root/radiance/ray/CMakeLists.txt
Revision: 1.32
Committed: Wed Jul 23 16:20:13 2025 UTC (2 weeks, 2 days ago) by greg
CVS Tags: rad6R0
Changes since 1.31: +1 -0 lines
chore: Build updates to compile rxpiece on non-Window machines (thanks to Mingbo Peng)
# User Rev Content
1 greg 1.30 cmake_minimum_required(VERSION 3.12)
2 greg 1.19 cmake_policy(SET CMP0020 NEW)
3     cmake_policy(SET CMP0048 NEW)
4 greg 1.30 cmake_policy(SET CMP0054 NEW)
5     cmake_policy(SET CMP0074 NEW)
6
7     # project-defined modules
8     set(CMAKE_MODULE_PATH "${CMAKE_CURRENT_LIST_DIR}/resources/cmake/modules")
9
10 greg 1.31 set(SUPPORTED_LANGUAGES C CXX)
11
12 greg 1.30 # Get the project version.
13     set(VERSIONFILE "${CMAKE_CURRENT_LIST_DIR}/src/rt/VERSION")
14     if(EXISTS ${VERSIONFILE})
15     file(READ ${VERSIONFILE} NAMEVERSION)
16     if(${NAMEVERSION} MATCHES "^([A-Za-z]+) +([0-9]+\\.[0-9]+)")
17     # project name must be lower case, or the CPack module fails
18     string(TOLOWER ${CMAKE_MATCH_1} PROGNAME)
19 greg 1.31 project(${PROGNAME} VERSION ${CMAKE_MATCH_2} LANGUAGES ${SUPPORTED_LANGUAGES})
20 greg 1.30 endif()
21     else()
22 greg 1.31 project(radiance LANGUAGES ${SUPPORTED_LANGUAGES})
23 greg 1.19 endif()
24
25 greg 1.30 message("Project: " ${CMAKE_PROJECT_NAME} " " ${PROJECT_VERSION})
26 greg 1.19
27     set(PROJECT_VERSION_TWEAK "Unknown" CACHE STRING "Commit Hash")
28     find_package(Git)
29     if(GIT_FOUND)
30     execute_process(COMMAND "${GIT_EXECUTABLE}" "rev-parse" "--short=10" "HEAD"
31     WORKING_DIRECTORY "${CMAKE_SOURCE_DIR}"
32     TIMEOUT 10
33     RESULT_VARIABLE RESULT
34     OUTPUT_VARIABLE GIT_VERSION
35     ERROR_QUIET
36     OUTPUT_STRIP_TRAILING_WHITESPACE
37     )
38     if(${RESULT} EQUAL 0 AND NOT "${GIT_VERSION}" EQUAL "${PROJECT_VERSION_TWEAK}")
39     set(PROJECT_VERSION_TWEAK ${GIT_VERSION} CACHE STRING "Commit Hash" FORCE)
40 greg 1.15 endif()
41     endif()
42
43 greg 1.1 enable_testing()
44     include(CTest)
45
46     option(BUILD_SHARED_LIBS "Build radiance using shared libraries?" OFF)
47 greg 1.9 option(BUILD_HEADLESS "Build radiance without any GUI components?" OFF)
48 greg 1.18 option(BUILD_PABOPTO_UTILS "Build PABOpto Utilities?" OFF)
49 greg 1.19 option(BUILD_LIBTIFF "Build libtiff?" OFF)
50 greg 1.27 option(BUILD_QT "Build Qt related stuff?" OFF)
51 greg 1.1
52     if(NOT WIN32)
53 greg 1.4 set(CPACK_INCLUDE_TOPLEVEL_DIRECTORY 1)
54 greg 1.19 install(DIRECTORY "${CMAKE_CURRENT_SOURCE_DIR}/doc/man/" DESTINATION man)
55 greg 1.27 if(BUILD_QT)
56     set(qt_plugin_term "PLUGIN")
57     endif()
58 greg 1.1 endif()
59 greg 1.4
60 greg 1.19 if(WIN32)
61 greg 1.23 set(CPACK_NSIS_INSTALL_ROOT "C:")
62 greg 1.10 set(CPACK_NSIS_MODIFY_PATH 1)
63 greg 1.27 if(BUILD_QT)
64     set(qt_plugin_term "LIBRARY")
65     endif()
66 greg 1.4
67 greg 1.10 # Set RAYPATH on install
68     set(CPACK_NSIS_EXTRA_INSTALL_COMMANDS
69 greg 1.11 "WriteRegExpandStr HKLM \\\"SYSTEM\\\\CurrentControlSet\\\\Control\\\\Session Manager\\\\Environment\\\" RAYPATH '\\\$INSTDIR\\\\lib\\\;.'"
