root/radiance/platform/README
Revision: 1.4
Committed: Thu Mar 10 17:36:18 2016 UTC (9 years, 8 months ago) by schorsch
CVS Tags: rad6R0, rad5R4, rad5R3, rad5R2, rad5R1, HEAD
Changes since 1.3: +7 -3 lines
Tifflib support and sleeker binaries on Windows
# User Rev Content
1 schorsch 1.2 Platform configuration files for the SCons based build system
2     -------------------------------------------------------------
3 schorsch 1.1
4 schorsch 1.3 <platform>_<##>.cfg
5 schorsch 1.1 --------------
6
7 schorsch 1.3 The <platform>_<##>.cfg files in this directory are used to determine
8 schorsch 1.1 the right settings, libraries, source files etc. on the platform
9     where you are building Radiance. The build system will select the
10 schorsch 1.2 appropriate file automatically.
11 schorsch 1.1
12     If your platform isn't supported yet, then you can create a new
13 schorsch 1.2 file with an appropriat name (SCons should tell you what it
14 schorsch 1.1 expects). Usually, you will start by copying the file of the most
15 schorsch 1.3 similar supported platform, and then make the necessary changes.
16 schorsch 1.1
17     On unix based platforms without a specific config file, the file
18 schorsch 1.3 "posix_<##>.cfg" will be used (which may or may not work well enough).
19 schorsch 1.1
20 schorsch 1.3 As of this writing, the following platforms are included where the
21     numbers 32 and 64 indicate 32 bit or 64 bit systems rspectively.
22 schorsch 1.2 (although not all of them have been tested very recently):
23
24 schorsch 1.3 * Linux_32.cfg Linux
25     * Linux_63.cfg Linux
26     * FreeBSD_32.cfg FreeBSD unix
27     * FreeBSD_64.cfg FreeBSD unix
28     * Darwin_64.cfg Macintosh OS-X
29     * Darwin_32.cfg Macintosh OS-X
30     * posix_64.cfg default for unknown Unix systems
31     * posix_32.cfg default for unknown Unix systems
32     * Windows_64.cfg Microsoft Windows with Visual C/C++
33     * Windows_32.cfg Microsoft Windows with Visual C/C++
34     * mingw_64.cfg MingW on MS Windows http://www.mingw.org/
35     * mingw_32.cfg MingW on MS Windows http://www.mingw.org/
36
37     The configuration for 32 bit and 64 bit architecture of the
38     same platform will typically be very similar, with just some
39     compiler flags indicating the different target.
40 schorsch 1.2
41 schorsch 1.1
42     <platform>_custom.cfg
43     ---------------------
44
45 schorsch 1.3 If you want to experiment with changes to the downloaded file, then
46 schorsch 1.1 you can create a copy named <platform>_custom.cfg, and make your
47     changes there. If such a file exists, then it will be used in
48     place of the original.
49
50
51     Contents and format
52     -------------------
53
54     Any text starting with a hash character (#) until the end of the
55     line is ignored as a comment.
56
57     A config file consists of several sections, each of which is
58     introduced by a keyword in brackets.
59     Within each section, a configuration directive starts with a
60 schorsch 1.2 keyword and a colon, followed by the data assigned to that keyword.
61 schorsch 1.1
62
63     Sections
64     --------
65
66     [install] # directories where to install the software
67 schorsch 1.2 [build] # compile and link instructions for production builds
68     [debug] # compile and link instructions for debug builds
69 schorsch 1.1 [code] # code compatibility configuration
70
71
72     Install section
73     ---------------
74
75 schorsch 1.3 Values in this section may refer to environment variables, in the
76     form {VARNAME}. On Windows the variable names must be given in
77     all uppercase.
78
79 schorsch 1.1 # The root directory of the Radiance installation
80 schorsch 1.3 # The second example reflects the installation standard on Windows.
81     RAD_BASEDIR: /opt/radiance
82     RAD_BASEDIR: {PROGRAMFILES}/radiance
83 schorsch 1.1
84     # The following are relative to RAD_BASEDIR!
85     # The directory for executables
86     RAD_BINDIR: bin
87 schorsch 1.2
88 schorsch 1.1 # The directory for support files (.cal, .pic, .fnt, etc.)
89     RAD_RLIBDIR: share/lib
90 schorsch 1.2
91     # The directory for the man pages
92 schorsch 1.1 RAD_MANDIR: share/man
93
94
95     Debug and Build sections
96     ------------------------
97
98 schorsch 1.3 The same keywords can (and usually will) be used in both, but
99     their assigned values will often differ.
100 schorsch 1.1
101     # The compiler to use (example: Gnu gcc)
102     CC: gcc
103
104 schorsch 1.2 # The directories for system header files (not normally needed).
105 schorsch 1.1 CPPPATH:
106
107 schorsch 1.3 # Symbols to define for the preprocessor (example for Mingw)
108 schorsch 1.4 # The symbol "RT_WINPROC" enables the use of our custom popen
109     # routine, which allows for pipelining, backslash-newline
110     # escapes, and some more functionality without the need for
111     # a unix shell.
112     CPPDEFINES: freebsd HDSUF=.exe RT_WINPROC
113 schorsch 1.1
114 schorsch 1.3 # Flags for the C preprocessor (example for gcc)
115 schorsch 1.1 CPPFLAGS: -O2 -Wall -Wno-uninitialized
116
117 schorsch 1.2 # Flags for the C compiler (example for debug build with gcc)
118 schorsch 1.1 CCFLAGS: -pg
119
120 schorsch 1.2 # The directories for system libraries (not normally needed)
121 schorsch 1.1 LIBPATH:
122
123     # Flags for the linker (example for debug build on Windows)
124 schorsch 1.4 LINKFLAGS: /DEBUG /INCREMENTAL:NO
125 schorsch 1.1
126     # Flags specific to ezxml.c (example for cygwin/mingw)
127     EZXML_CPPDEFINES: EZXML_NOMMAP
128
129     # Where to find an installed libtiff and its include files
130     # (Not needed when on a standard search path)
131     # If no libtiff is found here or on the standard paths, then
132 schorsch 1.4 # the executables "normtiff" and "ra_tiff" won't be built.
133 schorsch 1.1 TIFFLIB:
134     TIFFINCLUDE:
135
136
137     The Code section
138     ----------------
139
140     # There should be no need to edit this section in existing
141     # config files. If you create a new file for a yet untested
142 schorsch 1.2 # platform, you may need to ask on the dev-list what will
143     # work here.
144 schorsch 1.1
145     RAD_COMPAT: # theoretically obsolete (src/common/strcmp.c)
146     RAD_MATHCOMPAT: # erf.c floating point error function
147     RAD_ARGSCOMPAT: # fixargv0.c for Windows
148     RAD_NETCOMPAT: # [win_]netproc.c for ranimate
149     RAD_MLIB: # usually 'm', or any fastlib available
150     RAD_SOCKETLIB: # ws_2_32 on Windows (VC links it automatically)
151     RAD_PROCESS: # our process abstraction and win_popen()
152     RAD_PCALLS: # more custom process abstraction
153
154 schorsch 1.2
155
