| 1 | #!/bin/csh -f |
| 2 | # RCSid $Id: makeall,v 1.27 2012/04/25 22:21:06 greg Exp $ |
| 3 | # |
| 4 | # Make all the Radiance programs |
| 5 | # |
| 6 | if ( $#argv < 1 ) then |
| 7 | echo "Usage: makeall install [clean] [make options]" |
| 8 | echo "   or: makeall clean" |
| 9 | echo "   or: makeall library" |
| 10 | exit 1 |
| 11 | endif |
| 12 | if ( "$1" == library ) then |
| 13 | source installib |
| 14 | cp -f src/*/*.{cal,tab,hex,dat} $ldir |
| 15 | echo "" |
| 16 | echo "Set the environment variable RAYPATH=.:$ldir" |
| 17 | echo 'For C-shell users, put the following into ~/.cshrc' |
| 18 | echo "  setenv RAYPATH .:$ldir" |
| 19 | echo 'For Bourne shell users, put the following into $HOME/.profile' |
| 20 | echo "  RAYPATH=.:$ldir" |
| 21 | echo "  export RAYPATH" |
| 22 | echo "" |
| 23 | exit 0 |
| 24 | endif |
| 25 | set srcdirs=( common rt meta cv gen ot px hd util cal ) |
| 26 | if ( "$1" == install ) then |
| 27 | cat << _EOF_ |
| 28 |  |
| 29 | `cat src/rt/VERSION` INSTALLATION |
| 30 |  |
| 31 | This script rebuilds all of the Radiance programs and installs |
| 32 | them on your system.  You should read the file README before running |
| 33 | this script.  You can type ^C (followed by return) at any time to abort. |
| 34 |  |
| 35 | You must first answer the following questions. |
| 36 |  |
| 37 | _EOF_ |
| 38 | if ( ! $?EDITOR ) then |
| 39 | echo -n "What is your preferred editor [vi]? " |
| 40 | set ans="$<" |
| 41 | if ( "$ans" != "" ) then |
| 42 | setenv EDITOR "$ans" |
| 43 | else |
| 44 | setenv EDITOR vi |
| 45 | endif |
| 46 | endif |
| 47 | again1: |
| 48 | echo -n "Where do you want the executables [/usr/local/bin]? " |
| 49 | set idir=$< |
| 50 | (echo $idir) >/dev/null |
| 51 | if ( $status ) then |
| 52 | goto again1 |
| 53 | endif |
| 54 | set idir=$idir |
| 55 | if ( "$idir" == "" ) then |
| 56 | set idir=/usr/local/bin |
| 57 | else if ( "$idir" !~ /* ) then |
| 58 | echo "Directory must be relative to root, please reenter" |
| 59 | goto again1 |
| 60 | endif |
| 61 | if ( ! -d $idir ) then |
| 62 | mkdir $idir |
| 63 | if ( $status ) then |
| 64 | echo "Cannot create directory, please reenter" |
| 65 | goto again1 |
| 66 | endif |
| 67 | endif |
| 68 | set inpath=0 |
| 69 | foreach i ( $path ) |
| 70 | if ( "$i" == "$idir" ) then |
| 71 | set inpath=1 |
| 72 | break |
| 73 | endif |
| 74 | end |
| 75 | set rmake=$idir/rmake |
| 76 | if ( "`ls -tL $rmake $0 |& head -1`" == $rmake ) then |
| 77 | goto gotrmake |
| 78 | endif |
| 79 | set newrmake |
| 80 | more License.txt |
| 81 | echo -n "Do you understand and accept the terms of this agreement [n]? " |
| 82 | set ans="$<" |
| 83 | if ( "$ans" !~ [yY]* ) exit |
| 84 | set special= |
| 85 | set arch= |
| 86 | set opt= |
| 87 | set mach= |
| 88 | set compat= |
| 89 | set extras= |
| 90 | set esuffix= |
| 91 | cat << _EOF_ |
| 92 |  |
| 93 | Please select your system type from the following list: |
| 94 |  |
| 95 | 1)      Sun Solaris |
| 96 | 2)      Linux |
| 97 | 3)      MacOS X |
| 98 | 4)      FreeBSD |
| 99 | 5)      Cygwin |
| 100 | 6)      Other |
| 101 |  |
| 102 | _EOF_ |
| 103 | echo -n "Choice? " |
| 104 | set arch="$<" |
| 105 | switch ("$arch") |
| 106 | case 1:                 # SPARC Station |
| 107 | set arch=sun |
| 108 | set mach="-I/usr/openwin/include -L/usr/openwin/lib -DNOSTEREO" |
| 109 | set opt="-O" |
| 110 | set compat="strcmp.o timegm.o" |
| 111 | breaksw |
| 112 | case 2:                 # Linux |
| 113 | set mach="-Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO" |
| 114 | set opt="-O2" |
| 115 | set arch=IBMPC |
| 116 | set compat="erf.o" |
