_LIBRARY_DIR ${QT_LIBRARY_DIR} PATH)
124 # get_filename_component(QT_LIBRARY_DIR "${QT_LIBRARY_DIR}/.." ABSOLUTE)
125 find_package(X11)
126 if(APPLE)
127 include_directories(${X11_INCLUDE_DIR})
128 endif()
129 endif()
130
131 set(EXECUTABLE_OUTPUT_PATH ${PROJECT_BINARY_DIR}/bin)
132
133 if(MSVC)
134 add_definitions(/MP)
135 # Suppress warnings about double-to-float assignments and initializations
136 add_compile_options(/wd"4244" /wd"4305")
137 endif()
138 if(WIN32 AND "${CMAKE_C_COMPILER_ID}" MATCHES "^(Intel)$")
139 set(_INTEL_WINDOWS 1)
140 endif()
141 if(MSVC OR _INTEL_WINDOWS)
142 add_definitions(-D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE)
143 endif()
144 if(WIN32)
145 add_definitions(-DEZXML_NOMMAP -Dfseeko=fseek -Dstrcasecmp=_stricmp)
146 endif()
147
148 add_subdirectory("src")
149
150 set(test_dir "${CMAKE_CURRENT_SOURCE_DIR}/test/test data")
151
152 add_subdirectory(resources)
153
154 install(DIRECTORY "${CMAKE_BINARY_DIR}/lib/"
155 DESTINATION "lib"
156 )
157
158 # copy make tests to build
159 file(COPY test DESTINATION ${CMAKE_BINARY_DIR})
160
161
162 include(InstallRequiredSystemLibraries)
163 add_subdirectory(InstallRules)