70 greg 1.10 )
71 greg 1.4
72 greg 1.10 # Unset RAYPATH on uninstall
73     set(CPACK_NSIS_EXTRA_UNINSTALL_COMMANDS
74     "DeleteRegValue HKLM \\\"SYSTEM\\\\CurrentControlSet\\\\Control\\\\Session Manager\\\\Environment\\\" RAYPATH"
75     )
76 greg 1.4 endif()
77
78     if(UNIX)
79     set(CPACK_PACKAGING_INSTALL_PREFIX "/usr/local/radiance")
80     add_definitions(-Dlinux -D_FILE_OFFSET_BITS=64 -DNOSTEREO)
81     else()
82 greg 1.5 set(CPACK_PACKAGING_INSTALL_PREFIX "/")
83 greg 1.4 endif()
84
85 greg 1.21 set(CPACK_PACKAGE_FILE_NAME "${CMAKE_PROJECT_NAME}-${PROJECT_VERSION_MAJOR}.${PROJECT_VERSION_MINOR}.${PROJECT_VERSION_TWEAK}-${CMAKE_SYSTEM_NAME}")
86 greg 1.19
87 greg 1.4 if(APPLE)
88 greg 1.19 set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -std=c11 -std=c++11 -stdlib=libc++")
89 greg 1.32 add_compile_options(-O2 -DBSD -DNOSTEREO -Dfreebsd)
90 greg 1.4 add_definitions(-DBSD -DNOSTEREO -Dfreebsd)
91 greg 1.30 set(CMAKE_OSX_DEPLOYMENT_TARGET "10.13")
92 greg 1.4 endif()
93
94 greg 1.19 if(BUILD_LIBTIFF)
95     include(ExternalProject)
96     set(LIBTIFF_URL http://download.osgeo.org/libtiff/tiff-4.0.9.tar.gz)
97     set(LIBTIFF_MD5 54BAD211279CC93EB4FCA31BA9BFDC79)
98     if(WIN32)
99     ExternalProject_Add(libtiff
100     URL ${LIBTIFF_URL}
101     URL_MD5 ${LIBTIFF_MD5}
102     CMAKE_GENERATOR "NMake Makefiles"
103     CMAKE_ARGS
104 greg 1.25 "-UHAVE_UNISTD_H"
105 greg 1.19 "-DBUILD_SHARED_LIBS=OFF"
106     "-DCMAKE_BUILD_TYPE=Release"
107     "-Dzlib=OFF"
108     "../libtiff"
109     INSTALL_COMMAND ""
110     )
111     set(TIFF_LIBRARY ${CMAKE_BINARY_DIR}/libtiff-prefix/src/libtiff-build/libtiff/tiff.lib)
112     else()
113     ExternalProject_Add(libtiff
114     URL ${LIBTIFF_URL}
115     URL_MD5 ${LIBTIFF_MD5}
116     CMAKE_ARGS
117     "-DBUILD_SHARED_LIBS=OFF"
118     "-DCMAKE_BUILD_TYPE=Release"
119     "-Dzlib=OFF"
120     "../libtiff"
121     INSTALL_COMMAND ""
122     )
123     set(TIFF_LIBRARY ${CMAKE_BINARY_DIR}/libtiff-prefix/src/libtiff-build/libtiff/libtiff.a)
124     endif()
125     set(TIFF_INCLUDE_DIR ${CMAKE_BINARY_DIR}/libtiff/src/libtiff/libtiff)
126     endif()
127 greg 1.7
128 greg 1.19 set(CPACK_PACKAGE_VERSION_MAJOR ${PROJECT_VERSION_MAJOR})
129     set(CPACK_PACKAGE_VERSION_MINOR ${PROJECT_VERSION_MINOR})
130 greg 1.5 set(CPACK_PACKAGE_INSTALL_DIRECTORY "Radiance")
