| 1 | SCCSid "@(#)noX11.help 2.5 11/4/92 LBL" |
| 2 | This Radiance distribution assumes that you have X11 support |
| 3 | (ie.  a /usr/include/X11 directory and /usr/lib/libX11.a library). |
| 4 | If you have X11 installed but in a non-standard location, you only |
| 5 | need to edit the rmake script to add the needed -I and -L options. |
| 6 | If this is not the case, you will have to make a couple of changes |
| 7 | to the files in the src/rt directory to make "rview" compile properly. |
| 8 | If you are a thorough person, you can also make changes to the Rmakefile's |
| 9 | in the src/util and src/px directory to avoid some other spurious but |
| 10 | unimportant errors.  If you do not, you will have to copy the executable |
| 11 | files from those directories manually since rmake will not do so. |
| 12 |  |
| 13 | The following diffs should be applied to Rmakefile and devtable.c in the |
| 14 | src/rt subdirectory: |
| 15 |  |
| 16 | ============= rt/Rmakefile ============= |
| 17 | 35c35 |
| 18 | < DOBJS = devtable.o devcomm.o editline.o x11.o x11twind.o \ |
| 19 | --- |
| 20 | > DOBJS = devtable.o devcomm.o editline.o \ |
| 21 | 37c37 |
| 22 | < DSRC = devtable.c devcomm.c editline.c x11.c x11twind.c \ |
| 23 | --- |
| 24 | > DSRC = devtable.c devcomm.c editline.c \ |
| 25 | 39c39 |
| 26 | < DLIBS = -lX11 |
| 27 | --- |
| 28 | > DLIBS = |
| 29 |  |
| 30 | ============= rt/devtable.c ============= |
| 31 | 15c15 |
| 32 | < char  dev_default[] = "x11"; |
| 33 | --- |
| 34 | > char  dev_default[] = "sun";          /* or "news" for SGI */ |
| 35 | 17,18d16 |
| 36 | < extern struct driver  *x11_init(); |
| 37 | < |
| 38 | 23c21 |
| 39 | <       {"x11", "X11 color or greyscale display", x11_init}, |
| 40 | --- |
| 41 | >       {"x11", "X11 color or greyscale display", comm_init}, |
| 42 |  |
| 43 | These changes may be applied to the Rmakefile's in the src/util and |
| 44 | src/px subdirectories for cleaner compilation: |
| 45 |  |
| 46 | =============== px/Rmakefile ============= |
| 47 | 19c19 |
| 48 | < ra_t8 ra_bn ra_t16 pcomb pinterp ximage xshowtrace pflip |
| 49 | --- |
| 50 | > ra_t8 ra_bn ra_t16 pcomb pinterp pflip |
| 51 |  |
| 52 | =============== util/Rmakefile ============ |
| 53 | 13c13 |
| 54 | < PROGS = rpiece findglare xglaresrc glarendx |
| 55 | --- |
| 56 | > PROGS = rpiece findglare glarendx |
