root/radiance/platform/FreeBSD_32.cfg
Mon Apr 21 07:31:28 2008 UTC (17 years, 5 months ago) by schorsch
CVS Tags: rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0
Changes since 1.5: +1 -0 lines
Diff to previous 1.5
Scons update for mingw.
Mon Sep 19 11:30:10 2005 UTC (20 years, 1 month ago) by schorsch
Diff to previous 1.4
Wed Feb 2 00:17:35 2005 UTC (20 years, 8 months ago) by schorsch
Diff to previous 1.3
Turned bmalloc.c into a standard module.
Thu Oct 21 15:47:12 2004 UTC (20 years, 11 months ago) by schorsch
Changes since 1.2: +6 -6 lines
Diff to previous 1.2
SCons build simplifications.
Mon Oct 27 10:35:41 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 1.1: +7 -1 lines
Diff to previous 1.1
Tue Oct 21 19:27:28 2003 UTC (21 years, 11 months ago) by schorsch