| 117 | set extras=CC=gcc |
| 118 | breaksw |
| 119 | case 3:                 # MacOS X |
| 120 | set mach="-DBSD -DNOSTEREO -Dfreebsd -I/usr/X11R6/include -L/usr/X11R6/lib" |
| 121 | set opt="-O2" |
| 122 | set arch=Intel |
| 123 | set extras="CC=cc CONFIGURE_ARCH=i386" |
| 124 | set special="ogl" |
| 125 | breaksw |
| 126 | case 4:                 # FreeBSD |
| 127 | set mach="-DBSD -DNOSTEREO -Dfreebsd -I/usr/X11R6/include -L/usr/X11R6/lib" |
| 128 | set opt="-O" |
| 129 | set compat="erf.o" |
| 130 | set extras='CC=cc MLIB="-lcompat -lm"' |
| 131 | set arch=IBMPC |
| 132 | breaksw |
| 133 | case 5:                 # Cygwin |
| 134 | set mach="-Dfreebsd -L/usr/lib -L/usr/X11R6/lib -I/usr/include/X11 -I/usr/X11R6/include -DNOSTEREO" |
| 135 | set opt="-O2" |
| 136 | set arch=IBMPC |
| 137 | set compat="erf.o" |
| 138 | set extras="CC=gcc" |
| 139 | set special="ogl" |
| 140 | set esuffix=".exe" |
| 141 | breaksw |
| 142 | case 6:                 # Other |
| 143 | set opt="-O" |
| 144 | set compat="erf.o strcmp.o" |
| 145 | echo -n "Are you using the GNU C compiler [n]? " |
| 146 | if ( "$<" =~ [yY]* ) then |
| 147 | set extras="CC=gcc" |
| 148 | else |
| 149 | set compat="$compat timegm.o" |
| 150 | endif |
| 151 | set arch=other |
| 152 | breaksw |
| 153 | default: |
| 154 | echo "Illegal choice\!" |
| 155 | echo "Installation aborted." |
| 156 | exit 1 |
| 157 | breaksw |
| 158 | endsw |
| 159 | source installib |
| 160 | sed 's/[        ]*$//' > $rmake << _EOF_ |
| 161 | #!/bin/sh |
| 162 | exec make "SPECIAL=$special" \ |
| 163 | "OPT=$opt" \ |
| 164 | "MACH=$mach" \ |
| 165 | ARCH=$arch "COMPAT=$compat" \ |
| 166 | INSTDIR=$idir \ |
| 167 | LIBDIR=$ldir \ |
| 168 | ESUFFIX=$esuffix \ |
| 169 | $extras "\$@" -f Rmakefile |
| 170 | _EOF_ |
| 171 | chmod 755 $rmake |
| 172 | chmod 644 src/*/Rmakefile src/rt/devtable.c |
| 173 | gotrmake: |
| 174 | echo "Current rmake command is:" |
| 175 | cat $rmake |
| 176 | echo -n "Do you want to change it? " |
| 177 | set ans="$<" |
| 178 | if ( "$ans" =~ [yY]* ) then |
| 179 | cp $rmake /tmp/rmake$$ |
| 180 | $EDITOR $rmake |
| 181 | if ( `cat $rmake /tmp/rmake$$ | grep OPT= | uniq | wc -l` == 2 ) set newrmake |
| 182 | rm -f /tmp/rmake$$ |
| 183 | endif |
| 184 | if ( ! -d src/lib ) then |
| 185 | mkdir src/lib |
| 186 | endif |
| 187 | if ( $?newrmake ) then |
| 188 | echo 'New rmake command -- running "makeall clean"...' |
| 189 | csh -f $0 clean |
| 190 | endif |
| 191 | cd src |
| 192 | echo "Making programs..." |
| 193 | set errs=0 |
| 194 | foreach i ( $srcdirs ) |
| 195 | pushd $i |
| 196 | echo "In directory $i..." |
| 197 | $rmake -k $* |
| 198 | @ errs += $status |
| 199 | popd |
| 200 | end |
| 201 | if ( $errs ) then |
| 202 | echo "There were some errors." |
| 203 | else |
| 204 | echo "Done." |
| 205 | endif |
| 206 | cd .. |
| 207 | if (! $inpath ) then |
| 208 | echo "" |
| 209 | echo "Add $idir to the beginning of your execution path:" |
| 210 | echo 'For C-shell users, put the following into ~/.cshrc' |
| 211 | echo "  set path=( $idir "'$path )' |
| 212 | echo 'For Bourne shell users, put the following into $HOME/.profile' |
| 213 | echo "  PATH=$idir"':$PATH' |
| 214 | echo "  export PATH" |
| 215 | endif |
| 216 | else |
| 217 | cd src |
| 218 | foreach i ( $srcdirs ) |
| 219 | pushd $i |
| 220 | echo "In directory $i..." |
| 221 | make -f Rmakefile $* |
| 222 | popd |
| 223 | end |
| 224 | cd .. |
| 225 | foreach i ( $* ) |
| 226 | if ( "$i" == clean ) then |
| 227 | echo "Removing library archives..." |
| 228 | rm -f src/lib/*.{a,o,la} |
| 229 | endif |
| 230 | end |
| 231 | echo "Done." |
| 232 | endif |
| 233 | exit 0 |