131 greg 1.19 set(CPACK_RESOURCE_FILE_WELCOME "${radiance_SOURCE_DIR}/Welcome.txt")
132     set(CPACK_RESOURCE_FILE_README "${radiance_SOURCE_DIR}/README.txt")
133     set(CPACK_RESOURCE_FILE_LICENSE "${radiance_SOURCE_DIR}/License.txt")
134 greg 1.4
135 greg 1.19 if(APPLE)
136     set(CPACK_GENERATOR "PackageMaker")
137     elseif(UNIX)
138     set(CPACK_GENERATOR "TGZ")
139     endif()
140 greg 1.4
141 greg 1.1 include(CPack)
142
143 greg 1.9 if(NOT BUILD_HEADLESS)
144 greg 1.27 if(BUILD_QT)
145 greg 1.26 find_package(Qt5Widgets)
146     get_target_property(QT_LIBRARY_DIR Qt5::Core LOCATION)
147     get_filename_component(QT_LIBRARY_DIR ${QT_LIBRARY_DIR} PATH)
148     get_filename_component(QT_LIBRARY_DIR "${QT_LIBRARY_DIR}/.." ABSOLUTE)
149 greg 1.27 endif()
150 greg 1.30 if(APPLE)
151     set(X11_ROOT "/opt/X11")
152     endif()
153 greg 1.9 find_package(X11)
154 greg 1.20 if(APPLE)
155     include_directories(${X11_INCLUDE_DIR})
156 greg 1.30 endif()
157     if(APPLE AND X11_FOUND)
158     set(CMAKE_FIND_FRAMEWORK NEVER)
159     set(OpenGL_ROOT "/opt/X11")
160     find_package(OpenGL)
161     set(CMAKE_FIND_FRAMEWORK "")
162     else()
163     find_package(OpenGL)
164     endif()
165
166 greg 1.9 endif()
167 greg 1.1
168 greg 1.19 set(EXECUTABLE_OUTPUT_PATH ${PROJECT_BINARY_DIR}/bin)
169 greg 1.1
170 greg 1.19 if(MSVC)
171     add_definitions(/MP)
172 greg 1.24 # Suppress warnings about double-to-float assignments and initializations
173     add_compile_options(/wd"4244" /wd"4305")
174 greg 1.19 endif()
175 greg 1.1 if(WIN32 AND "${CMAKE_C_COMPILER_ID}" MATCHES "^(Intel)$")
176     set(_INTEL_WINDOWS 1)
177     endif()
178     if(MSVC OR _INTEL_WINDOWS)
179     add_definitions(-D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE)
180     endif()
181     if(WIN32)
182     add_definitions(-DEZXML_NOMMAP -Dfseeko=fseek -Dstrcasecmp=_stricmp)
183     endif()
184
185     add_subdirectory("src")
186
187 greg 1.19 set(test_dir "${CMAKE_CURRENT_SOURCE_DIR}/test/test data")
188 greg 1.5
189 greg 1.19 add_subdirectory(resources)
190 greg 1.5
191 greg 1.19 install(DIRECTORY "${CMAKE_BINARY_DIR}/lib/"
192     DESTINATION "lib"
193 greg 1.1 )
194
195 greg 1.22 # copy make tests to build
196     file(COPY test DESTINATION ${CMAKE_BINARY_DIR})
197
198
199 greg 1.1 include(InstallRequiredSystemLibraries)
200     add_subdirectory(InstallRules)
